Old 06-18-2013, 07:47 PM   #4186
dontfeelcold's Avatar
Trader Rating: 21 (100%+)
Xray touring car designer Martin Hudy is having a really good showing here in Austria, leading his team in an improved performance over Rd4 which saw the Slovakian company fail to get any cars into the modified A-main. Since then they have done a lot of testing and found that running harder springs and harder oil helped find the steering they were lacking, while retaining a responsive car. A change to anti-dive front and rear, harder oil in the rear diff as well as progressive springs all around and they now have a car that is competitive again.
http://www.petitrc.com/reglages/xray...hen2013061315/
dontfeelcold is offline   Reply With Quote
Old 06-18-2013, 11:00 PM   #4187
I just started my build on my first xray. Lightly sanded the chassis edges with 400. Debated gluing because I thought it could be messy, but decided to go for it. I used my tire glue with glue hose, and just as people described, I put on a small bead, and it ran down smoothly, then I wiped excess with a towel. No mess. I hit it lightly with 1500 afterwards. It's not art, but hopefully it does the job.
The real reason I'm posting is the gear diff. Holy... Frigging... Crap. I've only built spec-r, and with absolutely no work, this thing is 10x better than my best spec-r ever was. I don't think I can go back.
-Mike
Old 06-19-2013, 12:46 AM   #4188
tc3team's Avatar
TTVert and JoeSi - Many thanks, it gives me something to use as a rough understanding
However, since studying the charts, all of the values suggested are all for very light cts.
I would use the kit supplied xray oil to assemble one of the differentials and use higher or lower for the other end - depending on what you guys would think is the preferred choice for the other differential. (because im a total newbie with understanding gear diffs lol )
I am looking for a lot of forward bite, as the front diff will be working rather hard on a small 10x15m technical track. (foams, high bite carpet).
So, kit oil in the front or rear? And ___ cst for the other please?
I know I will never want to go back to a ball diff when the gear diff's are built but damn.... they are easier to understand
Sorry for the newbie stuff, once i'm racing things will be easier for me... I hope lol!
Maybe I should simply build up with kit oil for both differentials....
But no doubt I will only get enough oil to fill one, even if I buy a second diff with the car, right?
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 06-19-2013, 12:52 AM   #4189
daleburr's Avatar
-Mike
Welcome aboard! Once you've switched to Xray you can never go elsewhere You'll enjoy the shocks too, they're equally amazing.
Team Xray
RC-Timing Software - http://www.rc-timing.com
Mercedes AMG F1 - http://www.mercedes-amg-f1.com/
daleburr is offline   Reply With Quote
Old 06-19-2013, 01:24 AM   #4190
Brokin Racing's Avatar
Trader Rating: 68 (100%+)
-Mike
+ 1, Yes, welcome to Xray, quality all the way
Xray Since 2007 - LRP - PF - Futaba -
Brokin Racing is offline   Reply With Quote
Old 06-19-2013, 04:43 AM   #4191
Jerz616's Avatar
Trader Rating: 49 (100%+)
The kit has enough for several diffs. I never used the kit oil in my rear diff. I went straight to 1000cst. Most are using between 1000 and 3000 depending on traction. In the front you will prob want 2.5 million.
Ryan Gracey
XRAY T4'14/ORCA VXX/ORCA TX 5.0
XRAY XB8'14
Jerz616 is offline   Reply With Quote
Old 06-19-2013, 06:13 AM   #4192
tc3team's Avatar
very useful!
Much appreciated.
I wanted to know what kind of difference front and rear diff I should expect to use on a technical high grip track to get the car handling good and not "diff out"
I see the guide mentions to use a certain amount of grammes of oil in the diff on a set of scales.... Do I need Hudy scales for this?
Old 06-19-2013, 08:39 AM   #4193
Xpress's Avatar
very useful!
Much appreciated.
I may have missed it in one of your earlier posts, but the kit only comes with 1 diff. The front "diff" isn't a differential, but rather a spool.
"Desire is the key to motivation, but it's the determination and commitment to an unrelenting pursuit of laying it down - a commitment to excellence - that will enable you to attain the success you seek to beat ass."
-Espo
Xpress is offline   Reply With Quote
Old 06-19-2013, 09:16 AM   #4194
TT_Vert's Avatar
I run on a very similar track to you except I run on a rubber VTA tire. I've been using 2k rear diff oil and a spool up front. I'm also running a heavier shock oil w/ a softer spring.
Dave
TT_Vert is offline   Reply With Quote
Old 06-19-2013, 10:08 AM   #4195
Jerz616's Avatar
Yes. It only comes with a rear diff. The front is a spool. You can buy the diff for about $60 complete.
Ryan Gracey
XRAY XB8'14
Old 06-19-2013, 10:16 AM   #4196
Jerz616's Avatar
very useful!
Much appreciated.
I don't use a front gear diff so I couldn't tell you the differences. I run blinky sedan so I use the spool. I am playing with mod sedan and will try a front diff with 2.5million in it. I have beef told it makes it a little easier to drive.
As far as I'm told. Using lighter oil in the rear diff will allow less rotation and thicker oil allows more rotation.
You don't need the Hudy scales. I just use a digital scale to fill mine.
Ryan Gracey
XRAY XB8'14
Old 06-19-2013, 12:28 PM   #4197
Barry_Hughes's Avatar
Sorry for the xray newbie question, but I have heard of some people using shock oil in the gear differentials?
Would a typical 75wt shock oil be similar to the kit 750 supplied item?
I only ask as gear diff oil does not appear to be so easy to get (I could get it from Demon Power, but if I can use shock oil then it's much easier to source! ).
Many thanks
Diff oil is very easy to get hold of especialy in the UK. Schumacher (apologies for swearing) distribute Core RC shock & diff oils that cover most needs.
Built it !
Raced it !
Wrecked it !
Barry_Hughes is offline   Reply With Quote
Old 06-19-2013, 12:34 PM   #4198
JayL's Avatar
is a new xray coming? most places seem to be backordered
MOD: A800 R1 Digital-2 HW G2 4.5T|||VTA: Awesomatix EVO 1.1 Orca VX3 24K |||F1:
Xray X1 2017 HW XR10 StockSpec R1 21.5|||Futaba 4PX|||iCharger 308Duo
JayL is offline   Reply With Quote
Old 06-19-2013, 01:59 PM   #4199
Skiddins's Avatar
Probably not until the end of the year like usual.
Of course they're on backorder, they're the car to have
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 06-19-2013, 03:24 PM   #4200
chasingthepack's Avatar
thats the brand i use core rc,which id love to have a comparison chart against the xray oils
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
Xray T3 2012 rasta_man Electric On-Road 4220 11-09-2016 01:45 PM
RC10B4/T4 Forum DerekL Electric Off-Road 14331 01-01-2016 02:18 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 08:55 AM
Tags
xray t4
