Old 01-30-2013, 09:45 AM   #2566
Forgot about spec tires...
Is tire additives also spec or not used??
I agree with samnelso, his car looked loose from the start. Might help if you can tell us more about his setup. Is he using the basic carpet setup??
Serpenteer is offline   Reply With Quote
Old 01-30-2013, 09:53 AM   #2567
Meradin's Avatar
Trader Rating: 19 (100%+)
I told him to go back to the stock setup before Friday and we can start from there. At one time he did use the stock setup but started to gravitate from it. I think he is getting too far away.
Yes, we can use no-odor compounds like sticky-fingers, which is what I think he is using.
Better than Randy, Adam said so!
Second thought...I don't trust Adams, they make up everything!
"Leave it to Steever", custom paint masks, decals, and paint.
Meradin is offline   Reply With Quote
Old 01-30-2013, 09:58 AM   #2568
bucknuts's Avatar
I had a problem like this as well this week. One of the other fast guys did too, although with an AE TC6. It's not the car. I ran sweep 32s all day. The track was a little loose and .3 slower (~10sec lap) The car would be fine for about the first half of the race then it would get loose. I switched to some old Solaris mediums after the main and it was dialed. Added a little rr toe and it got better, switched front links to middle and it got better (short rear links). So I ordered some new Sweep 32s, Solaris mediums and Jaco Blues this week. I guess all three are needed for different track conditions at the same track?
The times I have had this happen is always when there are a lot of pan cars running. Is it foam buildup on the rubber?
bucknuts is offline   Reply With Quote
Old 01-30-2013, 10:12 AM   #2569
Skiddins's Avatar
If the guys are right about a change of tyres solving their similar problem, could a change of additive solve it?
From what I recall, Sticky Fingers wears off pretty quickly.
Has he tried LRP/Nosram carpet additive.
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 01-30-2013, 12:12 PM   #2570
bucknuts's Avatar
I dont think thats it, I have experienced this with paragon, sticky fingers, and now Sxt, and between cars, new tires and old
Old 01-30-2013, 03:45 PM   #2571
Bigz84's Avatar
Trader Rating: 15 (100%+)
Originally Posted by Adam B View Post
this past weekend I ran and I only had a LTCR and P37. The P37 is regular weight. I did not notice much difference, but the P37 increases steering also. I have to paint up a seed6 and get one ready for my next time racing.
besides Adam, has anyone tried (or is using) the p37 for a T4 and have some feedback, for carpet racing, 17.5 blinky? i know when i ran the LTC, i was not really comfortable driving it on carpet and this was w/ a 11/12. i also tried the p37, but is wasn't for long.
just wondering if the rear end stays planted w/ a p37. i am very close to the box setup, w/ a change here and there.
Radiopost : EA Motorsports : Orca : Reflex Racing/RSD : Wild Turbo Fans : Franchise Racing Products : RCAmerica : Hudy : Xray : Diggity Designs:
Bigz84 is offline   Reply With Quote
Old 01-30-2013, 05:32 PM   #2572
B00t13g's Avatar
A local guy liked it.
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 01-31-2013, 11:38 AM   #2573
roger999's Avatar
Will the plastic shock caps with hole from t4 fit Nt1 shocks?
facebook.com/rogergrafix
roger999 is offline   Reply With Quote
Old 01-31-2013, 12:04 PM   #2574
B00t13g's Avatar
See if the part numbers are the same.
Mackenzie Meyercord
Old 01-31-2013, 01:18 PM   #2575
Regional Moderator
CarbonJoe's Avatar
Todd, I've been running the P37 exclusively for quite a while. Recently, I've been having issues with the rear end getting loose. I have been running new sets of Sweeps I got at the Indoor Champs (multiple sets). I switched to a pair of 3 year old Jaco Blues I've had in a sealed tube and were never used. The car was 100% better, with zero setup changes.
In my opinion, something has definitely changed in the Sweep tires in the past year. At the beginning of the season I was running new sets I got at the 2011 Champs, and the rear was stable. New 2012 sets, the rear was loose.
*** The Gate - Celebrating 7 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 01-31-2013, 01:33 PM   #2576
How much difference does my car do of I make the car wider from 1.75mm to 2mm at front? its only 0.25mm on both sides?
daang is offline   Reply With Quote
Old 01-31-2013, 01:38 PM   #2577
you can drill out some stuff in the dampers or.... make very special higher shock mount....
I don't believe that the lowered center of gravity will be good for handling on asphalt, nice for carpet though.
Old 01-31-2013, 01:41 PM   #2578
trigger's Avatar
^^^^^more front stability. Less ability of steering turn in at corner entry. Will induce a bit more under steer.
Meant for post 2577
Minh Nguyen
[Maclan Racing][Xpert]
trigger is offline   Reply With Quote
Old 01-31-2013, 02:58 PM   #2579
Bigz84's Avatar
yeah, I haven't run sweeps since the champs. Thanks for the feedback. Might have to purchase a lid and give it a try again.
Old 02-01-2013, 12:53 AM   #2580
Any one know where I get hold of some of these T-shox chrome springs that seem to be working well. slightly longer than the std. spring, and appx. 2.7 in weight.
shrek54 is offline   Reply With Quote
Xray T3 2012 rasta_man Electric On-Road 4220 11-09-2016 01:45 PM
RC10B4/T4 Forum DerekL Electric Off-Road 14331 01-01-2016 02:18 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 08:55 AM
Tags
xray t4
