Old 05-26-2013, 01:30 PM   #3751
edhchoe's Avatar
Trader Rating: 41 (100%+)
Yes. Oversteer on exit. And lift throttle oversteer on high speed mid turn of decreasing radius.
edhchoe is offline   Reply With Quote
Old 05-26-2013, 01:33 PM   #3752
Skiddins's Avatar
Originally Posted by edhchoe View Post
I looked at the set up sheets posted by the winning people and what I noticed is some people have stiffer rear end than the front which seems crazy to me. This lead me to think that the fast people will be fast no matter how the car handles and they will adjust their driving style to make the best out of the given setup.
Do any of these guys also run the T4?
Front shocks hole 2, rear hole 3
Put kit sway bars back on.
Try 0mm on rear upper inner link and possible 2mm at the front
Kit rear springs
1.5 front camber.
1000 or even 2000 in diff
I take it you meant to put 64degF for the air temp
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 05-26-2013, 01:51 PM   #3753
That will increase the rear toe. Is that what you are recommending?
3.0 -> 3.5 ?
That is correct.
Should only take you a minute to change.
I will even offer a money back guarantee!
Josh Hohnstein is offline   Reply With Quote
Old 05-26-2013, 01:58 PM   #3754
edhchoe's Avatar
I will try the upper link inner shim change for different camber gains, and increase rear toe.
However, I refuse to try thicker oil in my rear diff and put the 2.3-2.6 spring back on the rear.
If the car handles better, I will let you guys know.
Thank you.
Old 05-26-2013, 02:22 PM   #3755
chasingthepack's Avatar
Thank you.
a word of advice,if skiddins is giving you advice then you really should listen,after seeing his car today in action (he won both a finals by a long way)he really knows his way around a t4
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
Old 05-26-2013, 02:36 PM   #3756
edhchoe's Avatar
I understand. But he would probably also beat me with my car even if I drove his car.
Old 05-26-2013, 03:42 PM   #3757
Skiddins's Avatar
Hmm, Thanks
But we can only go on info given, especially when we haven't raced at your track.
Out of interest, why are you so against the progressive rears and thicker oil?
Oh, and what additive and are you using warmers?
This is the track, correct?;
+ YouTube Video
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 05-26-2013, 05:12 PM   #3758
edhchoe's Avatar
Yes, that looks somewhat familiar.
I need all the traction I can get at this point and using thicker diff oil and putting back the stock springs (2.3-2.6) which are stiffer than what I have now (2.3) will only take away the rear traction.
I use tire tweak and Protek true grip medium and no tire warmers.
Old 05-26-2013, 06:38 PM   #3759
Softer front end will give more steering in low traction situations especially when running anti-dive. Running anti dive will always be better with softer springs since when suspension is fully compressed it'll be flat. If its flat already the when fully compressed it'll have some rake making less weight on rear wheels..
I asked the same question recently when I saw softer front springs in front
JOE SI is offline   Reply With Quote
Old 05-26-2013, 06:42 PM   #3760
I'm with you dude!!
He definitely knows what he's talking about. Even though he hasn't driven on my track, which will always help when asking advice, I always read what he has to say.
No I'm not stalkinLOL
Old 05-26-2013, 07:45 PM   #3761
edhchoe's Avatar
My custom battery holder. I used two tamiya motor plates and aluminum posts from old corally.
Old 05-26-2013, 09:11 PM   #3762
RCknight's Avatar
If anyone is interested selling my new in the box T4 for firm $450 shipped. PM for pics. Thanks
RCknight is offline   Reply With Quote
Old 05-26-2013, 11:10 PM   #3763
cyba888's Avatar
guys I am getting understeer and would like to decrease it a little bit more. Also want the car to have better turn in on slower corners.
my current setup on asphalt is below
530CST shock oil front and rear
2.5 springs all around
shocks laid all the way down front and rear
rear diff 2000 oil
stock sway bars and everything else is from stock setup.
I have all the option sway bars and springs to test out just not sure which setting I should touch first
2014 and 2015 BD7 Black Series, Yokomo RPX ESC- Yokomo 4.5T Motor
Yokomo B-MAX4 III Factory Team Kit, Muchmore ESC- LRP 6.5T Motor
Mugen MBX7R Eco- 2200 KV Motor
Futaba 4PX
cyba888 is offline   Reply With Quote
Old 05-27-2013, 01:50 AM   #3764
Dan
Dan's Avatar
Trader Rating: 48 (100%+)
Too thick on the shock oil. Stay in the 350-400CST range. Some people have tried 450CST, but start lower first...
Go back to the stock rear gear oil or 1000WT in the rear...
If you go back to the fully stock setup and oils, even with 2.5 springs all around, you should have PLENTY of steering.
This is all assuming you are on the right tires at your local track.
Dan is offline   Reply With Quote
Old 05-27-2013, 03:27 AM   #3765
Barry_Hughes's Avatar
Thank you.
Why do you refuse to put thicker oil in the rear diff?
If you look on Xray's own forum the top drivers all run with thicker oil.
I run on carpet & ashpalt, when I first had my T4 I ran with kit oil in the rear diff changed it to 2000 and would NEVER go back to 700, the car is so much better with the thicker oil.
Never ever say no to any change advised, try it, if you don't like the difference it makes go back, but it is always worth trying something
Built it !
Raced it !
Wrecked it !
Barry_Hughes is offline   Reply With Quote
RC10B4/T4 Forum DerekL Electric Off-Road 14338 11-18-2017 04:19 PM
Xray T3 2012 rasta_man Electric On-Road 4227 11-14-2017 05:49 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 09:55 AM
Tags
xray t4
