Old 02-08-2013, 06:34 AM   #2686
bucknuts's Avatar
Originally Posted by Huskerfan1212 View Post
Front camber1
Toe out 1
r/h 5.5
Rc high and long
Rear cambet 1.5
Toe in 2
R/h 5
Rc high and short links
More rear Toe! Stock is 3 deg. Try going with the thicker shim, I think the kit includes 3 different thicknesses? silver (2deg), black(3deg), gold(3.5-4deg)
bucknuts is offline   Reply With Quote
Old 02-08-2013, 09:54 AM   #2687
Adam B's Avatar
Originally Posted by Adam B View Post
Corey, did you cut the stock upper deck, or the thin one? Assuming you cut the stock one, would using the 1.6mm top deck give you the same or close to the same result?
He told me they cut the stock one, and that using the 1.6mm might be too much for indoor carpet.
Franchise Racing Products * Fantom Racing * Pro One R/C Tires * RC America/Xray * Discount R/C Store * F1 R/C Lab * NORCAR @ The Gate
Adam B is offline   Reply With Quote
Old 02-08-2013, 09:57 AM   #2688
Meradin's Avatar
Trader Rating: 19 (100%+)
I know the setup were posted for mod racing, I am wondering how much of these setups and changed will help in 17.5?
What kinda setup changes are needed for a slower class or are they pretty universal?
Better than Randy, Adam said so!
Second thought...I don't trust Adams, they make up everything!
"Leave it to Steever", custom paint masks, decals, and paint.
Meradin is offline   Reply With Quote
Old 02-08-2013, 09:59 AM   #2689
Adam B's Avatar
Adding the +.75 to the rear raising the roll center. Will that give more rear grip? Looking for more rear grip less steering.
I am confused with what Skiddins said about this. Wouldn't the +75 roll centers (short ones), lower the center of gravity in the rear and give more rear grip?
Old 02-08-2013, 10:05 AM   #2690
Adam B's Avatar
my car is basically the mod set up he posted back in October and it is pretty good. That set up was with basically all box stock parts, as tuning parts were not available yet. If you go off his 13.5 setting and running 17.5, you should be ok. The MOD setup will probably give you way too much steering at the slower speeds. But this depends on where you race and grip levels also. The 2 main tracks I go to have a ton of grip. I heard the grip at the Birds wasn't as high as some of my friends expected. Another issue is the setups are based on Andrews driving style, so to make them work, you may have to adjust for that also.
Old 02-08-2013, 01:30 PM   #2691
Skiddins's Avatar
Raising the rear roll centre blocks at the wishbone lowers the roll centre.
If you lower the upper link on the inside that also raises the roll centre
Neither affects the CoG, (that's down the ride height and weight distribution etc.) just where the car will try to roll around it.
Skiddins
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 02-08-2013, 01:43 PM   #2692
Skiddins
Skiddins,
Putting the +.75 wishbone mounts on the rear would raise the roll centre
XRAY T4 Hobbywing V3 Sanwa
FLAT OUT is offline   Reply With Quote
Old 02-08-2013, 03:21 PM   #2693
Bigz84's Avatar
Trader Rating: 15 (100%+)
Originally Posted by FLAT OUT View Post
Skiddins,
correct....
also what skiddins said about lowering the upper links is correct...it would raise roll center....
now I thought this was to take away traction? Lowering rc gives you more traction, right?
Airtronics/Sawna : EA Motorsports : Orca : Reflex Racing/RSD : Wild Turbo Fans : Franchise Racing Products : RCAmerica : Hudy : Xray : Diggity Designs: Motiv : Team Scream Racing
Bigz84 is offline   Reply With Quote
Old 02-08-2013, 03:44 PM   #2694
How about rebound in the shocks? Some none?
Huskerfan1212 is offline   Reply With Quote
Old 02-08-2013, 03:47 PM   #2695
Adam B's Avatar
Usually none to 10%
Old 02-08-2013, 05:18 PM   #2696
trigger's Avatar
Anytime you raise the hinge pins, it takes away traction on that end(less ability to roll). If you lower the hinge pins you gain traction on that end(more ability to roll)
Minh Nguyen
[Maclan Racing][Xpert]
trigger is offline   Reply With Quote
Old 02-08-2013, 05:33 PM   #2697
Adam B's Avatar
I stand corrected, I have studied the set up book a little more tonight. Good to know because tomorrow night both cars are being rebuilt.
Old 02-09-2013, 06:32 AM   #2698
Adam B's Avatar
I notice on the xray set up sheets there is mention of an optional motor mount. Anybody know anything about this?
Old 02-09-2013, 09:24 AM   #2699
Xpress's Avatar
I believe the motor mount is "Y" shaped and connects to the bottom of both sides of the layshaft mount.
"Desire is the key to motivation, but it's the determination and commitment to an unrelenting pursuit of laying it down - a commitment to excellence - that will enable you to attain the success you seek to beat ass."
-Espo
Xpress is offline   Reply With Quote
Old 02-09-2013, 10:42 AM   #2700
Skiddins's Avatar
Skiddins,
Oop's correct, I got it right originally, before it was questioned.
....Then I had a blonde moment during typing my response
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Xray T3 2012 rasta_man Electric On-Road 4220 11-09-2016 01:45 PM
RC10B4/T4 Forum DerekL Electric Off-Road 14331 01-01-2016 02:18 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 08:55 AM
Tags
xray t4
