Old 01-26-2013, 05:46 PM   #2506
Originally Posted by maxg123456 View Post
After months of trying to get this car to drive how I want it to, I've almost got to the stage of retiring my T4. The problem I'm having is a very unresponsive steering mid corner and general lack of steering. Every other xray I've owned has very responsive steering through the whole corner, initial and mid. This T4 however is completely different.
I've tried, every spring combo, 2.7fr2.7rr.... 2.5fr-2.5rr.... 2.7fr-2.3-2.6rr.... 2.5-2.8fr-2.5-2.8rr, even harder rear springs than front lol. Bump steer shims upto 4mm, caster 6 deg, graphite arms, harder c hubs, different shock oil, gear diff oil upto 2000 and car still has similar basic feeling of numb mid corner.
Anyone else suffer this?
I've done well, getting the car in A final at EWS in the UK every time I get a chance to race there this season which is usually an open indoor track, but at my own club where its a lot more technical I struggle with setting it to feel nimble and have steering mid corner on hairpins. It's like it's a limosine. Tried even + 0.75 rear blocks and LTC-R shell which just seems to turn in and feel even worse mid corner. The only good improvements I seem to have is with the Subaru Type C body and front gear diff with 1 million oil which is still not where I want the car to be. Any further ideas would be a great help! Thanks.
Another driver from ews that tried the t4 but went back to he's 3 12 that now drives a yokomo hopefully you'll know who I mean if not pm me! had the same issue he felt the car lacked mid/exit steering he described it as unable to go around a corner in a smooth arc!
As I said above he went back to he's 12 and done very well with it now running the yokomo goes even better!
He said it felt to do with the lack of roll or weight transfer. I have felt a couple of times I really need more steering, try running the wheelbase short! It makes it feel a lot faster but my consistency and fastest lap were near identical!
Hagberg struggled at the ets, if u look at the video what little u see of he's car it looked slower in the corners!
Jampot is offline   Reply With Quote
Old 01-26-2013, 06:25 PM   #2507
jlfx car audio's Avatar
Trader Rating: 35 (100%+)
Increase droop end of story problem solved .
Start car F/R with 6mm of up travel and start taking it away until it quits traction roling it really help mine with a smooth cornering feel
Justin & Matt Lyons
Awesomatix USA, EA motorsports, Sanwa, Protoform, Avid, Gravity Rc , TSR!
a800s sanwa m12s
jlfx car audio is offline   Reply With Quote
Old 01-26-2013, 06:37 PM   #2508
syndr0me's Avatar
Trader Rating: 32 (100%+)
Have you tried a gear diff up front with 1 millon?
syndr0me is offline   Reply With Quote
Old 01-26-2013, 06:45 PM   #2509
Mugen10's Avatar
Send a message via Yahoo to Mugen10 Send a message via Skype™ to Mugen10
I have a easy question.
Will the 2011 T3 sway bars work with the T4? I hate to order new swaybars.
Central Kentucky Racing
Xray T4
Mugen10 is offline   Reply With Quote
Old 01-26-2013, 07:57 PM   #2510
yeah they do just lock in the retainers between the bulkheads sto prevent the swaybar from shifting (I am not sure what they're called)
cheapskate.brok is offline   Reply With Quote
Old 01-26-2013, 08:17 PM   #2511
Trader Rating: 57 (100%+)
Something like this?
http://www.nexusracing.com/product_i...oducts_id=2420
PROMODVETTE is offline   Reply With Quote
Old 01-26-2013, 08:36 PM   #2512
B00t13g's Avatar
Rsd offers those in a more attractive package and I'm sure they are cheaper.
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 01-26-2013, 10:27 PM   #2513
Originally Posted by PROMODVETTE View Post
yup
Old 01-27-2013, 01:09 AM   #2514
Yes, I mentioned it in the post. It's still on the car which seems to work better, but its still not right. I even shoved on 50mn cvds at front which helped a tiny bit as well to make it more responsive. Still feels lacking though.
maxg123456 is offline   Reply With Quote
Old 01-27-2013, 01:11 AM   #2515
I have droop set at 5.5 and 4.5 on droop gauges. Surely running that much droop will get it so stuck to the track it will loose even more corner speed?
Old 01-27-2013, 01:17 AM   #2516
Originally Posted by cheapskate.brok View Post
shorten the wheelbase?
I tried it for 2 weeks but I just found it to start twitching around through the chicane so I put back to stock. Surprisingly it didn't do much to the handling. If I tried that on the T3 2012 it would've been very hard to drive but the T4 doesn't change it's frustrating characteristic.
Old 01-27-2013, 04:36 AM   #2517
alloyslash's Avatar
Trader Rating: 19 (100%+)
We did this to mine and it came alive. We moved the rear AND front arms all the way forward, set ride height to 5.4mm, set droop with the chassis on 10mm blocks.
Pemberton SJ27 / Tekin RS / Cooper D4SS 17.5 / EAM 5000 / Futaba 9551 / 17.5lm
Pemberton SJ27 / Tekin RS / Bullet 13.5 / EAM 5000 / Savox 1251 / 13.5 Pro EDM
TLR22 / Tekin RS / D4SS 6.5 / Futaba 9551 / ORCA 6000 /SCMOD,
F14 carpet Oval Chassis too!
alloyslash is offline   Reply With Quote
Old 01-27-2013, 07:17 AM   #2518
pcar951's Avatar
Here's what I changed for better corner finish:
1.3 front bar
2mm ackerman shims
450f 400r oil
kit springs
5.6f 4.8r droop
5.2 RH f&r
22 deg steering travel
Turns very well (even with a spool) yet doesn't lose the rear. JMO
Jim Chapman
PM Hobbycraft | RCAmerica | Xray | Hudy | Reds Racing
pcar951 is offline   Reply With Quote
Old 01-27-2013, 07:31 AM   #2519
Trader Rating: 38 (100%+)
FS: Xray T4 with with Ko Propo one low profile servo. Servo is brand new and so is car basically. Car has very little use, no scratches and only used a few packs on carpet. please advise if I should post this somewhere else. Pls text me at 518-495-0703 or reply.
noworries is offline   Reply With Quote
Old 01-27-2013, 11:32 AM   #2520
1.3 front bar
2mm ackerman shims
450f 400r oil
kit springs
5.6f 4.8r droop
5.2 RH f&r
Interesting... The 2mm I haven't really tested much as my car wanted to snap initially on throttle but I didn't give it much of a chance. 1.3 front bar is too docile but 2mm ackerman I can understand would counteract that.
Xray T3 2012 rasta_man Electric On-Road 4220 11-09-2016 01:45 PM
RC10B4/T4 Forum DerekL Electric Off-Road 14331 01-01-2016 02:18 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 08:55 AM
Tags
xray t4
