Old 04-26-2013, 01:55 AM   #3301
Skiddins's Avatar
Originally Posted by SourDieselX View Post
Hey everyone, I've been eye balling the Xray t4 for the last week, I'm just returning to the TC scene as it has been a long time since I last ran TC, I've heard that this was a really good car to go with and the car right out of the box is just incredible, can someone help clue me in and help me make the right decision.
Out of the box it's a great car, then it's easy to tune to what you want.
Skiddins
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 04-26-2013, 02:48 AM   #3302
I've been having a little trouble with my shocks.. When I set the droop at 5 or more (6 highest I've ever gone) it feels like the front of the car in very springy when I push down on the car to settle the shocks and not smooth like the rear ( feels like one of those cheap RTR cars).. If I loosen the droop screw a little it starts to feel the way it should, I went back to screw being 2mm between the bottom of the arm and chassis like it says in the manual and the same thing.. Can it be that I'm setting it with the ride height to high or is it the order that I'm setting up the car
JOE SI is offline   Reply With Quote
Old 04-26-2013, 03:03 AM   #3303
what ride height are you running?
Smartypants is offline   Reply With Quote
Old 04-26-2013, 03:26 AM   #3304
defcone's Avatar
Trader Rating: 15 (100%+)
Where are you measuring droop?
defcone is offline   Reply With Quote
Old 04-26-2013, 03:29 AM   #3305
5-5.2 or 5 front and rear never higher than 5.5 I feel like I'm setting the droop or down stops with the shock collars too low should turn them tighter to the top or lower the ride height before setting it or what order should I make changes
Old 04-26-2013, 03:51 AM   #3306
Under the screw that keep the pin in up front and under the arm in the rear.
It happened to me before and just started over and it was fine but just was thinking I was doing something wrong, I was messing with it just now cause it was bothering me and its fine..
All I did was redo the droop and set camber to 1.5 and it dropped the car .5 and its fine, I guess it had positive camber since I went to the shortest links while messing with it the other day but haven't ran it since so didn't even check the camber but when I did it lowered the car.. I always put a different setup at home so I don't have to do it at the track and if it doesn't work for me I have the time to go back to where it was before
Old 04-26-2013, 07:05 AM   #3307
Josh-n-ya's Avatar
Trader Rating: 72 (100%+)
Originally Posted by erchn View Post
Thanks!
Your supposed to measure from under the arms only! If you measure from C-hubs or anywhere else droop will be way off and thats why it seems tight!
Josh-n-ya is offline   Reply With Quote
Old 04-26-2013, 09:03 AM   #3308
Originally Posted by Josh-n-ya View Post
Thanks!
Ok that makes sense, that's probably why 6 felt like there was no up travel when there should be at least 1-2mm..
Can someone post a pic where to measure from? When you get a chance, thanks
Old 04-26-2013, 09:27 AM   #3309
edhchoe's Avatar
Trader Rating: 41 (100%+)
http://www.renoradiocontrol.com/foru...ead.php?tid=95
edhchoe is offline   Reply With Quote
Old 04-26-2013, 09:30 AM   #3310
Xray T4 for sale
Msg me for details
yunowill is offline   Reply With Quote
Old 04-26-2013, 10:08 AM   #3311
Skiddins's Avatar
Different type of gauge, but the same idea;
And when you measure ride height, do it under both sides of the chassis near to where the droop screws are.
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 04-26-2013, 02:59 PM   #3312
Trader Rating: 54 (100%+)
What is a good gear combo for 17.5 blinky on a medium to large track? I had the t3 and remember some gear combos didn't fit
Jamison R is offline   Reply With Quote
Old 04-26-2013, 03:17 PM   #3313
Dan
Dan's Avatar
Trader Rating: 45 (100%+)
Edit
Dan is offline   Reply With Quote
Old 04-26-2013, 03:49 PM   #3314
hanulec's Avatar
Trader Rating: 24 (100%+)
Happy to hear u are getting back into it.
Get a 96t spur...
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 04-27-2013, 03:39 AM   #3315
Get a 96t spur...
Gotta get ready for our ROAR region 2 event. And I'm not missing Vegas so I'm back in.thanks Mike
Xray T3 2012 rasta_man Electric On-Road 4220 11-09-2016 01:45 PM
RC10B4/T4 Forum DerekL Electric Off-Road 14331 01-01-2016 02:18 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 08:55 AM
Tags
xray t4
