Old 03-07-2013, 05:30 PM   #2911
Bigz84's Avatar
Trader Rating: 15 (100%+)
Default body height
what are most t4 drivers setting the body height at? Are you slamming the body to the ground? I picked up a hudy body gauge and I tried to place the body below the gauge, but I am worried about the front tires hitting the upper fender wells. What body post shims (0,1,2) are you using to get there?
Radiopost : EA Motorsports : Orca : Reflex Racing/RSD : Wild Turbo Fans : Franchise Racing Products : RCAmerica : Hudy : Xray : Diggity Designs:
Bigz84 is offline   Reply With Quote
Old 03-08-2013, 04:30 AM   #2912
Send a message via Skype™ to martinskarin
Originally Posted by cyba888 View Post
Keep me posted
It does work well.
Hold the shock upside down and loosen the bottom cap pretty much. Press the piston in slowly, it drains faster in this way..
Martin Skärin
Shanghai
Roche Rapide P12
martinskarin is offline   Reply With Quote
Old 03-08-2013, 07:20 AM   #2913
cyba888's Avatar
Originally Posted by martinskarin View Post
It does work well.
Thanks... so for 25% rebound just push the shock in, hold it at the 25% mark and then loosen the bottom cap to drain it out?
cyba888 is offline   Reply With Quote
Old 03-08-2013, 08:20 AM   #2914
I loosened the cap first, then push the shock in, wait a little and the tighten the cap. Re-do it if still too much rebound. Basically similar to doing it according to the manual but just on the other end of the damper..
Martin Skärin
Shanghai
Roche Rapide P12
Old 03-08-2013, 09:40 AM   #2915
cyba888's Avatar
Got it thanks!
Old 03-08-2013, 08:18 PM   #2916
cyba888's Avatar
I just follow what the manual says and if the body is slightly too low just trim accordingly. My guess is you want the body as low as possible without scraping...thats how mine is
Old 03-09-2013, 01:02 PM   #2917
yodace's Avatar
R/C Tech Charter Subscriber
What are Your guys thoughts on how this car performs on asphalt low grip? Is grip. is there anything i should change while I build the kit or get?
yodace is offline   Reply With Quote
Old 03-09-2013, 01:07 PM   #2918
yodace's Avatar
Originally Posted by syndr0me View Post
We noticed last night there appears to have been a running change to the servo mount. The older kits have one "nipple" that keys into either the chassis or the brace that goes across the top of the servo. Newer kits have two nipples.
Now you know about your XRay's nipples.
Do u have a picture of this running change? Hope the kit I got from the hobby store has this change ..
Old 03-09-2013, 01:36 PM   #2919
Skiddins's Avatar
So far, it looks like the kit asphalt setup is good.
I would get some of the different springs though as you may need to change them depending on conditions.
Skiddins
Xray T4'16, T4'14 (Wet Car)
Xray X12 2016
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 03-09-2013, 04:38 PM   #2920
Yesterday we where practicing outdoor for the first time of the season and the track where ofcourse dusty and slipery. I removed the screws from the bulkhead with the spur gear to get more flex apart from that I still have pretty much stock set, after testing alot of different things i ended up there again in the end of the day.
Softer rollbars, springs can be a good tuning option but I felt my car was too soft then and got harder to drive and lost rotation. Just laying the shocks down to hole no 3 can help you too. Maybe use the one piece suapension holders in the front. I did not have time to try those yesterday but will next week.
We have a real large open fast track.
Martin Skärin
Shanghai
Roche Rapide P12
Old 03-09-2013, 04:45 PM   #2921
alloyslash's Avatar
Trader Rating: 19 (100%+)
Skiddins
+1
What I did after buying my kit is I placed a small order every week until I collected every spring rate and most of the swaybars offered for the T4. I can tune for most any condition now.
Pemberton SJ27 / Tekin RS / Cooper D4SS 17.5 / EAM 5000 / Futaba 9551 / 17.5lm
Pemberton SJ27 / Tekin RS / Bullet 13.5 / EAM 5000 / Savox 1251 / 13.5 Pro EDM
TLR22 / Tekin RS / D4SS 6.5 / Futaba 9551 / ORCA 6000 /SCMOD,
F14 carpet Oval Chassis too!
alloyslash is offline   Reply With Quote
Old 03-09-2013, 09:33 PM   #2922
yodace's Avatar
I thought abouting getting a spec r gear diff for the front but? But didnt know what extra part to get. some one said u need some other part to use a spec r. When guys say springs are u talking about the progressive springs .. ?
Old 03-09-2013, 10:36 PM   #2923
trigger's Avatar
Someone correct me if I'm wrong but I think you'll need to run 50mm axles if you use spec r gear diffs. If that is you're only option, then go for it but I suggest but I suggest spending the extra coin on the xray diff cause its much lighter and you can run any axle you choose to.
Minh Nguyen
[Maclan Racing][Xpert]
trigger is offline   Reply With Quote
Old 03-09-2013, 10:52 PM   #2924
Skiddins's Avatar
....When guys say springs are u talking about the progressive springs .. ?
All their different springs, progressive and standard.
Xray X12 2016
Xray X1'16
RCDisco.co.uk
Old 03-10-2013, 04:50 AM   #2925
alloyslash's Avatar
Current XRay T4 spring rates are
2.3-2.6 & 2.5-2.8 progressives
2.3, 2.5, 2.7, 2.9 standards
Xray T3 2012 rasta_man Electric On-Road 4220 11-09-2016 02:45 PM
RC10B4/T4 Forum DerekL Electric Off-Road 14331 01-01-2016 03:18 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 09:55 AM
Tags
xray t4
SEO by vBSEO 3.5.0
