Old 03-20-2013, 04:27 PM   #3016
Originally Posted by Matt W View Post
Hi,
Does anyone know the weight of the new CSO Hard bumper for the T4?
a must have
cheapskate.brok is offline   Reply With Quote
Old 03-20-2013, 06:22 PM   #3017
RCFREAK's Avatar
Trader Rating: 17 (100%+)
ROAR NATIONALS THIS PAST WEEKEND @ HORSHAM RACEWAY!
XRAY T4 TAKES 1ST AND 2ND! Great win for Craig Xavier and Art for 2nd!
stock sedan had approx 60 entries!
The New Xray T4 '13-roar-nats-podium-pics.jpg   The New Xray T4 '13-roar-nats-pics.jpg
Arv.
RC AMERICA// EA MOTORSPORTS// KO PROPO// ORCA
RCFREAK is offline   Reply With Quote
Old 03-20-2013, 09:09 PM   #3018
B00t13g's Avatar
I posted this in the ask Paul section, but I figured since its related to the t4 I would ask you all as well!
Paul,
I've been having an issue with my car and I'm not sure it's actually an issue. If I lay the chassis on droop blocks the front block isn't as snug on the right hand side as the left. The rear has equal resistance on both sides. If I run a block down the chassis there is no gap or visible light anywhere to be seen. Ride height is equal left to right front/rear so I'm thinking it is not tweaked. Keep in mind when the lack of resistance is felt the car does not have a battery in it, but otherwise is full weight. With a battery in, there is equal resistance on all four corners. The chassis is balanced left to right as long as my battery is in it. I'm thinking it all comes down to a lack of weight, but I wanted your input.
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 03-21-2013, 04:04 AM   #3019
Adam B's Avatar
Anytime you do any setup adjustment or change your car needs to be in race ready form. That being said, with your battery not installed your chassis will want to lean towards the left because the weight of the electronics.
Franchise Racing Products * Fantom Racing * Pro One R/C Tires * RC America/Xray * Discount R/C Store * F1 R/C Lab * NORCAR @ The Gate
Adam B is offline   Reply With Quote
Old 03-21-2013, 05:00 AM   #3020
j.d.roost's Avatar
Trader Rating: 28 (100%+)
T4's were dialed at the nats.
While some struggled with traction rolling when grip came up...I did not see any "orange" and carbon rolling through the sweeper.
Arvin did great too.
Guy snuck into the big show on his last qualifier and proceeded to kick some a*s.
Was awesome to see.
F1
Roche usa
R.I.P. Jon Williams
j.d.roost is offline   Reply With Quote
Old 03-22-2013, 01:56 AM   #3021
Trader Rating: 43 (100%+)
where can i get the best deal on a T4. i saw a link on the rctech page one time 499 with free shiping.
aceinthesky is offline   Reply With Quote
Old 03-22-2013, 06:20 AM   #3022
klaymon's Avatar
Trader Rating: 71 (100%+)
It's out of stock right now, but A Main has it for $530 and you can use this code for $25 off.
CALPMAR2513
klaymon is offline   Reply With Quote
Old 03-23-2013, 05:29 AM   #3023
Send a message via AIM to Matt W
Default Over heating the tyres!!
Hi,
I run sorex 28's Jb on a fairly small tight and twisty carpet track. The car is great at the beginning of the meeting but I find that as the track rubbers in the tyres start to go off slightly and start over heating nearer the end of a race. I only have the additive on for around 15 mins and dont use tyre warmers.
I was wondering what kind of changes I could make to the car throughout the meeting to prevent the tyres from over heating nearer the end of a race. I am using the thinner top deck which I thought would help with this as the extra flex would mean the tyres were used less?
Any thoughts or ideas would be appreciated!
Matt W is offline   Reply With Quote
Old 03-23-2013, 05:44 AM   #3024
Talking
I also had this problem a few months ago and a good solution i found was to drive a bit different, to use less brake and to let the car more "roll"
You can also try the std topdeck so the car will "work" less and maybe the tires will stay cooler, but i'm not really sure about that
Awesomatix | LRP
Awesoman is offline   Reply With Quote
Old 03-23-2013, 06:46 AM   #3025
Skiddins's Avatar
Hi,
Matt which track do you mean?
Is it the front or rear tyres that are overheating, or both?
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 03-23-2013, 07:55 AM   #3026
Its up at wodson on a fri night so quite a grippy track! Its prob mainly the rears that are over heating but it seems the car becomes very edgy near the end of a race, especially at the end of the night with finals!
Old 03-23-2013, 08:53 AM   #3027
bucknuts's Avatar
Old tires or tire brand..
bucknuts is offline   Reply With Quote
Old 03-23-2013, 09:10 AM   #3028
CristianTabush's Avatar
Heavier oil and softer springs typically will help with tire overheating.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 03-23-2013, 10:36 AM   #3029
Default over heating
hi matt, will would try removing a little bit of droop from the rear, about .3mm to start with also are the gt12's running oil based additives on their foam tyres?
matt prigmore is offline   Reply With Quote
Old 03-23-2013, 12:12 PM   #3030
Skiddins's Avatar
Did you actually measure the tyre temps?
I ask as as the grip level gets higher, my car starts to understeer more and feel too safe.
What is your setup?
I would also go back to the standard top deck. At Newbury I found that the tin top deck was no faster or slower, but did make the car slightly more difficult to drive.
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Xray T3 2012 rasta_man Electric On-Road 4220 11-09-2016 01:45 PM
RC10B4/T4 Forum DerekL Electric Off-Road 14331 01-01-2016 02:18 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 08:55 AM
Tags
xray t4
