Old 06-10-2013, 08:25 AM   #4051
chasingthepack's Avatar
Originally Posted by yodace View Post
Is there anything to change that would Hlp prevent the front tires from overheating when using the front - .75 roll centers? I developed a foward push also at the end of the 8min race anything I could change to prevent that?
how much toe out have you got?you could set it to 0 deg and see if that helps,and if im right a harder spring will work the tyre harder so you could soften the front
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
Old 06-10-2013, 08:29 AM   #4052
am i right in saying that to reduce the amount the car rolls i would lower the links in the middle and the outer? trying to keep them as level as possible in the front and im not sure with the rear?
Old 06-10-2013, 10:31 AM   #4053
Kellen Guthrie's Avatar
Lowering the link but keeping it at the same angle will lower your roll center and increase body roll.
LRP America
Kellen Guthrie is offline   Reply With Quote
Old 06-10-2013, 12:02 PM   #4054
yodace's Avatar
R/C Tech Charter Subscriber
I have .5 toe out
Everything is stock but the -75 roll centers I changed and i liked how much steering it gave the car . Just started to push really bad near the end of the race..
Guess I can put the 0.00 roll centers bk on just dont wanna loose steering ..
yodace is offline   Reply With Quote
Old 06-10-2013, 12:30 PM   #4055
Kwikvdub's Avatar
Trader Rating: 89 (100%+)
Send a message via AIM to Kwikvdub
..... BTW..... What spur gear are you guys using to keep it in the center of the top deck??.....
Thanks!
Alex Valdes
TQRacing / 360 V2 RC Raceway
Kwikvdub is offline   Reply With Quote
Old 06-10-2013, 12:39 PM   #4056
edhchoe's Avatar
Trader Rating: 41 (100%+)
Thanks!
edhchoe is offline   Reply With Quote
Old 06-10-2013, 12:53 PM   #4057
erchn's Avatar
I have .5 toe out
You could try some .4mm under the -.75 blocks and see if that gives you the a compromise.
RCAmerica ; Team Powers USA ; Reflex Racing ; RC≥ RC Crew Chief ; Bezerk RC
erchn is offline   Reply With Quote
Old 06-10-2013, 01:34 PM   #4058
Correct if its the wishbone, if its the upper link lowering it evenly inner and outer it actually highers the roll centre so less roll
Nathan Wilson is offline   Reply With Quote
Old 06-10-2013, 01:42 PM   #4059
TT_Vert's Avatar
Trader Rating: 62 (100%+)
what does this mean?
TT_Vert is offline   Reply With Quote
Old 06-10-2013, 02:41 PM   #4060
its regarding how much roll the car has,to reduce roll you remove the shims from the camber links,less roll in my case allowed the car to roll through the turn faster
Old 06-10-2013, 02:56 PM   #4061
Barry_Hughes's Avatar
no need to be jealous,it wasnt halifax,its aldershot,the sweeper can be tricky as you need to stay as low as possible,if it was steeper it would be better as it chews up the front left in 3 rounds and grinds the motor
http://aldershotmodelcarclub.net/track-parking-pitting/
I will be racing at Aldersholt for the first time in the SRL, looking forward to it
Built it !
Raced it !
Wrecked it !
Barry_Hughes is offline   Reply With Quote
Old 06-10-2013, 05:38 PM   #4062
Mugen10's Avatar
Send a message via Yahoo to Mugen10 Send a message via Skype™ to Mugen10
What are the RSD Red springs close to Xray springs?
Central Kentucky Racing
Xray T4
Mugen10 is offline   Reply With Quote
Old 06-10-2013, 05:40 PM   #4063
erchn's Avatar
http://www.reflexracing.net/RSD-Univ...art_ep_58.html
Closest to XRAY 2.9, but they feel very different on the track.
Old 06-10-2013, 05:41 PM   #4064
yodace's Avatar
Take the -75 roll centers off and but the 0.00
Put the 4mm shims where do have a picture ?
Old 06-10-2013, 05:43 PM   #4065
erchn's Avatar
.4mm, not 4mm. See page 12 of the T4 manual (optional fine tuning).
Xray T3 2012 rasta_man Electric On-Road 4220 11-09-2016 02:45 PM
RC10B4/T4 Forum DerekL Electric Off-Road 14331 01-01-2016 03:18 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 09:55 AM
Tags
xray t4
SEO by vBSEO 3.5.0
