Old 03-17-2013, 09:24 AM   #3001
alloyslash's Avatar
Trader Rating: 19 (100%+)
Pemberton SJ27 / Tekin RS / Cooper D4SS 17.5 / EAM 5000 / Futaba 9551 / 17.5lm
Pemberton SJ27 / Tekin RS / Bullet 13.5 / EAM 5000 / Savox 1251 / 13.5 Pro EDM
TLR22 / Tekin RS / D4SS 6.5 / Futaba 9551 / ORCA 6000 /SCMOD,
F14 carpet Oval Chassis too!
alloyslash is offline   Reply With Quote
Old 03-17-2013, 06:01 PM   #3002
Wich pinion can i use on t4 with turnigy trackstar 8240KV 4.0t in 2s??
Revinho is offline   Reply With Quote
Old 03-17-2013, 06:25 PM   #3003
B00t13g's Avatar
Depends on track size, spur, boost etc.
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 03-18-2013, 02:15 AM   #3004
cyba888's Avatar
my local hobby shop has the Spec R versions in stock... you think they are worth it since it looks identical to the RSD ones?
http://www.spec-r.com/default/index....roducts_id=322
cyba888 is offline   Reply With Quote
Old 03-18-2013, 02:47 AM   #3005
kermit's Avatar
These work great. Just make sure the clip is orientated so that when the CVD is rotating forward it doesn't catch on the unhooked end resulting in a bent clip and lost pin. If you are really worried it is worth putting some 10mm heat shrink over the whole assembly to avoid losing pins altogether.
Note: the Spec-R v2 require the different sized inner bearing (each driveshaft includes one bearing).
Adelaide RC Team Driver - www.adelaiderc.com.au
XRAY T4 | Futaba | HOBBYWING | Muchmore
kermit is offline   Reply With Quote
Old 03-18-2013, 05:32 AM   #3006
cyba888's Avatar
Noted thanks
2014 and 2015 BD7 Black Series, Yokomo RPX ESC- Yokomo 4.5T Motor
Yokomo B-MAX4 III Factory Team Kit, Muchmore ESC- LRP 6.5T Motor
Mugen MBX7R Eco- 2200 KV Motor
Futaba 4PX
Old 03-18-2013, 11:49 AM   #3007
klaymon's Avatar
Trader Rating: 71 (100%+)
Originally Posted by alloyslash View Post
Here is their 52mms that are identical dimensionally wise and do not require "special" bearings. I have the XRay ECS axles on my T3'12 and the RSDs on my T4 and personally like the RSDs design better, no setscrews to back out during a race but are very easy to disassemble and clean. The best part is they are $42.99 a pair instead of $49.99 each.
I chose the narrow version because I like to play with track width to improve steering with track conditions
http://www.reflexracing.net/RSD-XRAY...cs_p_1674.html
I'm interested in these, but the phrase "virtually identical dimensionally " means they are not identical. Anyone know what the variance is on these? Is the length at least the same?
klaymon is offline   Reply With Quote
Old 03-18-2013, 12:10 PM   #3008
erchn's Avatar
Spec-r units are 51mm, RSD offers that as well.
Serpent ; Desoto Racing ; Team Powers USA ; Reflex Racing ; Bezerk RC
erchn is offline   Reply With Quote
Old 03-18-2013, 12:14 PM   #3009
klaymon's Avatar
So the wide units listed are actually shorter than the Xrays?
Old 03-18-2013, 04:58 PM   #3010
erchn's Avatar
I don't know what that means.
Spec-r sells a 51mm set.
RSD has a 52mm and 51mm set.
Xray sells 50 and 52.
Old 03-18-2013, 05:33 PM   #3011
klaymon's Avatar
I meant the RSD wide set is shorter than the Xray wide set. Sorry for the confusion.
Old 03-18-2013, 06:12 PM   #3012
CristianTabush's Avatar
Virtually identical means pretty much the same dimensions, however they have retaining clips so some areas around the clip are a bit larger in diameter. What this means is the wide axle are the same as 52mm ECSs. Personally I run the narrow axle ones. With the narrow axle, the entire coupling is moved outwards 1mm which makes the axles more efficient under lock than the standard width axles. However the narrow axle use the 5x10x3 bearings are not as durable.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 03-20-2013, 11:52 AM   #3013
Send a message via AIM to Matt W
Default CSO hard bumper weight!!
Hi,
Does anyone know the weight of the new CSO Hard bumper for the T4?
Matt W is offline   Reply With Quote
Old 03-20-2013, 11:57 AM   #3014
Nico''s Avatar
Originally Posted by Matt W View Post
Hi,
exactly 9,1 g
Nico' is offline   Reply With Quote
Old 03-20-2013, 01:26 PM   #3015
Originally Posted by Nico' View Post
exactly 9,1 g
Will it fit on the t3 12, It should do? Could you measure the height of it pls?
Xray T3 2012 rasta_man Electric On-Road 4220 11-09-2016 01:45 PM
RC10B4/T4 Forum DerekL Electric Off-Road 14331 01-01-2016 02:18 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 08:55 AM
Tags
xray t4
