Old 03-10-2013, 07:02 AM   #2926
cyba888's Avatar
my belt sits at an angle at the bottom and it rubs the antenna base... anyone else have this problem?
/URL]
cyba888 is offline   Reply With Quote
Old 03-10-2013, 07:06 AM   #2927
Quantra's Avatar
When I first built mine my front belt was twisted too. I just kept twisting it back a section at a time until it was flat. I think I did each part of the belt twice.
Vince Coleman
Quantra is offline   Reply With Quote
Old 03-10-2013, 02:01 PM   #2928
trigger's Avatar
I filed a flat spot on my antenna base to clear the belt.
Minh Nguyen
[Maclan Racing][Xpert]
trigger is offline   Reply With Quote
Old 03-10-2013, 04:20 PM   #2929
cyba888's Avatar
Thanks for the tips
Old 03-11-2013, 08:47 AM   #2930
Hey guys,
we are having a serious problem of rear belt snapping. I am talking about belts not lasting more than 4 heats of 5 minutes. Anything you guys have done to prevent this?? Less tension on the belt? Track is not dusty/dirty and no pebbles/rocks/dirt was found on the diff/pulleys.
Serpenteer is offline   Reply With Quote
Old 03-11-2013, 09:11 AM   #2931
cyba888's Avatar
My rear belt also snapped because of small rock/pebble but you won't see it stuck at the pulley...
Old 03-11-2013, 09:11 AM   #2932
kuruption's Avatar
Trader Rating: 24 (100%+)
Send a message via AIM to kuruption
Originally Posted by Serpenteer View Post
Hey guys,
I've been running the same belt since I bought the car. My belt is pretty loose, just tight enough to not slip. But I run 17.5 on carpet so it may be different in mod and/or on asphalt
Keep your pulleys clean too
Ray Sundland
Eat. Sleep. Race. Repeat.
"Feel not as though it is a sphere we live on, rather an infinite plane which has the illusion of leading yourself back to a point of origin."
kuruption is offline   Reply With Quote
Old 03-11-2013, 09:13 AM   #2933
samnelso's Avatar
Hey guys,
Hmm i have not seen this problem. For 17.5 blink I run the eccentric at its loosest position with the diff down. For mod a little bit tighter. There should still be a little slack though.
Team Associated | Reedy | Airtronics
RC Excitement: Fitchburg, MA | RC Madness: Enfield, CT | Horsham RC
samnelso is offline   Reply With Quote
Old 03-11-2013, 10:10 AM   #2934
CristianTabush's Avatar
Hey guys,
This is caused due to the belt being loose. It is especially bad on tracks with long straights and mod motors. I usually run my belt 1 notch tighter than the manual and after 2-3 runs I tighten it another notch.
Also, the Spec R R1 rear belt fits and is more durable than the XRAY one. Crazy stuff.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is online now   Reply With Quote
Old 03-11-2013, 10:14 AM   #2935
syndr0me's Avatar
Trader Rating: 32 (100%+)
Make sure your pinion isn't rubbing the belt.
syndr0me is offline   Reply With Quote
Old 03-11-2013, 10:21 AM   #2936
How did you know it was a rock/pebble if it wasn't stuck in the pulley??
Pulleys are kept very clean, we are running mod motors, so I know belts can take a hard fall. Yet, this problem never happened with T3 '12 cars. I know because I had run 5-6 race meets without any belt problems on the same motors.
I'll give the Spec R belt a try. The belts are real tight like the manual says. We have tried 1 notch looser and 1 notch tighter, still breaks.
Yes, the straightway is very long and we are using mod motors.
Yep, made sure of that.
I'll guess I'll start trying other brand's belts.
Old 03-11-2013, 10:21 AM   #2937
defcone's Avatar
Trader Rating: 15 (100%+)
Yokomobelts4life
defcone is offline   Reply With Quote
Old 03-11-2013, 10:52 AM   #2938
Skiddins's Avatar
Hey guys,
Try running the front belt on a tighter setting than the rear to help even on load on throttle between the two belts.
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 03-11-2013, 01:09 PM   #2939
Dash anybody know someting about BRCA rules, I have a LTC-R body that have a cutting mark on the side squirts this is BRCA cutting line, I wonder?
Is the BRCA not handling the EFRA or roar regulations.
Is there somebody who can explain this.
thanks
eded1 is offline   Reply With Quote
Old 03-11-2013, 01:31 PM   #2940
Skiddins's Avatar
thanks
I have never understood the cut llines on the bodies, as no-one uses them.
A lot of body rules were changed at the end of last year to simplify them. These are the current BRCA body rules (for 2013);
http://www.centralbooking.org/cbs/im...-12-2012_0.pdf
In short, you need to be carefull of the rear wing size (190*40*20mm) which includes the endplates, and mount it directly onto the body.
There is no minimum roof height but the wing must be below your roof, the size of the wings means it should never stick above the roof line.
Some of the rear and front valance & bumpers must still be left on the body, like the ETS;
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Xray T3 2012 rasta_man Electric On-Road 4220 11-09-2016 01:45 PM
RC10B4/T4 Forum DerekL Electric Off-Road 14331 01-01-2016 02:18 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 08:55 AM
Tags
xray t4
