Old 05-28-2013, 01:01 PM   #3826
TT_Vert's Avatar
Trader Rating: 63 (100%+)
Originally Posted by bvoltz View Post
Yep... Diff will give you a little more steering...
Now if only xray diffs weren't so expensive!!
TT_Vert is offline   Reply With Quote
Old 05-28-2013, 01:28 PM   #3827
B00t13g's Avatar
Originally Posted by TT_Vert View Post
Speaking of front diffs. Ive been hearing that a tight diff is better on tight carpet type tracks than a spool. Any opinions on that?
Dave
I disagree, a front diff does work well, but I definitely prefer a spool on carpet. It feels much better to me and lap times are better with a spool for ME.
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 05-28-2013, 01:29 PM   #3828
TT_Vert's Avatar
Are you racing on a small carpet track w/ many 180s?
Dave
Old 05-28-2013, 01:34 PM   #3829
CristianTabush's Avatar
Barry, easy test would be to just try a spool in the front and see if you still have the issue.
I would not say a gear diff is better in any condition. It's different. In super high bite tracks, it can make the car easier to drive, but it won't necessarily mean faster laps. Best thing to do is try them back to back.
I don't think a gear diff gives more steering either. It may give a little more initial turn in, but it tends to wash out as power is applied. Making it act much like a 2WD car under power. In high bite, this makes the car easier and more consistent to drive, however in low to medium grip, it does not allow the car to accelerate fast enough out of the corners. In medium high to high grip is when you will mostly see the benefit of a gear diff.
Also, the spool seems to do better under power in high speed sweeping corners and larger tracks where the gear diff is better for tighter, smaller tracks and under some conditions in large tracks with hairpins.
The common denominator I can say has been grip though. The higher the grip, the better the gear diff works.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 05-28-2013, 01:34 PM   #3830
B00t13g's Avatar
Dave
90x40, I wouldn't say a bunch of 180s, arguably the fastest guy at my home track is running a gear diff and does well with it, but it doesn't fit with me.
Mackenzie Meyercord
Old 05-28-2013, 02:11 PM   #3831
TT_Vert's Avatar
Thanks for the info guys. Same issue I have. I'm about .1 down of the fast guy at my track and I feel it's in the infield with the tight turns he gets me. My lap times are very good when I have enough front traction to traction roll but then there's that pesky occasional traction roll that negates that .1 second I gain w/ more steering. I'm hoping maybe a gear diff would give me that great turn in w/o the traction roll. This is the layout.
http://www.youtube.com/watch?v=ylgXpdoSx54
FYI, my track is 32'x61' and very high traction carpet.
Dave
Old 05-28-2013, 02:23 PM   #3832
bvoltz's Avatar
Trader Rating: 44 (100%+)
Many thanks... I will be giving my driveway a work out tonight (provided it is not raining)...
Thanks for the explanation... I had a different view / results...
Wheeling an Xray T4 and T4 14 using a Ko Propo, powered by EA motors and Speed Passion Speedo, paid for by my wife.
Digi3Dworks - 3D printing for the medical Field.
bvoltz is offline   Reply With Quote
Old 05-28-2013, 04:13 PM   #3833
Dane's Avatar
Trader Rating: 24 (100%+)
Send a message via AIM to Dane Send a message via Skype™ to Dane
Dave
Forget the gear diff, widen your front end to remove traction roll.
"the big secret is to keep practicing and never get discouraged when taking a good beating on the track" - Paul L
Dane is offline   Reply With Quote
Old 05-28-2013, 04:26 PM   #3834
TT_Vert's Avatar
I tried to widen it 1.5mm on each side just as a test and it still traction rolled. I run vta and I wonder if the tire itself was the problem. I went ahead and glued the outermost tread block and sidewall and the traction roll went away. Lost of a bit more steering than I would have liked so I probably should have just tried to glue the sidewall to start but I'm working on getting the steering back.
Dave
Old 05-28-2013, 04:32 PM   #3835
Skiddins's Avatar
Like the others have mentioned.
I've tried a gear diff with 2.5million on carpet and it just felt a bit lazy through the corners.
It felt a little better on a faster asphalt track with a lot of flowing corners, but that was running a 4.5
In stock it just seems to slow me down.
Xray T4'16, T4'14 (Wet Car)
Xray X12 2016
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 05-28-2013, 08:31 PM   #3836
yodace's Avatar
R/C Tech Charter Subscriber
Originally Posted by aussierevo View Post
Take a look at post #1789 on Page 120 and the few post following on that page of this thread and it provides a good solution to this problem. I had the exact same issue with the rear bar and found it was bend. Followed the steps detailed and problem solved.
I checked my sway bar to see if it was bent its perfectly flat. Measured everything per the manual and It still doesn't move either arm up when I try to movethem Separately .
yodace is offline   Reply With Quote
Old 05-28-2013, 09:18 PM   #3837
edhchoe's Avatar
Trader Rating: 41 (100%+)
check if the lengths of the bars connecting the sway bar to the arms are even.
Also, the arms have to move up and down freely. The shafts may be too tight or the ball joints could be too tight.
edhchoe is offline   Reply With Quote
Old 05-28-2013, 11:15 PM   #3838
What exactly do the shock pistons do? Do they slow down damping by stiffening Or softening, due to more or less holes? Or does it just slow it down since more or less oil is passing through?
What I'm trying to say is, would a shock with 4 hole piston and 350 oil be softer than a 3 hole with 350?
JOE SI is offline   Reply With Quote
Old 05-28-2013, 11:51 PM   #3839
Kellen Guthrie's Avatar
Assuming the holes are the same size yes the 4 hole would have less damping and be "softer". The smaller the hole the faster the shock will "pack up" because if the piston is moving fast and the hole is small the fluid will not be able to get through the hole at a sufficient rate.
The area of all the holes combined will give you how much fluid will be able to pass through the holes in the piston (negating the speed the piston is traveling). So lets say you have one piston that has 6 holes and another piston that has three holes. The area of all the holes combined is the same. They will both have the same damping when the piston moves slow. But when the piston is moving fast the 6 hole will give you more damping than the 3 hole since the holes are smaller.
LRP America
Kellen Guthrie is offline   Reply With Quote
Old 05-29-2013, 07:09 AM   #3840
Just making sure since, I feel the T4 has way too much compression with the 4 hole 1.1 set up. The sides and rear of my chassis are taking a beating with the 4hole setup with 2.7 front and 2.5 rear and a ride height of 5.8 rear and 5.4 front
Xray T3 2012 rasta_man Electric On-Road 4220 11-09-2016 02:45 PM
RC10B4/T4 Forum DerekL Electric Off-Road 14331 01-01-2016 03:18 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 09:55 AM
Tags
xray t4
