Old 05-22-2013, 10:16 PM   #3691
TT_Vert's Avatar
Trader Rating: 69 (100%+)
Guys, what would your input be for a traction roll issue I've got on a high traction carpet? If I only sauce the inside half of the tire I don't traction roll but I'm about .2-.3 seconds off my pace due to slight push I get in the infield. I've got the carpet setup on it except I have the +.75 rear arm mounts. I did this to try to get the car to rotate more while using 1/2 front tire sauce but I'm still a bit off the pace. I was thinking of maybe going to a 2000 cst diff oil from the 1000 to get it to rotate more and then half the front tire being sauced would be ok. I also reduced rear droop from 5 to 6 as I noticed I was lifting the rear inside tire when cornering. That helped a tad and the rear tire seems to stay planted but I'd like to resolve this traction roll problem. This is in vta at a 1550g race weight.
Thanks much
Dave
TT_Vert is offline   Reply With Quote
Old 05-22-2013, 10:51 PM   #3692
RCknight's Avatar
If anyone is interested I have my new in the box T4 for sale. Asking $475. PM for pics if interested.
RCknight is offline   Reply With Quote
Old 05-22-2013, 11:08 PM   #3693
VTEC? I thought that was something Honda had lol.
momofx is offline   Reply With Quote
Old 05-22-2013, 11:11 PM   #3694
Dan
Dan's Avatar
Trader Rating: 47 (100%+)
Thanks much
Dave
What are your shock oil/spring settings?
Dan is offline   Reply With Quote
Old 05-22-2013, 11:24 PM   #3695
pcar951's Avatar
Trader Rating: 19 (100%+)
Originally Posted by grippgoat View Post
Is it a similar effect to having the rear belt tighter than the front? I can definitely feel that.
-Mike
Yup, very similar.
Jim Chapman
PM Hobbycraft | RCAmerica | Xray | Hudy | Reds Racing
pcar951 is offline   Reply With Quote
Old 05-22-2013, 11:32 PM   #3696
cwoods34's Avatar
Thanks much
Dave
Going to 425cst in the front shocks helped me. I can't get the car to traction roll regardless of the spring or body I use.
Stop holding bitterness deep in your bum soul.
cwoods34 is offline   Reply With Quote
Old 05-23-2013, 12:59 AM   #3697
Xpress's Avatar
Thanks much
Dave
post your setup
Are you having traction roll problems at corner entry, thru the corner, or off the corner?
"Desire is the key to motivation, but it's the determination and commitment to an unrelenting pursuit of laying it down - a commitment to excellence - that will enable you to attain the success you seek to beat ass."
-Espo
Xpress is offline   Reply With Quote
Old 05-23-2013, 01:18 AM   #3698
chasingthepack's Avatar
Originally Posted by JOE SI View Post
What kind of traction is at this track? I ask because I have almost that setup for carpet except the mid roll center in the rear. For asphalt I change the F/F to low RC for a little dive and 1mm shim on the rear inner link (not 2mm) for a low traction track
it starts out with low med,then as it gets cleaned itll get to a high medium,thats why i was going to use the stiffer springs by round 3
but its quite bumpy,i dont use any shims on the rear inner links just 4mm on the upright
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
Old 05-23-2013, 01:55 AM   #3699
Send a message via Skype™ to martinskarin
Check droop, ride height and shocks. Just sounds weird being loose on corner exit and push on fast corners since most of the time they're both on throttle.
Originally Posted by niemand View Post
Hey guys,
I am totally lost setup-wise. I hope you can help me.
Im running on a small and rather tight asphalt track with low to medium traction.
My setup:
Base asphalt exept for
1mm rollcenter spacers on the bulkheads instead of 2 mm (front and rear)
rear shocks in hole 3
0,5 degrees of arm sweep front
Protoform Mazda Speed 6 body (LTCR already ordered)
Ride Re32
17,5t boosted or 10,5t
My problem:
I just dont have enough traction.
