Old 07-03-2013, 06:35 AM   #4276
cyba888's Avatar
Had the SpecR ones and in my opinion they were pretty bad... quality was bad and had more play than I liked. When I removed the clips for the first time and tried to put them back they had already bent out of shape. I recommend the K-factory universal ones got mine from local hobby shop for $38 and even comes with plastic caps. Build quality on these are a lot better and hardly any play. The clips did not bend at all and snaps back into place very snug like brand new. I run on large asphalt track with 4.0T motor and beat the crap out of them without any issues. A few other guys at my local track all run them on their T4.
2014 and 2015 BD7 Black Series, Yokomo RPX ESC- Yokomo 4.5T Motor
Yokomo B-MAX4 III Factory Team Kit, Muchmore ESC- LRP 6.5T Motor
Mugen MBX7R Eco- 2200 KV Motor
Futaba 4PX
cyba888 is offline   Reply With Quote
Old 07-04-2013, 07:12 PM   #4277
rcguyfpr's Avatar
Trader Rating: 21 (100%+)
Looks nice. Any modification needed to use them on T4? thx
rcguyfpr is offline   Reply With Quote
Old 07-04-2013, 07:39 PM   #4278
Ron Goetter's Avatar
Trader Rating: 17 (95%+)
Send a message via AIM to Ron Goetter
Originally Posted by Kensei View Post
Thx, gonna get me the XRay axles.
A pro seems to me that they are available in 50mm and 52mm.
Is it necessary to use shrink tube?
If so, what diametre?
Sorry for asking but these are my first djc axles.....
Since Xray went to the new 2mm joint pin I have stopped using Heat shrink and have been fine so far. You can use heat shrink as an added safety if you would like to. Just be sure to clean the set screw with motor spray and dry it off before putting on some blue loctite.
The Goat... B-Mainer Fo' life
-Awesomatix USA-ROCHE USA-Team CRC-ORCA-SIDE PIECE RACING-TEAM DAK-EA Motorsports-VP Fuel-Trains and Lanes-CR Graphics-TQ Wire-Horsham RC-rugburn anyone?
Shut up and Race!!!!
Ron Goetter is offline   Reply With Quote
Old 07-04-2013, 08:28 PM   #4279
cyba888's Avatar
If you plan on using the plastic caps then you would need to get the hudy aluminum spool cups so that it will fit. The plastic caps help protect the spool cups. I had SpecR aluminum spool cups and after a few batteries with 4.0T motor they started to get bent out of shape making slop/play even bigger.
SpecR spool cups
Below K-factory ECS with Hudy plastic cap so far no marks on the spool cups. If you plan on running plastic caps use the Hudy ones they are more flexible and easier to install. The plastic ones that came with the K-factory kit were too stiff I broke both trying to install them...basically useless.
Futaba 4PX
Old 07-04-2013, 10:10 PM   #4280
Who makes the orange screws your using? They look great.
Lycan is offline   Reply With Quote
Old 07-05-2013, 03:43 AM   #4281
Skiddins's Avatar
The problem with everyone's outdrives (including Xray's) is that the 'walls' of the outdrive need to be thicker so that the entire blade pushes against outdrive, as they are, a lot of the blade sticks out into free air doing nothing.
Xray T4'16, T4'14 (Wet Car)
Xray X12 2016
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 07-05-2013, 04:16 AM   #4282
cyba888's Avatar
http://www.hiro-seiko.com/product.ph...id=116&id=493#
http://www.hiro-seiko.com/product.ph...id=108&id=479#
Futaba 4PX
Old 07-05-2013, 05:03 AM   #4283
If only someone had thought of that.
http://shop.awesomatixusa.com/parts/nikita-outdrives
Old 07-05-2013, 05:43 AM   #4284
hanulec's Avatar
Trader Rating: 23 (100%+)
Thx for the broken link goat
Check out--
http://sidepieceracing.com/products/nikita/
http://shop.awesomatixusa.com/nikita-outdrives.html
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 07-05-2013, 06:56 AM   #4285
Jon Williams's Avatar
Originally Posted by hanulec View Post
The nice thing about the Nikita outdrives is that you rarely have to replace the plastic blades. They don't crack or wear out like they do with Xray outdrives. Like Goat said there's a lot more surface area for the blade to press on.
Jon Williams is offline   Reply With Quote
Old 07-05-2013, 07:54 AM   #4286
Skiddins's Avatar
They're fine, but I run a gear diff in the front for Mod (the only time I use blades at the front) so I really need replacement gear diff outdrives that have a larger surface area, not the spool items.
Skiddins
Xray X12 2016
Xray X1'16
RCDisco.co.uk
Old 07-05-2013, 08:21 AM   #4287
Your welcome buddy...
Skiddins
While I know what your talkin about I find with diffs and the smaller surface area blades don't wear horribly fast. Spools on the other hand will easily kill a blade in a run or two.
Old 07-06-2013, 11:08 AM   #4288
yodace's Avatar
R/C Tech Charter Subscriber
Are there different part numbers for the aluminum shims used for rear ?
yodace is offline   Reply With Quote
Old 07-07-2013, 01:30 AM   #4289
vabroom's Avatar
What range (tooth) of 64 pinions for 17.5 blinky, do you guys have. 45 to 50?
RC racing is still trying to prove that two solid objects can be in the same place, at the same time.
vabroom is online now   Reply With Quote
Old 07-07-2013, 01:46 AM   #4290
Dan
Dan's Avatar
Trader Rating: 40 (100%+)
Around that would be good, assuming you are already outfitted with a 92T spur gear.
Dan is offline   Reply With Quote
Xray T3 2012 rasta_man Electric On-Road 4220 11-09-2016 02:45 PM
RC10B4/T4 Forum DerekL Electric Off-Road 14331 01-01-2016 03:18 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 09:55 AM
Tags
xray t4
SEO by vBSEO 3.5.0
