Old 01-16-2013, 08:40 AM   #2416
Robertcooper88's Avatar
Trader Rating: 15 (100%+)
Thank you
Originally Posted by Skiddins View Post
Front is 171t and the rear is 63t
DischargeRC.com - Race-Opts MTS T2 - TRINITY FOR POWER
Robertcooper88 is offline   Reply With Quote
Old 01-16-2013, 11:37 AM   #2417
Can anyone explain what angling the front wish bones back does? I.e replacing the front suspension holders spacer with a 2mm from a 1.5mm.
Nathan Wilson is offline   Reply With Quote
Old 01-16-2013, 12:40 PM   #2418
Adam B's Avatar
I think you are talking about pin sweep. With the pins, for lack of a better term "toed out", that is called positive pin sweep. This will cause the car to turn in harder for what I have noticed. Negative pin sweep does the opposite. Basically positive pin sweep is like toe gain into a turn.
Franchise Racing Products * Fantom Racing * Pro One R/C Tires * RC America/Xray * Discount R/C Store * F1 R/C Lab * NORCAR @ The Gate
Adam B is offline   Reply With Quote
Old 01-16-2013, 12:41 PM   #2419
jlfx car audio's Avatar
Trader Rating: 35 (100%+)
Front arm sweep .
I have used it to numb out the steering . It gives it the feel of less steering by making the rear more planted . In slower areas of a track to me it turns tighter (smaller turning radius with shorter wheel base ) but thru chacanes I don't like it makes it seem lazy
When I ran outdoors I used this a lot to gain rear traction and have more steering in slower areas of the track
Justin & Matt Lyons
Awesomatix USA, EA motorsports, Sanwa, Protoform, Avid, Gravity Rc , TSR!
a800s sanwa m12s
jlfx car audio is offline   Reply With Quote
Old 01-16-2013, 12:55 PM   #2420
Yes thats what i mean, but obviously then putting your toe back to your desired setting.
From those two responses i am still unsure as one says more steering and one less
Old 01-16-2013, 01:03 PM   #2421
By placing more weight over the front tires u loose responsiveness in steering by making the tires have to work harder to move the car from left to right . Now at lower speeds it will give more steering cause u shortened the wheel base . And ur removing weight from the rear making it have less weight that can transfer wile cornering which usually helps keep it in line ... now I'm sure theirs a point where u can remove or add too much weight to one end to reverse this thought but I've swept my arms back 3mm ff/1.5mm fr and this concept held true to that extent
Justin & Matt Lyons
a800s sanwa m12s
Old 01-16-2013, 01:12 PM   #2422
erchn's Avatar
I think it makes the car feel more numb at low speed.
erchn is offline   Reply With Quote
Old 01-17-2013, 02:29 AM   #2423
alloyslash's Avatar
Trader Rating: 19 (100%+)
I believe thats what i have on my USGT car, still using EA's Birds setup. BTW thanks for all the help you gave me on my T4 last sunday. Every time you suggested something, it improved my fast lap by .10.
If you have the time this weekend would you be interested in driving my GT car? Its pretty good now, but the rear is washing out in the fast chicane and I have traction additive down both sides of the chassis after the race
Pemberton SJ27 / Tekin RS / Cooper D4SS 17.5 / EAM 5000 / Futaba 9551 / 17.5lm
Pemberton SJ27 / Tekin RS / Bullet 13.5 / EAM 5000 / Savox 1251 / 13.5 Pro EDM
TLR22 / Tekin RS / D4SS 6.5 / Futaba 9551 / ORCA 6000 /SCMOD,
F14 carpet Oval Chassis too!
alloyslash is offline   Reply With Quote
Old 01-17-2013, 05:24 AM   #2424
Adam B's Avatar
Nobody really gave a solid answer to the shock foam question. What does it change with that installed or not?
Old 01-17-2013, 06:03 AM   #2425
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
It adds rebound and traction is what Hagberg has said he feels on his car when testing it.
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 01-17-2013, 06:19 AM   #2426
I'm using a 95% of EA's setup on matts gt car and its working great . That thing is so easy to drive . Almost 2 easy but for a 11yr old setting fast laps every weekend kind of speaks for it self..lol
Justin & Matt Lyons
a800s sanwa m12s
Old 01-17-2013, 06:35 AM   #2427
Team EAM
I worked hard on that setup last year! LOL Mike Haynes helped a lot too at the birds with it. It was super easy to drive for sure but carried great speed!
Matts doing awesome for an 11 year old!
EA
Contact Us
Old 01-17-2013, 06:47 AM   #2428
EA
Lol tks . I removed rear sway bar( with is driving style it got a little loose sometimes when he snatched the wheel) ,and added some droop.
Justin & Matt Lyons
a800s sanwa m12s
Old 01-17-2013, 07:03 AM   #2429
Adam B's Avatar
EA
Is this with it installed?
Old 01-17-2013, 09:51 AM   #2430
Yes... it (the foam) adds rebound (foam takes the place of air inside the cap.)
Justin & Matt Lyons
a800s sanwa m12s
Xray T3 2012 rasta_man Electric On-Road 4220 11-09-2016 01:45 PM
RC10B4/T4 Forum DerekL Electric Off-Road 14331 01-01-2016 02:18 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 08:55 AM
Tags
xray t4
