Old 05-10-2013, 05:40 PM   #3511
Skiddins's Avatar
Originally Posted by Tekin Prodigy View Post
Can someone elaberate on their personal experience running a softer sway bar on the front of the T4, or even t3, like a 1.3 instead of a 1.4 standard bar. Im looking for more steering and trying to figure out if this is the route I want to go. Thank you
Yes, it can give more steering.
But, it can cause the car to be unstable if the back end isn't planted well.
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 05-10-2013, 06:10 PM   #3512
Ron Goetter's Avatar
Trader Rating: 17 (95%+)
Send a message via AIM to Ron Goetter
Generally when changing sway bars it will effect the opposite end of the car.
Think of it this way.
If you are running equal bars both front and rear the roll of the car is the same allowing for equal cross weight distribution.
If you thicken just the front bar up you make the front of the car roll flatter and also allows the cross weight to transfer more to the inside rear wheel allowing it to stay more in contact with the track which in turn gives you more rear traction VIA the inside rear tire.
Now if you go to a thinner front bar it allows the front of the car to roll more. Which in turn lessens the amount of cross weight transfer to the inside rear tire and in turn taking rear traction away. This makes it seem like you have more steering due to the loss of rear traction hence the reason you should not go to a softer front bar if your car is on the edge of being too free.
Also if you do this and you do not feel these changes or it feels like a thinner front bar gave you more steering you are probably on too soft a front spring and the car is using the bar as a spring rate which IMO is bad.
All this being said I generally find setups with big front bars and thin rear bars easier to drive constantly.
The Goat... B-Mainer Fo' life
-Awesomatix USA-ROCHE USA-Team CRC-ORCA-SIDE PIECE RACING-TEAM DAK-EA Motorsports-VP Fuel-Trains and Lanes-CR Graphics-TQ Wire-Horsham RC-rugburn anyone?
Shut up and Race!!!!
Ron Goetter is offline   Reply With Quote
Old 05-10-2013, 08:20 PM   #3513
-jacob-'s Avatar
Hi everyone,
it has been a back and fort between a TC6.1 and XRAY T4.
i was super close on getting a TC6.1 because of parts availability in the track.
parts are def available for TC6.1 but im a bit worried being a new driver, im going to crash a lot more. i did not want to spend time disassembling my car and replacing parts all the time when i could be racing or just practicing.
after how many parts replaced i probably could have bought a T4.
everyones reviews defenitely helped. it seemed that almost every review about XRAY'S is the car being very durable.
really excited it should be here on WED.
F**k im broke
just spent over 800 after the coupon code
www.teameamotorsports.com
www.seattlercracers.com
-jacob- is offline   Reply With Quote
Old 05-10-2013, 09:04 PM   #3514
B00t13g's Avatar
Has anyone found shock pliers that work well on the t4?
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 05-10-2013, 09:11 PM   #3515
Mugen10's Avatar
Send a message via Yahoo to Mugen10 Send a message via Skype™ to Mugen10
Just grab the last thread with any pliers cutting edge. Just be careful not to put pressure on the polished part.
Central Kentucky Racing
Xray T4
Mugen10 is offline   Reply With Quote
Old 05-10-2013, 09:54 PM   #3516
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
I think RSD is working on a pretty sweet solution for shock pliers.
Old 05-11-2013, 03:06 AM   #3517
nerdling's Avatar
Got any details on these? Part number, vendor?
--XRAY--NOSRAM--PROTOFORM--MUCHMORE--
www.teamxray.com -- www.hudy.net -- www.hobbyexpress.com.au
nerdling is offline   Reply With Quote
Old 05-11-2013, 03:52 AM   #3518
dontfeelcold's Avatar
Trader Rating: 21 (100%+)
There are heaps of shock pliers that work on the T4 shocks. I think mine are Jet.
dontfeelcold is offline   Reply With Quote
Old 05-11-2013, 03:53 AM   #3519
Grabbing shocks shafts with pliers is nasty.
Old 05-11-2013, 03:56 AM   #3520
Originally Posted by Josh-n-ya View Post
Is this like a temp fix? Also will this create another tweak? I have the same issue on an 12 that I just thought was normal.
If you want to get anal you could make a jig for straightening and measuring the bar tweak so it goes straight in Would be simple.
It creates no extra tweak. Swaybar tweak is nasty, especially on a stiff bar. I regularly check droop and swaybar tweak and my car always goes in a straight line under hard acceleration and hard braking.
Old 05-11-2013, 04:50 AM   #3521
Skiddins's Avatar
I think he means with the 'cutter' part of the pliers.
TO get the ideal length of the shock you need around 1mm of the thread showing anyway.
Skiddins
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 05-11-2013, 06:42 AM   #3522
chasingthepack's Avatar
i may have been setting my car up in the wrong sequence,can some one exlain the correct way and order to set up the cars droop and ride height,or a run down of how you get your car race ready,cheers guys
i have been setting droop then ride height?
im usure of the over ride height method
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
Old 05-11-2013, 08:01 AM   #3523
bvoltz's Avatar
Trader Rating: 44 (100%+)
Here is a video that will show you how to do the Over ride height method...
Link
Wheeling an Xray T4 and T4 14 using a Ko Propo, powered by EA motors and Speed Passion Speedo, paid for by my wife.
Digi3Dworks - 3D printing for the medical Field.
bvoltz is offline   Reply With Quote
Old 05-11-2013, 09:33 AM   #3524
Team Grid RC's Avatar
Agree. We don't use pliers either.
That is why we came up with a special tool for shock shafts.
http://www.redrc.net/2012/03/team-gr...ck-shaft-tool/
www.GridRC.com
Team Grid RC is offline   Reply With Quote
Old 05-11-2013, 01:49 PM   #3525
Trader Rating: 57 (100%+)
That looks like it would take forever unscrewing/screwing it together. I use http://www.integy.com/st_prod.html?p...5#.UY6gR7Vf3Lc. Work great and no marring of shock shafts.
PROMODVETTE is offline   Reply With Quote
Xray T3 2012 rasta_man Electric On-Road 4227 11-14-2017 05:49 PM
RC10B4/T4 Forum DerekL Electric Off-Road 14337 11-10-2017 08:19 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 09:55 AM
Tags
xray t4
