Old 06-12-2013, 04:10 PM   #4111
idbdoug's Avatar
Trader Rating: 33 (100%+)
Originally Posted by pcar951 View Post
Paul L just posted on this issue on his thread, he explains the whole belt tension thing in detail.
Can u post a link to this thread?
idbdoug
idbdoug is offline   Reply With Quote
Old 06-12-2013, 04:37 PM   #4112
bvoltz's Avatar
Trader Rating: 44 (100%+)
idbdoug
From the thread:
"Hi Peter. I do not adjust the tension of the belts based off of efficiency. Obviously i would never run the belt Super loose or Super tight but i will run the belts on the loose med or tight side of things for handling purposes.
I assume that with the ever changing speed and load of the drive train their is no perfect setting for efficiency across the board so i generally tune the belt tension for handling purposes only. I normally run the front belt on the tight side and the rear belt on the loose side. I feel like with the rear belt being so much shorter it can have the tendency to apply a more abrupt load to the rear tires than the front. making the front belt tight and rear belt loose seems to help with this. I also think that the car might turn in harder with the front belt tight and rear loose.
Thanks "
Wheeling an Xray T4 and T4 14 using a Ko Propo, powered by EA motors and Speed Passion Speedo, paid for by my wife.
Digi3Dworks - 3D printing for the medical Field.
bvoltz is offline   Reply With Quote
Old 06-12-2013, 06:08 PM   #4113
Craig W's Avatar
Send a message via MSN to Craig W Send a message via Skype™ to Craig W
carbon 2mm t4 steering brace are in stock
http://www.chubbiescarshack.co.uk/in...product_id=247
Orca www.ChubbiesCarShack.co.uk TDX SMC RC Airbrush Fundecal
Craig W is offline   Reply With Quote
Old 06-12-2013, 06:11 PM   #4114
yodace's Avatar
R/C Tech Charter Subscriber
Are those parts shown a few pages bk for carpet or asphalt ?
yodace is offline   Reply With Quote
Old 06-13-2013, 02:43 AM   #4115
tc3team's Avatar
Some interesting reading about the design of the T4 if you have not already seen it
http://www.teamxray.com/teamxray/new...T4,%20Part%201
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 06-13-2013, 04:39 AM   #4116
WIITA's Avatar
Trader Rating: 41 (100%+)
Originally Posted by chasingthepack View Post
getting back to roll centers, if i lower the roll center the car leans less or more?thanks
Couple short videos to help explain a little. Done with a b4 but still translates to tc.
https://www.youtube.com/watch?v=tWdR...e_gdata_player
https://www.youtube.com/watch?v=44Al...e_gdata_player
Team CRC / Sanwa / Team scream / Genesis RC / Hobbywing / TQ Wire / Schelle / MIP / RC^2 / TEKNO / BoomRC
WIITA is offline   Reply With Quote
Old 06-13-2013, 04:50 AM   #4117
chasingthepack's Avatar
thanks for the links,very informative,i understand it alot better now
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
Old 06-13-2013, 12:57 PM   #4118
do any of you run a single hole rear hub/upright?
Old 06-13-2013, 05:27 PM   #4119
Skiddins's Avatar
A lot of the UK team drivers use them, but I couldn't get on with them (on carpet) so changed back.
They made my car a bit loose at the rear
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 06-13-2013, 06:31 PM   #4120
yodace's Avatar
Anything I could change from basic asphalt setup to help with a loose rear end?
Old 06-13-2013, 07:14 PM   #4121
MrRolla's Avatar
Trader Rating: 29 (100%+)
On power or off power?
MrRolla is offline   Reply With Quote
Old 06-13-2013, 07:18 PM   #4122
yodace's Avatar
On power
The front pushes also coming into turns also. I think that's started when I put the -.75 roll center on up front ...
Old 06-13-2013, 10:07 PM   #4123
dontfeelcold's Avatar
Trader Rating: 21 (100%+)
On power
Sounds like the problem I am having.
Try the front holes on the steering knuckles, make sure you turn your epa down too.
Then try 450cst oil in the shocks.
dontfeelcold is offline   Reply With Quote
Old 06-14-2013, 01:02 AM   #4124
cheers,thats what id heard,ive had a set of spec r single holes on for 5 weeks now but still cant feel the difference at wlrc,but they made the rear tighten up at amcc which made the car faster at the sweeper but i do find the rear a little twitchy off power
Old 06-14-2013, 01:21 AM   #4125
daleburr's Avatar
On power
To gain turn-in but reduce exit steering:
- Lay the rear shocks down a hole (or two)
- Thinner rear diff oil
- Stiffer front springs
To gain rear traction:
- Remove some topdeck screws (I remove the inner ones from the main bulkheads)
- Move the rear wing backwards
- Add rear toe-in
Team Xray
RC-Timing Software - http://www.rc-timing.com
Mercedes AMG F1 - http://www.mercedes-amg-f1.com/
daleburr is offline   Reply With Quote
Xray T3 2012 rasta_man Electric On-Road 4220 11-09-2016 01:45 PM
RC10B4/T4 Forum DerekL Electric Off-Road 14331 01-01-2016 02:18 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 08:55 AM
Tags
xray t4
