Old 05-11-2013, 02:24 PM   #3526
B00t13g's Avatar
I like your pliers, but I would have to remove them to measure length and that doesn't look like it would be very quick.
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 05-11-2013, 02:48 PM   #3527
Team Grid RC's Avatar
Originally Posted by PROMODVETTE View Post
That looks like it would take forever unscrewing/screwing it together. I use http://www.integy.com/st_prod.html?p...5#.UY6gR7Vf3Lc. Work great and no marring of shock shafts.
Yes, it does take 10 seconds to remove or install each screw.
Less effort than keeping the pliers squeezed during the whole time you are trying to thread the end on the shaft. Ask anyone that has 1/8 off road shocks, they are the most difficult to thread on even with pliers.
www.GridRC.com
Team Grid RC is offline   Reply With Quote
Old 05-11-2013, 04:54 PM   #3528
TT_Vert's Avatar
Trader Rating: 69 (100%+)
Hey can anyone running vta share a setup with me? I'm new to the Xray and would like a good starting point. I'm right at VTA weight (What a pita) but I'm not sure where to start. I've go the kit setup on it now but I'm wondering if there are any opinions on changes to make pre: practice. I'm coming from a TC5 that I had pretty dialed but after driving a friends T3 `12 I fell in love w/ the handling of this thing. Driving a Lamborshini vs. driving a cavalier on the autobahn.
Dave
TT_Vert is offline   Reply With Quote
Old 05-11-2013, 07:24 PM   #3529
Where are the holes for lipo go.
drifttt01 is offline   Reply With Quote
Old 05-11-2013, 07:49 PM   #3530
veecee's Avatar
Trader Rating: 34 (100%+)
Pliers are fine. What you also need is a wide rubber band. Put the rubber band on and give it a bit of tension so it's taut. Then pliers are good to go. This gives you great grip without scratching the shock shaft.
SMOKEM --- XPRESS --- MONTECH --- SRT
veecee is offline   Reply With Quote
Old 05-11-2013, 08:23 PM   #3531
cyba888's Avatar
Anyone try the rsd linear springs or battery hold down system?
2014 and 2015 BD7 Black Series, Yokomo RPX ESC- Yokomo 4.5T Motor
Yokomo B-MAX4 III Factory Team Kit, Muchmore ESC- LRP 6.5T Motor
Mugen MBX7R Eco- 2200 KV Motor
Futaba 4PX
cyba888 is offline   Reply With Quote
Old 05-11-2013, 11:32 PM   #3532
Johnny Than's Avatar
Trader Rating: 91 (100%+)
I have not try the linear springs yet, but I love the RSD Progressive springs. makes the car transition through the corners faster than the stock springs. As for the battery hold down... I probably can't live without it now! Makes my life so much easier. No more messing with tapes. it's a must have!
Johnny Than is offline   Reply With Quote
Old 05-12-2013, 02:29 AM   #3533
cyba888's Avatar
Thanks for the info I seem to drive better with linear springs. BTW that motor fan looks heavy duty
Futaba 4PX
Old 05-12-2013, 02:50 AM   #3534
B00t13g's Avatar
Wiring looks awesome!!
Mackenzie Meyercord
Old 05-12-2013, 03:29 AM   #3535
redthunder's Avatar
Trader Rating: 15 (100%+)
Originally Posted by B00t13g View Post
Has anyone found shock pliers that work well on the t4?
guy at my track had a blue set of these in his pit box:
link
they come in orange...match the car
i also had the same problem with my shock pliers, too thick to get the shock ends on...
redthunder is offline   Reply With Quote
Old 05-12-2013, 04:14 AM   #3536
Hi all!
Just got my T4 and it's wonderful. However I noticed that when i run the car in air and turn the steering the front belt starts jumping around. I'm sure the steering arms aren't touching the belt. Any ideas anyone?
Cheers!
Rainmakerr is offline   Reply With Quote
Old 05-12-2013, 05:13 AM   #3537
hotrod1933's Avatar
Default belts jumping
if you don't have ecs front driveshaft this is normal.
should only be doing at or near full lock on steering.
the std driveshafts bind a bit ecs stop this.
XRAY T4-15 -- nbhc.com -- powerhouse performance -- sma.org
hotrod1933 is offline   Reply With Quote
Old 05-12-2013, 05:54 AM   #3538
Thanks hotrod!
I noticed if i take the wheels off it does not do it, or not as much.
Might get the ECS drive shafts though they are a bit on the expensive side :P
Old 05-12-2013, 06:11 AM   #3539
hotrod1933's Avatar
Default ecs
depends on class you run.
i am running 21.5 blinky and another guy hasn't got ecs in his car and is just as quick.
would depend on layout as well tight track with full lock cnrs will make more difference. other brands like rsd / reflex and spec r are cheaper.
couple of pages back someone gave rsd a good rap.
Old 05-12-2013, 07:28 AM   #3540
Do you know of any website that sells them?
I only found Yeah Racing ones on ebay. Think they're good or?
RC10B4/T4 Forum DerekL Electric Off-Road 14338 Yesterday 04:19 PM
Xray T3 2012 rasta_man Electric On-Road 4227 11-14-2017 05:49 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 09:55 AM
Tags
xray t4
