Old 05-27-2013, 02:32 AM   #3766
Barry_Hughes's Avatar
Originally Posted by Skiddins View Post
If you've had to go that extreme with the rollbars you have another problem.
NOBODY runs without a rear roll bar as it effects the transition of the car.
Post your setup so others can have a look and make sure you fill in as much information as possible.
Skiddins
Have to disagree Damien, I ran without the rear roll bar at Eastbourne in the SRL in my last final leg as I was struggling with set up - set the fastest lap and apart from a couple of bad laps (bit of unfortunate maneuvers by other drivers as I was getting past them ) would have won that leg.
Wish I had taken it off a bit earlier
Built it !
Raced it !
Wrecked it !
Barry_Hughes is offline   Reply With Quote
Old 05-27-2013, 04:18 AM   #3767
Skiddins's Avatar
Interesting. I have thinner roll bars in case needed, but I never take them off completely as when I used to do that (a few years ago now) it felt good and did increase rear grip, my lap times suffered as it seemed to be worse on parts of the tracks with changes in direction.
There was always something else that could be changed to give me a better result.
I have never removed them since
Skiddins
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 05-27-2013, 07:46 AM   #3768
CristianTabush's Avatar
Originally Posted by cyba888 View Post
guys I am getting understeer and would like to decrease it a little bit more. Also want the car to have better turn in on slower corners.
my current setup on asphalt is below
530CST shock oil front and rear
2.5 springs all around
shocks laid all the way down front and rear
rear diff 2000 oil
stock sway bars and everything else is from stock setup.
I have all the option sway bars and springs to test out just not sure which setting I should touch first
I agree that your oil is a bit thick. Which piston are you running? To get more steering I would start by adding 1mm of of shims to your steering rack for a total of 2mm. After that, go to the short camber links front and rear. Finally shorten your wheelbase in the front and rear of the car by 1mm (bring the front arms back and the rear arms forward).
Sound familiar Damian?
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 05-27-2013, 07:58 AM   #3769
Skiddins
I wanted to try thinner bars but only had thicker ones for the rear, no-one else running the T4 had any thinner, so decided to remove it completely.
Funny though at Eastbourne the times improved considerably
Normally like you I always run roll bars.
Built it !
Raced it !
Wrecked it !
Old 05-27-2013, 08:23 AM   #3770
cyba888's Avatar
Thanks for the tips guys. What do you mean by "go to the short camber links front and rear"
This is the track I run at
http://www.youtube.com/watch?v=NXba8Nl1Y7Q
2014 and 2015 BD7 Black Series, Yokomo RPX ESC- Yokomo 4.5T Motor
Yokomo B-MAX4 III Factory Team Kit, Muchmore ESC- LRP 6.5T Motor
Mugen MBX7R Eco- 2200 KV Motor
Futaba 4PX
cyba888 is offline   Reply With Quote
Old 05-27-2013, 08:46 AM   #3771
The length of your upper links. Run the shortest links available.
Old 05-27-2013, 09:24 AM   #3772
cyba888's Avatar
You mean remove all the shims under the camber links?
Futaba 4PX
Old 05-27-2013, 09:27 AM   #3773
Skiddins's Avatar
At Eastbourne i went thinner on front roll bar, 1.3mm, but left the rear at 1.2mm (my default is 1.3mm at the rear) for my fastest laps
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 05-27-2013, 09:29 AM   #3774
Skiddins's Avatar
Hmm, there is something familiar about it
Have you found the extra shims on ackerman help through slower corners, or just in general?
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 05-27-2013, 09:40 AM   #3775
edhchoe's Avatar
Trader Rating: 41 (100%+)
Why do you refuse to put thicker oil in the rear diff?
If you look on Xray's own forum the top drivers all run with thicker oil.
I run on carpet & ashpalt, when I first had my T4 I ran with kit oil in the rear diff changed it to 2000 and would NEVER go back to 700, the car is so much better with the thicker oil.
Never ever say no to any change advised, try it, if you don't like the difference it makes go back, but it is always worth trying something
My reasoning is... Thicker oil will give more even power to both rear wheels upon acceleration and make the rear end loose. Thinner diff oil will give more power to the wheel with less grip and the rear end will have less contribution than the front end upon acceleration which will make the car more stable coming out of a turn.
If my problem is understeering I would change my diff oil to thicker one.
edhchoe is offline   Reply With Quote
Old 05-27-2013, 09:42 AM   #3776
erchn's Avatar
Skiddins
I had great luck with no rear bar and a very light front bar (thanks Paul L. for the loaner) at the Reedy Race this past weekend. The car was very easy to drive and felt really consistent corner to corner. The key was a relatively stiff set of springs from RSD. My setup is here.
Serpent ; Desoto Racing ; Team Powers USA ; Reflex Racing ; Bezerk RC
erchn is offline   Reply With Quote
Old 05-27-2013, 09:43 AM   #3777
Skiddins's Avatar
No, they mean the hole in the upper clamps that the link screws into.
Use hole 1, not 2 or 3.
If you look at a proper Xray setup sheet you'll see what I mean.
Skiddins
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 05-27-2013, 10:00 AM   #3778
cyba888's Avatar
got it thanks
Futaba 4PX
Old 05-27-2013, 10:01 AM   #3779
Skiddins's Avatar
Why such a high rear link (compared with the front)?
Did you try any slightly softer sprtings like the RSD Silver's or Grren's?
What did you think?
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 05-27-2013, 10:01 AM   #3780
edhchoe's Avatar
Xray T3 2012 rasta_man Electric On-Road 4220 11-09-2016 01:45 PM
RC10B4/T4 Forum DerekL Electric Off-Road 14331 01-01-2016 02:18 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 08:55 AM
Tags
xray t4
