Old 06-01-2013, 11:37 AM   #3901
cwoods34's Avatar
Originally Posted by edhchoe View Post
Where do you guys put the weight? Lead or Fe?
Only put enough weight at the corners to balance the left to right. Any weight still needed to make minimum weight should be added as centerline as possible.
I have 60-70g bolted onto my car to make minimum. I believe my car balanced left to right with just 7g in front of and 14g behind the battery. The rest is centerline between the motor and servo. Depending on your electronics, lining up the ESC and RX with the edge of the chassis should leave plenty of room for bolting on weight and balances nicely.
Stop holding bitterness deep in your bum soul.
cwoods34 is offline   Reply With Quote
Old 06-01-2013, 11:40 AM   #3902
B00t13g's Avatar
Originally Posted by JOE SI View Post
Why do you think the car will drop weight with ORCA packs$ are they lighter?
I use 6000 and 7000 both ORCA and with no weight added to the car I can get it balanced perfect left and right. Obviously a little difference with the 6000 in the car but not enough to add weight since its perfect with the 7000
The orca 6000s are lighter than my 7000 reedys and the orca mod motors are lighter than the speedzone I'm currently using. My stock car will drop weight because I'm going to titanium screws, but might gain some back with the orca 7000s packs.
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 06-01-2013, 01:54 PM   #3903
chasingthepack's Avatar
im sure ive read it somewhere,but has anyone cut the top deck at the front for more flex/steering ?
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
Old 06-01-2013, 07:29 PM   #3904
What's minimum weight? 60-70g seems like alot
JOE SI is offline   Reply With Quote
Old 06-01-2013, 08:11 PM   #3905
edhchoe's Avatar
Trader Rating: 41 (100%+)
VTA needs to weigh 1450g min.
edhchoe is offline   Reply With Quote
Old 06-01-2013, 08:15 PM   #3906
TT_Vert's Avatar
Trader Rating: 70 (100%+)
1550g for vta
TT_Vert is offline   Reply With Quote
Old 06-01-2013, 08:20 PM   #3907
edhchoe's Avatar
Ok. USVTA. 1450g.
Old 06-01-2013, 08:34 PM   #3908
Dan
Dan's Avatar
Trader Rating: 48 (100%+)
USVTA is 1550g still
Dan is offline   Reply With Quote
Old 06-01-2013, 08:35 PM   #3909
edhchoe's Avatar
OK. Scale spec.
Old 06-01-2013, 08:46 PM   #3910
TT_Vert's Avatar
Are you making up your own class now to prove you are right?
Old 06-01-2013, 08:56 PM   #3911
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
The ORCA 6000's are 298 grams and the 7000s are 329 grams.
The TX motors are about 35 grams lighter than a D3.5 or Killshot motor. The idea is for mod to run the TX motor and the 6000 battery. Because you take 35 grams off of each side of the car and keep your balance.
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | APEX Raceway and Hobbies | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 06-01-2013, 11:04 PM   #3912
B00t13g's Avatar
EA
That's the plan, just waiting on you to get the motors in.
Mackenzie Meyercord
Old 06-02-2013, 01:12 AM   #3913
chevtech23's Avatar
We run a class in this area called scale spec that is a hybrid of USGT and VTA rules, with a 1450 min wt. Thats what Ed is referring to. Its a fun mashup of GT and vintage bodies, we run 25.5 on carpet and 21.5 outdoors
chevtech23 is offline   Reply With Quote
Old 06-02-2013, 01:28 AM   #3914
Yeah, this.
-Mike
Old 06-02-2013, 08:12 AM   #3915
rack's Avatar
Trader Rating: 64 (100%+)
So have anybody found that the car pushing on entry. I tried 2.7's springs all the way around that did not help much. I am running the basic asphalt set for now. I need to know the fix for this.
rack is offline   Reply With Quote
RC10B4/T4 Forum DerekL Electric Off-Road 14338 11-18-2017 04:19 PM
Xray T3 2012 rasta_man Electric On-Road 4227 11-14-2017 05:49 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 09:55 AM
Tags
xray t4
