Xray T4 '13
#3466
cheers joe,i cant wait to get back to the track to see if the changes ive made will equal faster lap times,im very positive that it will now be quicker and easier to drive,however did you add more caster or just stick with the 4 degree blocks?
on set up i cant really make out exactly how much caster i have im going to take a guess at 2 degrees ???
#3467
To check tweak I measure droop and ride height. Then I do the center lift to make sure the tires go up at the same time. Make adjustment by loosening or tightening the spring collar to get both wheels to lift up at the same time. After I get everything perfect I notice for example front left is 0.2mm higher than the front right. Is this normal? Does the ride height need to be exactly the same from left to right?
#3468
This should get you very close as you're automatically compensating for weight distribution etc.
Skiddins
#3469
#3470
I popped along to the Nationals yesterday at Cotswolds,the car did look very good,and well done on the wins in the finals,
I was a bit dissapointed how the pit tent looked a bit "closed shop" and all it missed was two bodyguards out the front,it did look smart thought lol
it was the only car i didnt get to have a look at to help me choose my next car,
With the wind coming from the trackside in the direction of their gazebo, they had the sides up to shelter them.
#3475
Norcal Hobbies - Using Losi 32.5WT all around, think its something like 400cst equivalent. 2.7 spring front, 2.5 spring rear. Running 50% rebound. Actually did not like how 100% felt.
Car is super planted and a slint hint of push, but very stable.
#3476
Thanks for the tip guys ...
How many use the lift method or the hudy tweak station with the bubble?
I have 4 scales but find it difficult to use as the numbers are sometimes off
#3477
Note: traction was super high.
#3479
Sorry Ed, got plans this weekend. How come Sundays are bad for you now?