Loose rear end on corner exit, massive understeer through fast corners, slight understeer in medium speed corners and massive understeer in slow corners entry to middle.
I also drove a Tamiya teamdriver's car and his 417 v5 was just that much better so its not the trackconditions in general. He didn't even use the raceberry conversion kit
Tried a lot of stuff already, nothing really worked. So please help me. Any ideas are welcome
Regards,
David
Try my aoc setup. It was a super technical track. Adjust rear difr oil after grip level.
If you still have problems try make the car softer and make it roll more.
http://forum.teamxray.com/xform/inde...D=361&setup=t4
I ran the 17.5 blinky class that race.
Martin Skärin
Shanghai
Roche
Destiny
PROAMPS
martinskarin is offline   Reply With Quote
Old 05-23-2013, 04:31 AM   #3700
I was only saying because my track starts really low traction and I have 400 in my shocks with 2.7front and 2.5 rear then it comes up to be around med/med,high and I switch to 450 with same springs or progressive 2.5-2.8 up front and it is great. If I want it less aggressive (the way I like it and my girls too) ill just switch the fr/fr back to mid RC all around maybe little more or little less camber but usually at 1.5-2 front and same for rear with 3 toe in and 1-1.5 toe out
JOE SI is offline   Reply With Quote
Old 05-23-2013, 12:57 PM   #3701
TT_Vert's Avatar
Sorry guys. Traction roll entering the corner. I have the kit 350cst shock oil. 2.7 front and 2.3-2.6 rear springs. I have attached my setup but it is the kit carpet setup w/ a few changes. Mainly rear diff height, rear diff oil, rear roll center blocks and a bit less rear droop. Saucing entire front tire nets me much faster laps but I get quick traction rolls on occasion so I've been saucing only 1/2 of the front tire and eating the .1-.2 a lap knowing I can at least drive the car hard w/o traction roll. I also tried 3/4 front tire sauce and it still traction rolled.
Dave
Old 05-23-2013, 01:28 PM   #3702
bvoltz's Avatar
Trader Rating: 44 (100%+)
Dave
You can try the following:
1 - lower your ride height from 5.5 to 5.2
2 - lengthen your camber links 1 hole, currently you are in the shortest hole. Increase the length.
and / or remove 1mm from the rear outside camber link / remove 1mm from the front inside (on the bulk head) camber link.
3 - Reduce your spring rate 1 step in the front (dummy down the response rate of the car)
Wheeling an Xray T4 and T4 14 using a Ko Propo, powered by EA motors and Speed Passion Speedo, paid for by my wife.
Digi3Dworks - 3D printing for the medical Field.
bvoltz is offline   Reply With Quote
Old 05-23-2013, 01:36 PM   #3703
TT_Vert's Avatar
1. Lower front/rear ride height or just front? I have a bit of a bumpy track which is why I was at 5.5 but I can try to lower.
2. Is this in refence to just the front camber link?
3. So you recommend going softer in front? Wouldn't that just cause more roll or is your thinking that it'll roll further before it traction rolls?
Thanks for the input/clarification!!
Old 05-23-2013, 01:37 PM   #3704
Skiddins's Avatar
Dave
You also said you were using the +.75 rear roll centres, but the setup sheet say's -.75's
Have you tried a softer front spring or even the progressives?
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 05-23-2013, 01:46 PM   #3705
TT_Vert's Avatar
My mistake, fixed the PDF. It is +.75
I've not tried a softer spring as I thought more roll would perpetuate the problem. Perhaps I'm looking at this wrong. What I was trying to do was free up the rear a bit so it'd rotate at corner entry a bit rather than want to traction roll. Raised rear roll center w/ arms to do that. not sure if that was the best way.
Dave
Xray T3 2012 rasta_man Electric On-Road 4227 11-14-2017 05:49 PM
RC10B4/T4 Forum DerekL Electric Off-Road 14337 11-10-2017 08:19 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 09:55 AM
Tags
xray t4
