Old 05-25-2013, 02:23 PM   #3736
Default grip roll
Originally Posted by TT_Vert View Post
Here is the front tire I must use. It's 26mm wide and 65.8mm in diameter. Here is a pic of the tire that kept traction rolling. It seems all vta tires wear the inside. I only have 1 deg of negative camber.
My weight is around 1550g
pm sent
matt prigmore is offline   Reply With Quote
Old 05-25-2013, 02:44 PM   #3737
Skiddins's Avatar
Originally Posted by edhchoe View Post
My T4 has been naughty and made me frustrated. It is finally handling good for the first time. I took the rear bar off and increased front droop and softened rear dampers by using 1.2mm pistons.
2.3 Rear springs and 1.5mm front bar.
If you've had to go that extreme with the rollbars you have another problem.
NOBODY runs without a rear roll bar as it effects the transition of the car.
Post your setup so others can have a look and make sure you fill in as much information as possible.
Skiddins
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 05-25-2013, 03:42 PM   #3738
Originally Posted by Dan-Dan Team-X View Post
Hi Guys Does Anyone No The Size Difference Of The DS Motosports Xray T4 Towers Compared To The Std T4 Towers Isit Only 1mm Increase On The Shock Mounting Points??
Lycan is offline   Reply With Quote
Old 05-25-2013, 04:00 PM   #3739
chasingthepack's Avatar
just a quick one,if i move the front camber link to the shortest hole from middle what can i expect to happen?
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
Old 05-25-2013, 05:29 PM   #3740
cwoods34's Avatar
TQ'd, won, and set a new personal best at the track today. I've basically been running EA's Snowbirds setup but with a front spool and some minor fluid changes. I feel like it is the best 17.5/stock carpet setup to begin with. If you need a starting point USE IT. The setup is also good in mod with just a spring and droop change. We've also had great luck with the setup in VTA with 2.9/2.7 springs.
In other words, there's a reason it won Snowbirds
Stop holding bitterness deep in your bum soul.
cwoods34 is offline   Reply With Quote
Old 05-25-2013, 05:58 PM   #3741
Just asked the same exact question today. In a way it controls the speed of the roll left to right/right to left, or the amount of roll in a corner. With shorter links it will finish its roll faster than with long links.
Today I put thicker bars on my car 1.5 front,1.3 rear and had my best run yet.
Usually around 27-28 laps fastest lap 9.6.
I didn't break my fast lap but consistently hit my fast lap and avg around 10 seconds with 30 laps, TQ was 32 5.06 or something.
In all the change made a huge difference for my driving style and would definitely recommend to try it
JOE SI is offline   Reply With Quote
Old 05-25-2013, 11:54 PM   #3742
edhchoe's Avatar
Trader Rating: 41 (100%+)
Skiddins
Here you go. I started with Basic Set up for asphalt as recommended by Xray.
Then I kept making adjustments...
I marked the wrong pistons... I have the four hole pistons.
edhchoe is offline   Reply With Quote
Old 05-26-2013, 12:39 AM   #3743
B00t13g's Avatar
Hmmm, I've never tried droop settings like that.
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 05-26-2013, 12:42 AM   #3744
pcar951's Avatar
Trader Rating: 19 (100%+)
We all hate traction rolling! Like skiddins said, you gotta put the rear sway bar back on for sure. Here's a few things to do: Go back to the 1.4 or even 1.3 front bar. Go mid or even long upper links (to reduce camber gain) and 2mm inner shims. Reduce front static camber to 1.0. Lay your front shocks down to the second hole from the inside. Reduce rear droop to 5 or more (to reduce forward weight transfer on entry). I'd probably go with 2.5 rear springs. Go back to 1.1 - 4 hole pistons and 350 all around. You could even increase the front track width .75 with shims or option hexes. Lower your body and ride height as much as legally possible.
Basically, to avoid grip roll you have to let the car roll more freely in the corners. I know it sounds backwards but, many of us have gone through this and it's the only solution. Hope this helps.
Jim Chapman
PM Hobbycraft | RCAmerica | Xray | Hudy | Reds Racing
pcar951 is offline   Reply With Quote
Old 05-26-2013, 12:45 AM   #3745
edhchoe's Avatar
I am not the guy with traction rolling problem. My car was too loose. Oversteering coming out of a turn.
Old 05-26-2013, 01:01 AM   #3746
pcar951's Avatar
Right, TT Vert was the traction rolling guy. Well hopefully it helps someone...
Jim Chapman
Old 05-26-2013, 12:09 PM   #3747
edhchoe's Avatar
I looked at the set up sheets posted by the winning people and what I noticed is some people have stiffer rear end than the front which seems crazy to me. This lead me to think that the fast people will be fast no matter how the car handles and they will adjust their driving style to make the best out of the given setup.
Old 05-26-2013, 12:25 PM   #3748
Use the 1.2 rear toe shim instead of the .75 shim, if that locks the rear end in to much you can go to a 1mm shim.
Josh Hohnstein is offline   Reply With Quote
Old 05-26-2013, 01:16 PM   #3749
edhchoe's Avatar
That will increase the rear toe. Is that what you are recommending?
3.0 -> 3.5 ?
Old 05-26-2013, 01:25 PM   #3750
Skiddins's Avatar
It looks like you probably had an issue with loose on power, but in trying to solve it you've gone too far.
Is it as if when you come of of a corner, you start to straighten up and apply power and the car almost wants to keep turning?
Xray X12 2018
Xray X1'16
RCDisco.co.uk
RC10B4/T4 Forum DerekL Electric Off-Road 14338 11-18-2017 04:19 PM
Xray T3 2012 rasta_man Electric On-Road 4227 11-14-2017 05:49 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 09:55 AM
Tags
xray t4
