Old 05-04-2013, 11:21 AM   #3421
Originally Posted by chasingthepack View Post
after being very dissapointed in the amount of steering lock i was getting(about 75%) from the standard servo saver /savox servo set up and after reading what someone else had tried i came up with my rendition of that mod,i now have full lock which should help on the tighter tracks,i drilled a small hole nearer to the bearing and although i havent had a chance to test(english weather) it looks very promising,i originally had epa at 120 and still couldnt get the amount of lock i wanted/needed hence this mod,im now down to 80 epa and the lock to lock is faster,
so whats your opinion on this?
Your servo arm is way to short if I where you I used the servo link from the kit.
This is a good and thrustfull device and give full lock if required.
eded1 is offline   Reply With Quote
Old 05-04-2013, 12:26 PM   #3422
trigger's Avatar
I agree. The servo horn is a bit on the short side. That's probably why you have so little steering throw.
Minh Nguyen
[Maclan Racing][Xpert]
trigger is offline   Reply With Quote
Old 05-04-2013, 12:54 PM   #3423
chasingthepack's Avatar
i was using the kit servo saver hence why i have done this,
its no shorter than the standard servo saver,identical length,after testing today its a huge improvement over stock,i even dropped the d/r to 82%
its nice to know that at a tighter track itll help me get through the infield faster,the main reason for doing this was the savox servo im using is slow,im now only using 50 degrees of servo throw to achieve the same full lock,but steering response is faster,i wasnt checking lap times so dont know if its faster per lap or not,ill find that out at tomorrows meeting
i timed a 17.5 guy and he was posting 16.3
i had a run around with him and im sure i was 1.5 sec faster
the top guys are getting around in 14.4,still looks promising for tomorrow
plus i was on 32ry's when 28r's would have been the better choice
my best lap was a 15.11 with a tc6 2 meetings ago,i only managed a 15.3 with the t4 at the last meeting but i was slower down the straight,thats now sorted
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
Old 05-04-2013, 07:05 PM   #3424
RCknight's Avatar
What I wish is that Xray would make shorter steering mount posts so we could just flip the whole steering rack. That way we could mount the servo link in the middle like the BD. Lower CG and no steering stop. This always made more sense to me. Anyone out that can CNC some short aluminum or titanium posts?
RCknight is offline   Reply With Quote
Old 05-04-2013, 07:12 PM   #3425
RCknight's Avatar
thanks I'll give it a try.
Originally Posted by JOE SI View Post
I used on carpet 2.7 front and 2.5 rear with 450 Xray oil all around, sometimes I'd use 2.9 up front and progressive 2.3-2.6 rear, both combos with 450 oil and 1.1 4 hole piston because 350 to me just felt way too soft.. Most combos with springs worked good but those 2 suited me for carpet...
The car just always seems to work and have more traction than needed (maybe its just me) and sometimes feels too planted but always fast and easy to drive..
The spool rips out of the corner, my only experience with a diff up front is with nitro cars and even then I used a spool, that's why I say start at 300k and go up but the guy a few posts back says start at 1million or its useless.. IMHO if its that hard I'd use a spool
Old 05-05-2013, 10:10 AM   #3426
well what can i say,much faster today,as i said my best lap was a 15.30,today i blitzed it with a 14.69 in the 2nd a final,the car got faster all day as well as me,i made a few small changes which got me 6th in the a final,1st final i dropped to 8th,i put a 2mm shim behind the shock cap and managed 4th in the second final,for about 4 mins i was in second but a quick roll saw me in 3rd and half a lap from the end i saw an orange car and thought it was the leader and let him through to later find out he was in fourth,so i could have made 3rd,still very happy with the outcome,roll on the next meeting
Old 05-05-2013, 11:54 AM   #3427
It is another way of aproach, and with your explanation it can work in the right way.
thanks
Old 05-05-2013, 12:05 PM   #3428
Barry_Hughes's Avatar
Default Min/Max no of teeth
Does anyone know the min & max number of teeth that you can use on the T4 with 48 dp gears?
Max appears to be 118 but minimum?
Built it !
Raced it !
Wrecked it !
Barry_Hughes is offline   Reply With Quote
Old 05-05-2013, 12:13 PM   #3429
118 would be 64 dp = 118/38 or 100/18
48dp would be 87/34 or 69/12
this is from the xray fdr sheet
Old 05-05-2013, 12:55 PM   #3430
Anything larger than a 114t 64p sticks out below the bottom of the chassis.
Lycan is offline   Reply With Quote
Old 05-05-2013, 03:06 PM   #3431
Skiddins's Avatar
Believe the max with 48dp is 119.
I ran an 80t spur with 19 pinion today, but it does depend on the 'chanfer on the motor etc as it was close to the top deck.
I think the minimum tooth count is 99t
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 05-05-2013, 06:33 PM   #3432
edhchoe's Avatar
Trader Rating: 41 (100%+)
For the asphalt setup, I got to the point where I had to take the rear swaybar off to take care of the corner exit oversteer issue. It is almost there but I am still feeling the rear end trying to come out. It is just not suiting my driving style. So I am going to put 1.2 mm hole pistons in the rear dampers to soften the back and stand up the front shocks until I can order a stiffer front sway bar.
edhchoe is offline   Reply With Quote
Old 05-05-2013, 06:48 PM   #3433
jhautz's Avatar
Trader Rating: 84 (100%+)
I have 48P 78/40 on my car right now and I don't think I can get another tooth on it.
While we are talking about 48P gears... Anyone know where I can get a spur gear smaller than 78T in 48P? I wanted to go up a tooth or 2 today but couldn't and the 78T spur was the smallest spur I found. I really dont want to switch to 64P since I have all kinds of 48P pinion gears that I use on my offroad cars too.
jhautz is offline   Reply With Quote
Old 05-05-2013, 07:01 PM   #3434
dontfeelcold's Avatar
Trader Rating: 21 (100%+)
What diff oil are you running?
dontfeelcold is offline   Reply With Quote
Old 05-05-2013, 07:04 PM   #3435
edhchoe's Avatar
I was having the same dilemma but I don't have many 48p gears anyway, so I bought 64p gears. You have more options with 64p...
stock per manual. really soft and smooth. is it 700 cst?
Xray T3 2012 rasta_man Electric On-Road 4220 11-09-2016 01:45 PM
RC10B4/T4 Forum DerekL Electric Off-Road 14331 01-01-2016 02:18 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 08:55 AM
Tags
xray t4
