Old 06-10-2013, 05:15 PM   #4066
yodace's Avatar
R/C Tech Charter Subscriber
Originally Posted by erchn View Post
.4mm, not 4mm. See page 12 of the T4 manual (optional fine tuning).
Ok..
Would increasing rear toe also cause what I Described earlier? Cause I did increase my rear toe
yodace is offline   Reply With Quote
Old 06-10-2013, 06:01 PM   #4067
erchn's Avatar
Originally Posted by yodace View Post
Ok..
More rear toe shouldn't cause overheating of the front tires, if anything it should just cause more heat in the rear tires. I suppose it's possible that more rear toe could kill some corner speed, causing you to add more steering throw, which would generate heat in the front tires if they are scrubbing more.
Serpent ; Desoto Racing ; Team Powers USA ; Reflex Racing ; Bezerk RC
erchn is offline   Reply With Quote
Old 06-10-2013, 06:20 PM   #4068
Kellen Guthrie's Avatar
Originally Posted by Nathan Wilson View Post
Correct if its the wishbone, if its the upper link lowering it evenly inner and outer it actually highers the roll centre so less roll
Nope you got it backwards.
LRP America
Kellen Guthrie is offline   Reply With Quote
Old 06-10-2013, 06:36 PM   #4069
Mugen10's Avatar
Send a message via Yahoo to Mugen10 Send a message via Skype™ to Mugen10
Has anyone tired Art Scrimo aka artwork. At Union City, Ca. setup?
Any input for asphalt med bite/med temp track.
Central Kentucky Racing
Xray T4
Mugen10 is offline   Reply With Quote
Old 06-10-2013, 07:08 PM   #4070
erchn's Avatar
No, but each time I try springs that light I feel like the car is a bit slow to react, and it feels too stuck. That said, the low front roll centers will help the "too stuck" issue. A fellow racer had Art look at this T3 and Art suggested lower front roll centers and it helped quite a bit to get more steering in the car.
I promise this is the last time I'll post this, but here's another option for the same surface.
http://forum.teamxray.com/xform/inde...D=421&setup=t4
Old 06-10-2013, 08:22 PM   #4071
B00t13g's Avatar
http://www.reflexracing.net/RSD-Univ...art_ep_58.html
Closest to XRAY 2.9, but they feel very different on the track.
Damn, still no rates for the 2.5.
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 06-11-2013, 12:19 AM   #4072
Dan
Dan's Avatar
Trader Rating: 45 (100%+)
Ethan, I've been looking at mod setups from Paul and yourself and the setups are drastically different. I'm thinking about trying your setup but do you have any recommendations as far as tweaks to the setup for the slower 17.5 class?
Thanks!
Dan is offline   Reply With Quote
Old 06-11-2013, 08:01 AM   #4073
erchn's Avatar
Thanks!
Hey Dan,
Agreed, the setups vary quite a bit. I think looking at the setups though that some of those differences balance out others. For instance, 2.3 springs up front for Paul but running outside on a two hole arm to gain a bit of stiffness.
The difference that stands out the most, though I don't think is as dramatic as it first seems, is the springs. Running no bar in rear and 1.2 in the front means quite a bit more roll in my car. The harder springs balance that back out, but also match my driving style better, being stiffer in a straight line, as I tend to shoot corner to corner and Paul is a smoother driver so manages the weight transfer better than I. (Well he does it all better than I, but that's one piece :-).
I found the setup I ended up with very easy to drive and very consistent, but still certainly on pace. I'm not sure the setup will work everywhere or for everyone, so.
All that crap said, for 17.5 I think I'd start by trying to free the car up a little bit. I'd probably start with less rear camber, and maybe a short camber link up front. You might also try raising higher roll centers in the rear or lowering the front a bit. I would probably also go down to 1500 or 2000 rear diff oil.
For what it's worth, I found the silver/silver spring combination from RSD to work extremely well earlier in the week, but was a little loose on power, which might be ok in 17.5. If you'd like a setup based on those springs (which are closer to what the team runs in lb./in.), let me know I'll PM you.
Good luck.
Old 06-11-2013, 08:51 AM   #4074
chasingthepack's Avatar
Originally Posted by chasingthepack View Post
am i right in saying that to reduce the amount the car rolls i would lower the links in the middle and the outer? trying to keep them as level as possible in the front and im not sure with the rear?
ok can we try this one again as we have had 3 different opinions and im confused now,thanks
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
Old 06-11-2013, 08:59 AM   #4075
If you lower both (outer and inner) you will get a higher RC
If you lower the outer you will lower your RC
If you lower the inner you will higher your RC
It's the exact same principle front and rear of the car.
Team AME/ORCA
https://www.facebook.com/strawberryrcdesigns
http://www.strawberryrcdesigns.pt/
jorgesimes is offline   Reply With Quote
Old 06-11-2013, 09:03 AM   #4076
thanks,and as dumb as it sounds if i lower the roll center the car rolls less?
Old 06-11-2013, 09:07 AM   #4077
Xpress's Avatar
Lower rc the car will roll more slowly
Raise rc the car will roll more quickly
"Desire is the key to motivation, but it's the determination and commitment to an unrelenting pursuit of laying it down - a commitment to excellence - that will enable you to attain the success you seek to beat ass."
-Espo
Xpress is offline   Reply With Quote
Old 06-11-2013, 09:10 AM   #4078
Sorry it is not a matter of faster or slower roll, but more or less. Of course if you have more roll the car may feel like slower roll, but actually is just rolling more.
Team AME/ORCA
Old 06-11-2013, 09:16 AM   #4079
thanks for explaining that jorge much appreciated
Old 06-11-2013, 11:07 AM   #4080
See jorgesimes post above
Nathan Wilson is offline   Reply With Quote
Xray T3 2012 rasta_man Electric On-Road 4220 11-09-2016 01:45 PM
RC10B4/T4 Forum DerekL Electric Off-Road 14331 01-01-2016 02:18 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 08:55 AM
Tags
xray t4
