Old 05-23-2013, 09:41 PM   #3721
TT_Vert's Avatar
Trader Rating: 68 (100%+)
Originally Posted by trigger View Post
Changing diff oil will have little affect for traction rolling. Roll center adjustments and shock oil will definitely affect traction rolling.
What is your opinion on addressing traction roll into the corner?
TT_Vert is offline   Reply With Quote
Old 05-24-2013, 01:24 AM   #3722
Skiddins's Avatar
Originally Posted by regets ama View Post
can I get a starting point for Mod TC FDR, 4.5 Thunderpower, 20 degrees timing, no boost, similar to the recent outdoor electric roar in florida
I kept getting told by guys here to gear at 8.3 and adjust boost etc.
Ended up on 8.0 but still lacked a little top speed. Was told to try 25deg on the motor.
Skiddins
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is online now   Reply With Quote
Old 05-24-2013, 09:12 PM   #3723
Trader Rating: 9 (80%+)
Hi Guys Does Anyone No The Size Difference Of The DS Motosports Xray T4 Towers Compared To The Std T4 Towers Isit Only 1mm Increase On The Shock Mounting Points??
Dan-Dan Team-X is offline   Reply With Quote
Old 05-24-2013, 09:42 PM   #3724
defcone's Avatar
Trader Rating: 15 (100%+)
I got some made which were 2mm higher and I can run normal springs.
defcone is offline   Reply With Quote
Old 05-24-2013, 10:16 PM   #3725
TT_Vert's Avatar
Wanted to update you guys on my traction roll issue. Tried everything mentioned here one at a time and nothing resolved the traction roll. I tried going from a 2.7 front spring to a 2.5, I tried to reduce droop, lowered ride height a bit, tried a longer camber link, tried playing w/ the roll center blocks, etc. I even prepped the rear tire and just cleaned front w/o any sauce and it still rolled. Unfortunately when it didn't roll my lap times were the best. I ended up going to a new vta tire and resolved the traction roll. However I don't have as much steering and am about .3 off my lap times w/ them. It seems if I do get the traction to get my best lap times I'm on the verge of traction rolling. It's quite frustrating to know that the setup that seems fastest to me isn't consistent. I reduced rear droop from 5 to 6 and that helped keep the rear inside tire on the ground at least. I'd really love to be able to get the steering that nets me fast laps w/o this traction roll issue.
Dave
Old 05-25-2013, 02:03 AM   #3726
Default traction roll
Dave
Hi, could post a picture of the tyre or post a link for me to to look at. also what is the diameter of the vta tyre.
In the vta class, what is the minimum weight for the cars.
matt prigmore is offline   Reply With Quote
Old 05-25-2013, 02:20 AM   #3727
chasingthepack's Avatar
Dave
just curious but what camber are you running
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
Old 05-25-2013, 05:13 AM   #3728
cwoods34's Avatar
Dave
Put a little expo in the steering and turn your servo speed down on the radio if possible (to 80%). Did you thicken the shock oils?
Stop holding bitterness deep in your bum soul.
cwoods34 is offline   Reply With Quote
Old 05-25-2013, 06:53 AM   #3729
DS Motorsport's Avatar
Hi,
Unfortunately I can't give you the exact number because that would make it extremely easy for another company to copy the raised shocktowers.
The DS Motorsport shocktowers raise the upper shock mounting point by the minimal amount required to run full length springs with big diameter tires and still hit a 5mm rideheight.
For the ones who wanted to order our parts but were shocked by the shipping costs, from monday on the shipping costs will come down around 50%. We are currently busy implementing the new shipping options into the shop software.Also a new batch of T4 towers is on it's way.
We're also working on a high-flex chassis for the T4.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 05-25-2013, 08:52 AM   #3730
TT_Vert's Avatar
is everyone using the rsd front bumper or is there a better alternative to the flimsy stock one?
Dave
Old 05-25-2013, 09:43 AM   #3731
TT_Vert's Avatar
Here is the front tire I must use. It's 26mm wide and 65.8mm in diameter. Here is a pic of the tire that kept traction rolling. It seems all vta tires wear the inside. I only have 1 deg of negative camber.
My weight is around 1550g
Old 05-25-2013, 10:20 AM   #3732
B00t13g's Avatar
Dave
Either the rsd or the cso.
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 05-25-2013, 10:59 AM   #3733
it seems to me and i may be wrong but with only 1 deg of camber ,taking a small amount of slop into consideration,you could be hooking up on the side wall hence the traction roll,try 1.5/2 deg,how much do those tyres deform?
Old 05-25-2013, 11:54 AM   #3734
TT_Vert's Avatar
Originally Posted by chasingthepack View Post
it seems to me and i may be wrong but with only 1 deg of. Always thoughtcamber ,taking a small amount of slop into consideration,you could be hooking up on thethe for side wall hence the traction roll,try 1.5/2 deg,how much do those tyres deform?
I started at 1.5 but went to 1 after I saw that inside tire wear I went to 1 degree. i always thought that adding negative camber increased traction to that side of the car up to a point. The tire deforms quite a bit m
Dave
Old 05-25-2013, 01:10 PM   #3735
edhchoe's Avatar
Trader Rating: 41 (100%+)
My T4 has been naughty and made me frustrated. It is finally handling good for the first time. I took the rear bar off and increased front droop and softened rear dampers by using 1.2mm pistons.
2.3 Rear springs and 1.5mm front bar.
edhchoe is offline   Reply With Quote
Xray T3 2012 rasta_man Electric On-Road 4220 11-09-2016 01:45 PM
RC10B4/T4 Forum DerekL Electric Off-Road 14331 01-01-2016 02:18 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 08:55 AM
Tags
xray t4
