Old 02-07-2013, 05:10 AM   #2656
Originally Posted by Nathan Wilson View Post
Can you post a pic or a diagram please. thanks
Here you go.
CoreyW. is offline   Reply With Quote
Old 02-07-2013, 05:54 AM   #2657
Trader Rating: 38 (100%+)
SOLD!!!!!!!!!!!!!!!!!!
noworries is offline   Reply With Quote
Old 02-07-2013, 06:05 AM   #2658
Skiddins's Avatar
Originally Posted by CoreyW. View Post
Here you go.
The cut was where I thought
What did that give with regards to handling.
Skiddins
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 02-07-2013, 07:09 AM   #2659
j.d.roost's Avatar
Trader Rating: 28 (100%+)
Guess I will be hanging out here more often.
F1
Roche usa
R.I.P. Jon Williams
j.d.roost is offline   Reply With Quote
Old 02-07-2013, 07:43 AM   #2660
Skiddins
A little less steering on centre btu more mid-corner/exit steering. We also had the 2 screws removed from the front of the spur gear portion of the upper deck - both changes provided more overall grip but did make the car suffer slightly through chicanes. The test was done back to back with-in 15mins(both times on new tires) so we were able to eliminate the track changing as a variable.
Also, I think this change helps when running a front diff as it keeps more load on the inside tire when driving off the corner. Some of the Xray guys switched back and forth between the spool and diff with mixed results, and I think it might have had more to do with the front end flex(split blocks and cut deck) then anything else.. Most were running 1 piece front blocks. Back home we tested both a spool and diff THOROUGHLY - what we found was that you had to committ to this change, and by commit, I mean change the rest of the setup to work with it. This is a common mistake I see some people make at big races, or any race for that matter. I believe the reason our car was one of the better T4's at the race is because we tested each one(spool/diff)and made the necessary changes to the car that suited both. When testing was completed, we could honestly say we gave both a fair chance. For us, what made the diff work best were front split blocks and the cut upperdeck! We had more front end flex on our car which provided more grip to the inside tire and the result was better drive off the corner. Now, combine that with the better turn-in and increased corner speed from the diff (advantage over the spool), you have the best of both worlds!
Old 02-07-2013, 08:56 AM   #2661
WNRacing's Avatar
Trader Rating: 34 (100%+)
Corey, did you only use the option arms in mod? If so would you mind explaining what the difference was?
I heard of a couple people running the solid (one piece) suspension block in the (forward) rear, were you guys still running the stock T4 split blocks?
Thanks!
-Evan Williams
SMC Racing - Airtronics - Radiopost Servos - Upgrade RC
WNRacing is offline   Reply With Quote
Old 02-07-2013, 09:11 AM   #2662
Hi Corey,
Thanks for all the information! It's great! Did you guys get to test other bodies???
Serpenteer is offline   Reply With Quote
Old 02-07-2013, 09:20 AM   #2663
syndr0me's Avatar
Trader Rating: 32 (100%+)
Is the Corey Whiteman fan club accepting new members? Where do I sign up?
syndr0me is offline   Reply With Quote
Old 02-07-2013, 09:25 AM   #2664
locked's Avatar
I think you're going to have to start an "Ask CoreyW" thread.
locked is offline   Reply With Quote
Old 02-07-2013, 09:31 AM   #2665
theatriks's Avatar
Coreys a wicked mechanic from what i can see....when are we gonna see him wheeling a T4.
theatriks is offline   Reply With Quote
Old 02-07-2013, 09:34 AM   #2666
locked's Avatar
I bug him to race with us all the time. He's probably tired of hearing it.
Old 02-07-2013, 09:40 AM   #2667
WNRacing's Avatar
As good as Andrew's cars looked at Snowbirds...... I wouldn't doubt that one bit.
-Evan Williams
Old 02-07-2013, 10:01 AM   #2668
Default re
Thanks guys, really.
I think I will keep my help focused on this thread and its followers for the time being. I do have a life outside this forum afterall
Please keep in mind, there isn't really anything extremely special about Andrews cars, it just comes down to attention to detail and being thorough with EVERY aspect of the car. If you don't have the basics down(prep), you can't properly test setup changes and you definitely won't know their true effect. Lastly, I am lucky to work on a talented young drivers car, because sometimes, the car isn't as good as it looks, he will just wheel the shite out of it regardless. At the Snowbirds I was fortunate enough to get it right where HE wanted/needed it..
As for wheeling an Xray, I just might, but only to improve our testing program. I use to race years ago, but now I focus on my real car instead.
Old 02-07-2013, 12:03 PM   #2669
Kwikvdub's Avatar
Trader Rating: 90 (100%+)
Send a message via AIM to Kwikvdub
Hey Corey, you use to race Tamiya's??..... and won some big races??.....
..... Just wondering....
Alex Valdes
TQRacing / 360 v2 RC Raceway
Kwikvdub is offline   Reply With Quote
Old 02-07-2013, 12:21 PM   #2670
Adam B's Avatar
Corey, thanks for posting the set up sheets sir. And congrats to you guys on how well you did. You, Andrew, and Ian have always been great to talk to the few times I have raced with you guys.
Did you cut the stock upper deck, or the thin one? Assuming you cut the stock one, would using the 1.6mm top deck give you the same or close to the same result?
Franchise Racing Products * Fantom Racing * Pro One R/C Tires * RC America/Xray * Discount R/C Store * F1 R/C Lab * NORCAR @ The Gate
Adam B is offline   Reply With Quote
Xray T3 2012 rasta_man Electric On-Road 4220 11-09-2016 01:45 PM
RC10B4/T4 Forum DerekL Electric Off-Road 14331 01-01-2016 02:18 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 08:55 AM
Tags
xray t4
