Old 03-24-2013, 01:27 PM   #3046
CristianTabush's Avatar
They are both very nice.
I really like the springs. They came about sort of "accidentally". In trying to replicate spring rates from HPI and Yokomo, we found some really curious qualities on springs when you make them with 1.5mm wire and so short.
Turns out the springs behave like progressive springs due to the coils collapsing over 50% of their range under normal working situations. This makes a spring that compliments the T4 a lot. Our progressive springs actually do change almost 1.0lb over the usable compression range.
Most springs change about 0.4-0.5 lb over the usable range. This is a spring we would call "linear" and what our carpet springs do.
What is interesting was what we found when testing XRAY springs. We do all our spring testing with AVID's spring testing machine. This is a precise, purpose built spring tester and the readings are accurate to 0.001lb/in.
XRAY linear springs are very linear. Very linear. Their variation is only about 0.3lb/in over the usable range. This is very low for a spring. Lowest I have tested to this day. What is surprising is their progressive springs.
From the tests we ran, we tested 5 sets of 2.3-2.6 and 5 sets of 2.5-2.8, we found out 2 things:
1.The springs don't act very progressive. The rates on the 2.3-2.6 averaged out to a 14.5-14.7 lb spring and the 2.5-2.8 averaged out to a 14.4-14.6lb spring, which leads to:
2.The 2.5-2.8 springs are slightly softer than the 2.3-2.6 springs. We ran the tests over and over again, trying different compression lengths and processes, and we always got the same result.
For the springs we tested, we found the rates to be:
XRAY Progressive:
2.3-2.6: 14.5-14.7
2.5-2.8: 14.4-14.6
XRAY Linear:
2.9: 16.5 lb/in
2.7: 15.4lb/in
When on the track, the RSD Silver provided a little bit better steering response than the 2.7 when used in the front which was the typical spring that I had been running. In the rear, the spring behaved similarly to the 2.3-2.6, but it stopped rolling the rear end a little bit sooner, making the car a little more stable. It also provided a little more rotation in the middle of the corner. This is for modified.
For my 13.5 car I found to like the silver up front and the carpet black by the end of the night. This allowed for more rear body roll which aided the car with better steering, however I did not have a second set of silvers to try in the rear. These might have been better.
Overall, I gained 1 tenth of a second with my mod car to a new fast lap of 10.6 at our local track and matched my fastest lap with the 13.5 to a 10.9 with the RSD goodies. I was running on worn tires though, so fresher rubber may have been better.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is online now   Reply With Quote
Old 03-24-2013, 02:18 PM   #3047
Skiddins's Avatar
XRAY Progressive:
2.3-2.6: 14.5-14.7
2.5-2.8: 14.4-14.6
XRAY Linear:
2.9: 16.5 lb/in
2.7: 15.4lb/in
Will you give proper ratings for your springs as well as the 'colours'?
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 03-24-2013, 02:27 PM   #3048
Yes, look at this here: Our springs are listed as, RSD 20mm T4 (...)
It is also listed on the individual product page on the website.
Old 03-25-2013, 02:22 AM   #3049
Skiddins's Avatar
Where do Xray T4 2.5's fit in?
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 03-25-2013, 03:31 AM   #3050
Send a message via MSN to Emil
Very interesting spring comparison chart. I expected a progressive measurement for the Yokomo BLUE/PINK springs and would be interested to see that as well since they used to be the spring to have for carpet at least before the Xray short shock era...
Emil is offline   Reply With Quote
Old 03-25-2013, 03:31 AM   #3051
+1
Old 03-25-2013, 04:37 AM   #3052
Hi RSD representitive, when will be the RSD bladder for T4 shock available? Looking foward to it
klth is offline   Reply With Quote
Old 03-25-2013, 05:40 AM   #3053
Warren Weaver's Avatar
Trader Rating: 46 (100%+)
Nice job Cristian nice stuff his springs are the best out there
warren
Warren Weaver is offline   Reply With Quote
Old 03-25-2013, 06:33 AM   #3054
Out of curiosity, has anyone crash tested the RSD DCJ??
Serpenteer is offline   Reply With Quote
Old 03-25-2013, 06:43 AM   #3055
Skiddins's Avatar
A few times , so far they seem to be holding up better than Xray's originals
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 03-25-2013, 10:00 AM   #3056
RCW
Trader Rating: 16 (100%+)
I did that yesterday. Broke an outdrive but the shaft was fine.
RCW is offline   Reply With Quote
Old 03-25-2013, 10:48 AM   #3057
alloyslash's Avatar
Trader Rating: 19 (100%+)
Will the RSD carpet springs be offered in a complete kit? I like how the T4 bumper brace/MyLaps mount turned out.
Pemberton SJ27 / Tekin RS / Cooper D4SS 17.5 / EAM 5000 / Futaba 9551 / 17.5lm
Pemberton SJ27 / Tekin RS / Bullet 13.5 / EAM 5000 / Savox 1251 / 13.5 Pro EDM
TLR22 / Tekin RS / D4SS 6.5 / Futaba 9551 / ORCA 6000 /SCMOD,
F14 carpet Oval Chassis too!
alloyslash is offline   Reply With Quote
Old 03-25-2013, 11:13 AM   #3058
Th yokomo springs are not really progressive. There is nothing in their design that would make them so. What they do have is that they are 0.5mm in diameter bigger than the "std" 14.0mm spring. This might have something to do with their performance. Our carpet springs are also 0.5mm oversized.
We are still working with the bladder factory to get them right. It will be a while, but we are working on them.
As for the Carpet spring set, we are working on 1 more rate in order to release a set of 4. These should be available in about 2-3 weeks. The Carpet spring set will follow.
Old 03-25-2013, 09:05 PM   #3059
erchn's Avatar
Cristian,
Thank you much for the information, and effort, on the spring chart. It's definitely helping me make sense of some of my testing in regards to the xray progressives.
If you do end up finding time to test the 2.5s from Xray that would be great.
I look forward to testing your new springs.
Thanks again,
Ethan
Serpent ; Desoto Racing ; Team Powers USA ; Reflex Racing ; Bezerk RC
erchn is offline   Reply With Quote
Old 03-25-2013, 09:17 PM   #3060
rustlerboi1052's Avatar
Just ran my T4 for the first time today.
I used the included baseline carpet setup included with the kit. I was running on a short indoor carpet track with no groove set in yet. CS-22 tires.
Having on-power understeer and off power oversteer. First I decreased rear droop and then subsequently took out the rear ARB. I didn't see any large improvements. I wonder what to change next... I wouldn't be so concerned, but I feel I'm pretty far off a stable car with the stock setup.
rustlerboi1052 is offline   Reply With Quote
Xray T3 2012 rasta_man Electric On-Road 4220 11-09-2016 01:45 PM
RC10B4/T4 Forum DerekL Electric Off-Road 14331 01-01-2016 02:18 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 08:55 AM
Tags
xray t4
