Old 03-06-2013, 02:42 PM   #2896
alloyslash's Avatar
Trader Rating: 19 (100%+)
Originally Posted by Nathan Wilson View Post
So you moved the rear arms forward and shortened the wheelbase?
Yes i run all 3mm of shims behind the rear arms. That makes my car turn the way I like it to.
Pemberton SJ27 / Tekin RS / Cooper D4SS 17.5 / EAM 5000 / Futaba 9551 / 17.5lm
Pemberton SJ27 / Tekin RS / Bullet 13.5 / EAM 5000 / Savox 1251 / 13.5 Pro EDM
TLR22 / Tekin RS / D4SS 6.5 / Futaba 9551 / ORCA 6000 /SCMOD,
F14 carpet Oval Chassis too!
alloyslash is offline   Reply With Quote
Old 03-06-2013, 03:40 PM   #2897
cyba888's Avatar
Any tricks on rebuilding the shocks? First time with 25% rebound no problem following owners manual but after a few weeks later I can't seem to get it to work again to achieve same rebound. Tried following same instructions again with no luck. I heard the stock bladders swell up over time? If any of you are rebuilding it differently with success please share
cyba888 is offline   Reply With Quote
Old 03-06-2013, 06:36 PM   #2898
Send a message via Skype™ to martinskarin
I got same issue with 1 damper. I just cannot get the re-bound down and after too much trying I get air inside, I will try to hold the damper upside down and open the bottom cap instead tmrw, I found some tips about doing that.
Martin Skärin
Shanghai
Roche
Destiny
PROAMPS
martinskarin is offline   Reply With Quote
Old 03-06-2013, 10:36 PM   #2899
cyba888's Avatar
Keep me posted
Old 03-06-2013, 11:04 PM   #2900
Anybody have any advice on reducing off throttle oversteer? Finding the rear swaying out too much coming into the corner and wiping too much speed.
J-PaP is offline   Reply With Quote
Old 03-07-2013, 04:55 AM   #2901
LIUK82's Avatar
HI,
I installed today a standard servo Orion 1017
but it doesn't fit good, I had to remove all the shims that I used with the first low profile, removing the adhesive label from the servant and given a narrowed down to the plastic of the steering group that touched but
I have little space, the manual talks about a minimum of 0.5mm of space
i removed the shim on servo but touch
T4 is built only to serve low profile?
LIUK82 is offline   Reply With Quote
Old 03-07-2013, 07:33 AM   #2902
hi all,
i have a question regarding the upper clamp position in the front... the T4 manual says that, as initial asphalt setup, you should use position 1 on both front and rear... but the same xray, in the "T4 basic asphalt setup sheet", says that you should use position 2 in the front upper clamp.... and most setups i see on the net also are on position 2 in front... can someone clear this aspect ? it would help...thanks,
fabrc68 is offline   Reply With Quote
Old 03-07-2013, 07:40 AM   #2903
Trader Rating: 38 (100%+)
FOR SALE T4 - NEW. Ran 2 packs on carpet. Not a scratch on it. Spektrum LP 6070 servo installed. Comes with everything in kit. Body posts not even cut down. Upgraded Front Xray bumper. call me/text me 518-495-0703 for pics. $440 with Servo.
Previous username: MBUCK
noworries is offline   Reply With Quote
Old 03-07-2013, 09:43 AM   #2904
samnelso's Avatar
Originally Posted by LIUK82 View Post
HI,
Same issue on mine with a Savox servo. I trimmed down the thickness of the servo ears to help remedy the rubbing, but it still touches the bellcrank arm. It actually rubbed off the sticker on the servo. To supplement this, the bellcrank arm could be trimmed a little too. Certainly not ideal.
Team Associated | Reedy | Airtronics
RC Excitement: Fitchburg, MA | RC Madness: Enfield, CT | Horsham RC
samnelso is offline   Reply With Quote
Old 03-07-2013, 09:56 AM   #2905
syndr0me's Avatar
Trader Rating: 32 (100%+)
We noticed last night there appears to have been a running change to the servo mount. The older kits have one "nipple" that keys into either the chassis or the brace that goes across the top of the servo. Newer kits have two nipples.
Now you know about your XRay's nipples.
syndr0me is offline   Reply With Quote
Old 03-07-2013, 10:11 AM   #2906
artwork's Avatar
Trader Rating: 56 (100%+)
My Xray Nipples appear to be optimized!
Xray | Hudy | Sanwa | R1 Wurks | Avid | Protoform | Proline | 2mm Designs
artwork is offline   Reply With Quote
Old 03-07-2013, 10:33 AM   #2907
Anti-dive in front.
Team AME/ORCA
https://www.facebook.com/strawberryrcdesigns
http://www.strawberryrcdesigns.pt/
jorgesimes is offline   Reply With Quote
Old 03-07-2013, 11:33 AM   #2908
Edited - will sell without servo as well.
Old 03-07-2013, 11:42 AM   #2909
Skiddins's Avatar
Could try more rear toe in, go up to 1mm shims from the kit 0.75mm, should be around 3.3deg
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 03-07-2013, 01:58 PM   #2910
SOLD. SOLD> SOLD> SOLD>
Xray T3 2012 rasta_man Electric On-Road 4220 11-09-2016 01:45 PM
RC10B4/T4 Forum DerekL Electric Off-Road 14331 01-01-2016 02:18 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 08:55 AM
Tags
xray t4
