Old 05-22-2013, 04:27 AM   #3676
Skiddins's Avatar
Originally Posted by Jamison R View Post
Anybody running the killshot motor in the T4 for stock class? If so, care to post a pic of mounting it? Apparently some are having an issue.
Most motors have 6 mounting holes, all evenly spaced around the motor.
The Killshot appears to also have 6 holes, but most are more spread out, with 4 of them almost side by side, almost like old brushed motors.
I should think the position of the holes is not compatible with the T4 motor mount. There are a few other cars with similar mounts.
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 05-22-2013, 04:34 AM   #3677
Skiddins's Avatar
Originally Posted by chasingthepack View Post
thats not good,if the oil leaked surely it would be noticable,ie dirt sticking to them?
if i can pick your brains for a mo,
im setting up my car for this weekend at wlrc and im starting with
shocks 4 x 1.1 450cst front and rear
3degrees rear toe in
2.7 front 2.5 rear
1.5 camber all round
roll center mid front short rear
droop f 5 r 4
rh 5.5 f 6 r
anything else you might add to that?
have you done the hagberg mod to the t4?
i have another set of shocks that im going to try which are cso
front 2.8 cso spring 3 hole 1.1 400 cst
rear 2.7 xray spring 3 hole 1.1 400cst
just so i can teach myself a bit more about shock settings and what they do,still a grey area for me,thanks in advance
rich
No need for the hagberg T3'12 mod as the T4 has a narrower rear track by design.
I've been running 350 oil in the shocks.
Pretty much it for the rest, but try experimenting with springs etc. if you have any.
Skiddins
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 05-22-2013, 05:04 AM   #3678
NR
NR's Avatar
Trader Rating: 52 (100%+)
Originally Posted by dontfeelcold View Post
I'm in the same boat here, exactly the same problems in all the same areas. The slower the speed, the worse the corner exit oversteer is. The car looks like its diffing out, loses all forward drive and spins inner rear.
I will admit I haven't tried 2k rear diff oil on a medium size track yet. Only small tracks. This makes the understeer worse and does nothing for the on power oversteer. Setup helps with drivability a bit, and I can drive around the problem, but it does nothing for improving the laptimes.
Things I have found to help are:
1mm shims under the inner ball studs
1.3mm bars front and rear (need to try 1.4 front and rear)
5.4 front droop
4.4 rear droop
(any less droop ie 6f 5r = diffing out)
Foam bits in the shock caps
This makes the car driveable, not fast. I still get left behind on tight corners.
I will either try a 2mm chassis or get a new car and get my friend to build it. I swear that guy has magic fingers. Everytime he builds a new car they are fast. Everytime I build a new car, slow
Not again Josh!! it's all in your head
NR is offline   Reply With Quote
Old 05-22-2013, 05:23 AM   #3679
chasingthepack's Avatar
Skiddins
i have 2.9's down to 2.5's plus the progressives
when i was there last i only had 2.7 f and 2.3/2.6 r
hence why it wouldnt steer
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
Old 05-22-2013, 06:57 AM   #3680
cyba888's Avatar
For those who have Spec-R C.V. Universal Swing Shaft do you also have a lot of play when you twist the wheel forward and back? Not sure if this is normal or not...
2014 and 2015 BD7 Black Series, Yokomo RPX ESC- Yokomo 4.5T Motor
Yokomo B-MAX4 III Factory Team Kit, Muchmore ESC- LRP 6.5T Motor
Mugen MBX7R Eco- 2200 KV Motor
Futaba 4PX
cyba888 is offline   Reply With Quote
Old 05-22-2013, 08:53 AM   #3681
Skiddins's Avatar
Although I don't use Spec-R, there is always a small amount of play.
There is some between the dog bone pins and the spool outdrive, then a little in each pin joint where the dog bone meets the axle.
Skiddins
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 05-22-2013, 10:16 AM   #3682
cyba888's Avatar
Any other company make ecs drive shaft besides xray and arrowmax?
Futaba 4PX
Old 05-22-2013, 10:20 AM   #3683
defcone's Avatar
Trader Rating: 15 (100%+)
This is not normal and is probably because your shafts are old and have developed play or your spool cups have notches in them.
defcone is offline   Reply With Quote
Old 05-22-2013, 10:30 AM   #3684
B00t13g's Avatar
Rsd makes some good ones.
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 05-22-2013, 03:03 PM   #3685
pcar951's Avatar
Trader Rating: 19 (100%+)
I ran the Spec R DCJ's in my T312's, for sure they're a little sloppy compared to the Xray ECS's. You've probably got some wear in the cross pins and sleeve's, and if you've got wear in the drive cups... you got play. Parts are cheap for the Spec R's and a set of Xray drive cups is $10, problem solved.
Jim Chapman
PM Hobbycraft | RCAmerica | Xray | Hudy | Reds Racing
pcar951 is offline   Reply With Quote
Old 05-22-2013, 05:44 PM   #3686
What's wrong with play in the DCJs? I.e. how does it cause a loss of performance / different feel on track, such that I'd be motivated to replace worn parts?
-Mike
Old 05-22-2013, 05:49 PM   #3687
B00t13g's Avatar
I don't like slop or play in things, up to a certain point. The x ray and rsd dcjs seem to wear to a point and stop. I don't like the composite drive cups, they wear a bit and for me they start binding. I run the hudy spring steel cups in stock and mod.
Mackenzie Meyercord
Old 05-22-2013, 07:38 PM   #3688
pcar951's Avatar
-Mike
If you've got extra play in the front, when you get on or off the throttle, the rear wheels will react on the surface first. Even though it's just a split second, you can feel it. You're usually transitioning power either entering or exiting corners, so it's important to have all the wheels driving as evenly as possible.
Jim Chapman
Old 05-22-2013, 07:41 PM   #3689
Is it a similar effect to having the rear belt tighter than the front? I can definitely feel that.
-Mike
Old 05-22-2013, 08:19 PM   #3690
2.7 front 2.5 rear
droop f 5 r 4
rh 5.5 f 6 r
rear 2.7 xray spring 3 hole 1.1 400cst wiyth a cso 2.6 to try as well
rich
What kind of traction is at this track? I ask because I have almost that setup for carpet except the mid roll center in the rear. For asphalt I change the F/F to low RC for a little dive and 1mm shim on the rear inner link (not 2mm) for a low traction track
JOE SI is offline   Reply With Quote
Xray T3 2012 rasta_man Electric On-Road 4220 11-09-2016 01:45 PM
RC10B4/T4 Forum DerekL Electric Off-Road 14331 01-01-2016 02:18 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 08:55 AM
Tags
xray t4
