Old 03-29-2013, 06:07 AM   #3091
Skiddins's Avatar
Originally Posted by Nathan Wilson View Post
you seem to always prefer the 1mm inner front and 0mm inner rear camber link positions, whys this have tried running them higher? what difference does it make?
Put simply, when I lower the links, I get more grip.
The latest setup I ran 0.5mm on the inside rear with 4.5mm on the outside, this seemed slightly better still.
But the rear link is getting a bit too close to the wheel for my liking, might be able to get 5mm at the rear provided the wheels aren't too soft.
Skiddins
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 03-30-2013, 04:05 AM   #3092
sell682's Avatar
Trader Rating: 81 (99%+)
Duplicate post sorry
sell682 is offline   Reply With Quote
Old 03-30-2013, 04:16 AM   #3093
sell682's Avatar
Originally Posted by j.d.roost View Post
Something is either binding or put together wrong.
I run the same springs/droop and it takes me about 4 turns to get to 5mm.
While the car is loaded (battery ect) sit it on a level surface and back out the droop screws. If the front comes up...you found your issue.
If your using droop blocks you need to be checking under the corner of the a arm...not under the knuckle/chub.
If this does not work pull the shocks and check for pin binding.
What do you mean by, you found your problem if front comes ? What would that problem be? Also you have a pic of where to check droop at the front? I have the same issue. Greatly appreciated.
Old 03-30-2013, 04:46 AM   #3094
j.d.roost's Avatar
Trader Rating: 28 (100%+)
If your spring collars are cranked down and you unscrew the droop screws while the car is sitting on the tires (and the front lifts up)..your droop screws are setting your ride height not your spring collars.
If your using Hudy droop blocks and getting a 6 reading under the c-hub tit (for lack of a better word) not the outer corner of the a-arm...I can just about guarantee you the droop screws are setting the ride height not the springs.
If it's set this way...you have zero droop (not good).
I don't have a picture sorry.
If this is hard to understand just set droop over ride height with a normal ride height gauge and there will be no issues.
Hope this helps.
F1
Roche usa
R.I.P. Jon Williams
j.d.roost is offline   Reply With Quote
Old 03-30-2013, 06:28 AM   #3095
sell682's Avatar
Got it .. Thanks!!! Issue resolved
Old 03-30-2013, 07:31 AM   #3096
jhautz's Avatar
Trader Rating: 85 (100%+)
Hey guys. Just picked up a T4 to race this summer. Planning to run the 17.5 blinky class. Im trying to figure out starting gearing but cant find a gearing chart anywhere. Last yer I ran the tc6 and that manual had a gearing/FDR chart in the back that I found really useful. Is there something like that available for this car?
If not can anyone help me get close to a 3.7 FDR. Thats about what my local track liked last year and where I want to start. BTW, I'm using 48 pitch gears.
Thanks for the help guys.
jhautz is offline   Reply With Quote
Old 03-30-2013, 08:08 AM   #3097
B00t13g's Avatar
78/40 puts you dead on a 3.7 in 48p.
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 03-30-2013, 08:21 AM   #3098
Xpress's Avatar
spur/pinion x 1.9 = final drive
"Desire is the key to motivation, but it's the determination and commitment to an unrelenting pursuit of laying it down - a commitment to excellence - that will enable you to attain the success you seek to beat ass."
-Espo
Xpress is offline   Reply With Quote
Old 03-30-2013, 12:46 PM   #3099
http://www.teamxray.com/teamxray/pro...Name=XRAY%20T4
gearing charts in the setup download
rescue119 is offline   Reply With Quote
Old 03-30-2013, 06:50 PM   #3100
jhautz's Avatar
Thanks guys. Didnt even see that chart in the downloads.
Xrpess. Exactly the info I was looking for. Thanks.
Old 03-30-2013, 10:49 PM   #3101
J.Filipow's Avatar
Trader Rating: 15 (100%+)
What part number do I need to run the optional, two piece lower suspension holder in the front of the T4?
P1 Brand - "Victory is Black and White" ◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤
RC America / XRayUSA / Hudy / Motiv / Avid / Vannen Watches
J.Filipow is offline   Reply With Quote
Old 03-30-2013, 11:15 PM   #3102
artwork's Avatar
Trader Rating: 59 (100%+)
XRA302049
http://www.amainhobbies.com/product_...-Holder-Orange
Sanwa | R1 Wurks | Avid | 2mm Designs
artwork is offline   Reply With Quote
Old 03-30-2013, 11:38 PM   #3103
B00t13g's Avatar
I can't seem to find a 52mm ecs replacement bone for the 2mm pins. Does anyone know of a place that has them or the part number?
Mackenzie Meyercord
Old 03-31-2013, 06:07 AM   #3104
What would people do to prevent the rear breaking loose late in the corner, like deep into its roll. Lower roll centre on the rear? Softer rear roll bar? More rear droop etc
Nathan Wilson is offline   Reply With Quote
Old 03-31-2013, 07:42 AM   #3105
Bigz84's Avatar
What is your camber and Toe at in the rear? increasing those would help...
Airtronics/Sawna : EA Motorsports : Orca : Reflex Racing/RSD : Wild Turbo Fans : Franchise Racing Products : RCAmerica : Hudy : Xray : Diggity Designs: Motiv : Team Scream Racing
Bigz84 is offline   Reply With Quote
Xray T3 2012 rasta_man Electric On-Road 4220 11-09-2016 01:45 PM
RC10B4/T4 Forum DerekL Electric Off-Road 14331 01-01-2016 02:18 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 08:55 AM
Tags
xray t4
