Old 04-12-2013, 09:02 PM   #3226
Tried 2.7 front and 2.5 rear with 500 and it was awesome and also tried 2.9 front and 2.5-2.8 rear 350 oil and it was even better
JOE SI is offline   Reply With Quote
Old 04-13-2013, 04:33 AM   #3227
Skiddins's Avatar
Try 2.7 front and rear with both oils and see what that does for your lap times.
I started last night with a setup I ran outdoors at the weekend just to see what it was like, just OK, but a bit loose.
At one point I kept everything the same, including springs, but just changed the oil from 350 to 450, and within a couple of laps I was 0.2s per lap faster. The thicker oil just seems to make the car a bit easier to drive.
Skiddins
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 04-13-2013, 01:24 PM   #3228
cwoods34's Avatar
Skiddins
We've been trying some things out to "flatten" the car out in stock. 2.7/2.5 with 350-400wt oil has been good to start with. I tried 1.5/1.3 swaybars last weekend and it helped a little. I forgot to order some 2.9s for this weekend, so I took some Associated blues (roughly the same lb/in rate) and cut them to fit. I plan to get the 2.9s and also order Serpent black and grey springs as they should fit. (this is on med/hi bite carpet)
Stop holding bitterness deep in your bum soul.
cwoods34 is offline   Reply With Quote
Old 04-13-2013, 01:33 PM   #3229
mac853's Avatar
Interesting!
Aplus parts for T4:
http://www.a-plusrc.com/index.php/pr...ts/x-ray/t3-t4
mac853 is offline   Reply With Quote
Old 04-13-2013, 03:01 PM   #3230
Skiddins
Which pistons do you use? I'm using 1.1 4 hole and think if I go to 700 the car will still feel soft but not too soft...
I have 2 full sets of shocks, ill try 2.7's all around with 350 and 500 tat tomorrow's race..
I'm by far not the best driver as I crash a little more than the faster guys, I'm only racing electric since around Xmas time... Just really happy I decided to go xray instead of something else, that being said the fastest lap last night was 8.9 and my fastest was 9.2 and the week before couldn't break 10 seconds
Old 04-13-2013, 03:03 PM   #3231
Serpent springs from the new shorter shocks?
Old 04-13-2013, 03:24 PM   #3232
cwoods34's Avatar
Yes, for the S411/Eryx. Their electric TC springs have always been short and a bit wider than other springs, but for the newest car they shortened the shock body to match!
I'm going to start at AE blue front/2.7 rear, 425wt all around, and 4x1.1 front/4x1.2 rear pistons. I found a swaybar that measures at 1.45, so I'll try that up front. The 1.3 on the back worked great so I'm leaving it for now.
Old 04-14-2013, 02:21 AM   #3233
ChadB.'s Avatar
Trader Rating: 21 (100%+)
Can someone tell me the total length of the T4 shock?
Chad Burdick
*Mugen Seiki*Flashpoint Racing Products*9th Annual Timezone Grand Prix July 13th-16th 2017*Unique Air Design*TimezoneRacing*RoseCityScaleRacers* Daves RC Track
ChadB. is offline   Reply With Quote
Old 04-14-2013, 05:02 AM   #3234
Trader Rating: 38 (100%+)
Selling my Xray T4 NIB with Sanwa/airtronics 94647 low profile NEW. 127 oz/.09 speed. 518-495-0703.
Previous username: MBUCK
noworries is offline   Reply With Quote
Old 04-14-2013, 10:00 AM   #3235
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
I saw that someone suggested 9 mm gap between the top of the shock eyelet and the lower shock cap. When I got the shock assembled with that measurement, it was a little under 57 mm, so I just set all mine to 57 mm. HTH
AWD
Old 04-14-2013, 10:42 AM   #3236
Is it better to have a tighter or looser rear belt on asphalt in general? Also, considering the possibility of little stones getting in between the belt and gear diff?
Xray T4 2015 /Team Orion R10.1/Scorpion RS-3420 4.5T/RSxone10/Sanwa M12:rx-471
Xray T4 2014 /LRP Flow Worksteam/LRP X20 4.5T/RSxone10/Sanwa M12:rx-472
Xray XB4 /LRP Flow/LRP X20 6.5T/Savox 1251MG/Sanwa M12:rx-471
Durango DEX410v4 /Tekin RSX/Tekin RL 6.5/Savox 1251MG /Sanwa M12:rx-471
rafyel is offline   Reply With Quote
Old 04-14-2013, 10:45 AM   #3237
B00t13g's Avatar
AWD
9mm for me. Haven't measured total length.
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 04-14-2013, 04:50 PM   #3238
That's what it says in the instructions 9mm from top of the ball end to the bottom off the cap where the O-ring is...
What's the difference if the dff is up or down?
It just makes it easier to adjust belt tension if I do it on top
Old 04-14-2013, 05:14 PM   #3239
cwoods34's Avatar
A friend had some 2.9s available, so today I ran 2.9 425wt front/ 2.7 350wt rear. I also had medium camber links front and read. I tried both a Mazdaspeed and LTCR...... The Mazda was incredibly smooth and consistent but I set the fastest laps with the LTCR.
After going with a "stiffer dampening" setup, I'd say the car was the best it's ever been in stock. I was on Sweep32s most of the day, but they got a little tired in the main. The setup worked so well that I'm going to test it in mod, except with Jacos and probably the Mazda.
I tried this setup with both a gear diff and spool.... I personally preferred the spool but ran the same laptimes with both.
My friend ran a similar setup except with slightly stiffer springs (Reflex), but I can't remember which exactly. He is much less aggressive than I am, so despite the springs and gear diff he ran identical times.... He rolls the turns and barely uses handbrake, so those two differences compared to mine suited his driving style well.
Old 04-14-2013, 05:18 PM   #3240
I noticed today that the metal ball that the lower shock mounts to is very tight and doesn't pivot properly. I checked the T4 build manual and it says to have the shiney side away from the metal ball ??? is this right ? TBH I tried it both ways round and its still tight. Ive never had this problem with any xray before. Any ideas
XRAY T4 Hobbywing V3 Sanwa
FLAT OUT is offline   Reply With Quote
Xray T3 2012 rasta_man Electric On-Road 4220 11-09-2016 01:45 PM
RC10B4/T4 Forum DerekL Electric Off-Road 14331 01-01-2016 02:18 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 08:55 AM
Tags
xray t4
