Old 03-23-2013, 04:59 PM   #3031
yodace's Avatar
R/C Tech Charter Subscriber
Anyone use the team Orion v10 pro and have any pictures, Of how u arranged all the wires
yodace is offline   Reply With Quote
Old 03-23-2013, 05:20 PM   #3032
dynasty's Avatar
Trader Rating: 26 (100%+)
Got a question on roll center arm holders... I just have high and low holders. Don't have enough for center position and I race on a tight carpet track with medium grip. What do you reccommend I start with? High or the low holders? I use spec sweep blue tires. Thanks
dynasty is offline   Reply With Quote
Old 03-23-2013, 05:26 PM   #3033
artwork's Avatar
Trader Rating: 56 (100%+)
First off buy some medium roll center blocks we all use them. Until you get some run low blocks but put shims under the aluminum blocks to raise the roll center to get closer to the medium blocks. I would suggest at least .5mm shims under all of the blocks until you get the medium roll center blocks. The difference between low blocks and medium blocks is .75mm so if you run low blocks with .75 under the aluminum blocks it would be like running medium roll center blocks. Make sure you use the correct length screws if you do run shims under the blocks.
Xray | Hudy | Sanwa | R1 Wurks | Avid | Protoform | Proline | 2mm Designs
artwork is offline   Reply With Quote
Old 03-23-2013, 06:32 PM   #3034
cwoods34's Avatar
Do you have enough to do at least one end of the car (4)? If so, center front/high rear works well.
If not, as artwork said just run lows all around but buy a full set of centers ASAP. My friend and I tested highs on the front of the car but never found them to work well..... 99% of the time you'll have at least one end of the car with centers.
Stop holding bitterness deep in your bum soul.
cwoods34 is offline   Reply With Quote
Old 03-23-2013, 07:01 PM   #3035
dynasty's Avatar
Thumbs up
Thanks for the feedback. I will run the lows and get some centers. I only have two which is not enough to complete an end. Thanks
Old 03-23-2013, 08:58 PM   #3036
eds24's Avatar
Send a message via AIM to eds24 Send a message via Yahoo to eds24
Not sure you are willing to do some custom wiring on your R10.. but I moved the RX wire and On/Off Switch to exit the back.
eds24 is offline   Reply With Quote
Old 03-23-2013, 09:02 PM   #3037
B00t13g's Avatar
I'll get you one tomorrow.
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 03-24-2013, 01:18 AM   #3038
dMITIj's Avatar
you got an link for those medium roll center blocks?
Best Regards.
TLR 22-4.
ORION VORTEX R10.1 Pro ESC.
ORION VORTEX VST2 PRO 7.5T.
ORION CARBON PRO 4500 100C 7.4V SHORTY PACK x3.
Sanwa MT4S Radio/RX-481 receiver & Xpert RC PI-3402 Brushless Servo.
dMITIj is offline   Reply With Quote
Old 03-24-2013, 02:07 AM   #3039
yodace's Avatar
Cool
Old 03-24-2013, 06:35 AM   #3040
Jerz616's Avatar
Trader Rating: 49 (100%+)
Here's mine with the wires in the regular location. I'm too chicken to try and rewire it like eds. Even though his looks super clean.
Ryan Gracey
XRAY T4'14/ORCA VXX/ORCA TX 5.0
XRAY XB8'14
Jerz616 is offline   Reply With Quote
Old 03-24-2013, 07:17 AM   #3041
Mikkel_R's Avatar
Standard setup for me, caps stuck to the side of the ESC belt side and switch in front of speedo. Receiver stuck to back of servo stood upright and PT stuck to side of RX.
Mikkel_R is offline   Reply With Quote
Old 03-24-2013, 09:56 AM   #3042
CristianTabush's Avatar
Default New RSD T4 Items
Some of our stuff started showing up. Below are the pictures:
RSD077 RSD XRAY T4 Asphalt Progressive Spring Set
RSD Carpet Linear Springs
RSD XRAY T4 Aluminum Bumper Brace
RSD XRAY T4 Machined Delrin Pistons 3/6 Holes (1.0-1.2mm holes)
RSD XRAY T4 Machined Delrin Pistons 4 Holes (1.0-1.2mm holes)
RSD XRAY T4 High Speed Bearing Kit
RSD XRAY T4 Increased Steering Throw Steering Rack Stand Off
The carpet springs are still missing 1 rate, this is why we are yet to release it as a set.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 03-24-2013, 10:55 AM   #3043
B00t13g's Avatar
Parts look good. When will you have pinks available?
Mackenzie Meyercord
Old 03-24-2013, 12:30 PM   #3044
j.d.roost's Avatar
Trader Rating: 28 (100%+)
Excited about the pistons and springs.
F1
Roche usa
R.I.P. Jon Williams
j.d.roost is offline   Reply With Quote
Old 03-24-2013, 12:41 PM   #3045
Overheard some talk about springs yesterday, as I start to make changes since I'm pretty new to racing I've really noticed how much springs make a difference.. Night and day when I went a little stiffer but traction rolled a few times
JOE SI is offline   Reply With Quote
Xray T3 2012 rasta_man Electric On-Road 4220 11-09-2016 01:45 PM
RC10B4/T4 Forum DerekL Electric Off-Road 14331 01-01-2016 02:18 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 08:55 AM
Tags
xray t4
