Old 05-09-2013, 05:16 PM   #3496
dontfeelcold's Avatar
Trader Rating: 21 (100%+)
The tiniest tweak in the bar can throw it out alot on the car.
Make sure its as even as possible as this can tweak the car on the track in a big way.
dontfeelcold is offline   Reply With Quote
Old 05-09-2013, 05:54 PM   #3497
Josh-n-ya's Avatar
Trader Rating: 72 (100%+)
Originally Posted by IIGQ4U View Post
Raise or lower the ball cups that support the anti roll bar.
Raise or lower one side by turning the ball cups until both sides react simultaneously.
Is this like a temp fix? Also will this create another tweak? I have the same issue on an 12 that I just thought was normal.
Josh-n-ya is offline   Reply With Quote
Old 05-09-2013, 08:15 PM   #3498
Originally Posted by rcguyfpr View Post
Question about the anti-roll bar. No matter what I do to the mounting set screws or adjusting the set screws by the end of the bar, left and right just have uneven reaction. All arms go up&down freely. However, when lift up left, right will come up; but life up right, left only moves a little (shocks off).
Front 1.4 and rear 1.2 bar, similar case. How do I fix it? thanks!
I had the same problem. You would think the ARB mounts would bother be same when screwed tight since they can only go so far.. I put a .5 shim so I know they are the same and they work fine
JOE SI is offline   Reply With Quote
Old 05-09-2013, 10:28 PM   #3499
TT_Vert's Avatar
Trader Rating: 68 (100%+)
I have the same issue. Bar ends are equal everything is free and bar is straight but left arm won't raise. When I have less weight on the arm (no hub carrier) they bolt go up. There is no binding either.
Dave
TT_Vert is offline   Reply With Quote
Old 05-10-2013, 02:00 AM   #3500
scoyle's Avatar
Originally Posted by Skiddins View Post
Also, put the roll bars on a flat surface like a piece of glass and check that they are flat and not twisted.
I would second this as I checked mine last night - front was perfect but the rear would not raise the right hand side. Checked the roll bar on a piece of glass and it was not flat... twisting it slightly (not much!) made it flat and when I put it back on it worked as expected.
Quick question related to this - how much do people tighten the grub screws on the roll bar mounts?
Web Site: http://www.rcracingreviews.net
Sponsors: Schumacher UK | XFactoryUK | Zen Racing
scoyle is offline   Reply With Quote
Old 05-10-2013, 02:05 AM   #3501
daleburr's Avatar
You need to de-tweak the roll-bars with the hubs and upper links removed. And before de-tweaking, make sure the wishbones drop freely under their own weight, and that the roll-bars are free in the holders.
You use the roll-bar links to set the tweak. Lengthen one side as necessary so that the wishbones rise after the same amount of movement. I do this using a ride height gauge under the wishbone. E.g. I may have to lift the RH wishbone 5mm before the LH one starts to lift up. Make sure it's the same the other way around, and adjust the roll-bar links if not.
If the roll-bar tweak has changed when you reattach the hubs and upper links, then you've got some binding somewhere.
Team Xray
RC-Timing Software - http://www.rc-timing.com
Mercedes AMG F1 - http://www.mercedes-amg-f1.com/
daleburr is offline   Reply With Quote
Old 05-10-2013, 03:17 AM   #3502
Skiddins's Avatar
I assume you're talking about the two grub screws on the bulkhead mounts, not the links.
Disconnect the links so they are only attached at the bulkheads. loosen the grub screws off so the roll bar drops under it's own weight. Slowly tighten the grub screw on one side until it stops the bar dropping under it's own weight. Now back it out 1/4 turn.
Repeat for the other side.
You want the bars to be loose, but not so much that they rattle around and have lots of movement for and aft or up and down.
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 05-10-2013, 05:01 AM   #3503
scoyle's Avatar
Yes, on the bulkhead and great explanation, thanks.
Old 05-10-2013, 05:41 AM   #3504
chasingthepack's Avatar
skiddins,have you run 3 hole pistons with a heavier oil?just curious if on a flat track if this would be better or just stick with the 4 holes?
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
Old 05-10-2013, 05:59 AM   #3505
Skiddins's Avatar
I've only ever run 4hole 1.1mm on the T4
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 05-10-2013, 03:22 PM   #3506
Tekin Prodigy's Avatar
Trader Rating: 55 (100%+)
Can someone elaberate on their personal experience running a softer sway bar on the front of the T4, or even t3, like a 1.3 instead of a 1.4 standard bar. Im looking for more steering and trying to figure out if this is the route I want to go. Thank you
Xray T4
Tekin Prodigy is offline   Reply With Quote
Old 05-10-2013, 03:59 PM   #3507
edhchoe's Avatar
Trader Rating: 41 (100%+)
That's the first thing you should do according to the xray table.
Then soften spring and damper, lower the roll center, etc.
edhchoe is offline   Reply With Quote
Old 05-10-2013, 04:13 PM   #3508
B00t13g's Avatar
Where did you find that chart?
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 05-10-2013, 04:14 PM   #3509
B00t13g's Avatar
http://www.teamxray.com/teamxray/sho...p?file_id=2531
Found it for anyone interested.
Mackenzie Meyercord
Old 05-10-2013, 04:15 PM   #3510
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
The used to include it in the older kits.
Xray T3 2012 rasta_man Electric On-Road 4220 11-09-2016 01:45 PM
RC10B4/T4 Forum DerekL Electric Off-Road 14331 01-01-2016 02:18 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 08:55 AM
Tags
xray t4
