Old 01-14-2013, 07:02 AM   #2371
Originally Posted by Skiddins View Post
Can anyone tell me the weight of the standard T4 bumper, just the foam section.
Skiddins
4 grams.
Sean B. is offline   Reply With Quote
Old 01-14-2013, 07:54 AM   #2372
Originally Posted by Sean B. View Post
4 grams.
they're really really soft, and wear out magically. I am using CSO ones
cheapskate.brok is offline   Reply With Quote
Old 01-14-2013, 08:17 AM   #2373
jlfx car audio's Avatar
Trader Rating: 36 (100%+)
The RSD bumper is nice also .
Justin & Matt Lyons
Awesomatix USA, EA motorsports, Sanwa, Protoform, Avid, Gravity Rc , TSR!
a800s sanwa m12s
jlfx car audio is offline   Reply With Quote
Old 01-14-2013, 08:52 AM   #2374
Skiddins's Avatar
Mine eventually split all the way though just in front of the plastic brackets and was dragging on the ground under braking making the front end 'skip'
Even though only 5mm thinner than the T3 bumper it felt softer than wool
I have bought a T3 hard foam bumper and have shaved it down to the same thickness as the T4 and drilled some 12mm holes in it to reduce the weight
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 01-14-2013, 08:56 AM   #2375
Meradin's Avatar
Trader Rating: 19 (100%+)
I thought about doing that too but my concern is the "hardness" of the material. There is a lot of crashing in our club racing and my concern is is the hard bumper is too hard and would just transfer the impact to the chassis rather than absorb the energy. Did drillng the holes or cutting it down help soften it a bit?
Better than Randy, Adam said so!
Second thought...I don't trust Adams, they make up everything!
"Leave it to Steever", custom paint masks, decals, and paint.
Meradin is offline   Reply With Quote
Old 01-14-2013, 09:00 AM   #2376
Skiddins's Avatar
How much do they weigh?
I have spent ages trying to balance my car and keep the weight distribution even, I don't want to add another 10g etc and hang it out front as it really does effect handling.
Skiddins
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 01-14-2013, 09:02 AM   #2377
Skiddins's Avatar
Originally Posted by Mera'din View Post
....Did drillng the holes or cutting it down help soften it a bit?
Not really.
I'm considering turning the holes into slots with a Dremel cutting wheel.
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 01-14-2013, 10:41 AM   #2378
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Are the Reflex Racing outdrives wider than the standard Xray items?
Always seemed a waste that the Xray outdrives never used all the available surface area of the blades
Yes, they cover more of the blade than the Xray Aluminum or spring steel outdrives. Similar to the Side Piece units.
Old 01-14-2013, 12:47 PM   #2379
Anyone having problems fitting a speed passion motor without ur rotor hitting the battery? Its not touching it but the gap is around 0,5 mm... The motor is stock out of box. A friend of mine was running a LRP motor and the rotor already was scrubbing against the battery cause of the flex of the car. when is the new motor mount comming?
Big fan of xray quality and never had any problems with the T3 except for those first servo flexing (according to them not, but they made a better one a month later) mounts.
JanE is offline   Reply With Quote
Old 01-14-2013, 01:40 PM   #2380
Default Xray T4 V2
Does anyone know when the Xray T4 V2 will be released? Judging by the pictures of the team drivers cars on the race report on their site i would say this is what was used at the DHI cup this weekend...
Bony85 is offline   Reply With Quote
Old 01-14-2013, 01:53 PM   #2381
syndr0me's Avatar
Trader Rating: 32 (100%+)
All I see on their report is pictures of dudes, no cars.
syndr0me is offline   Reply With Quote
Old 01-14-2013, 02:05 PM   #2382
Meradin's Avatar
where is this report you are referring to.
Old 01-14-2013, 02:10 PM   #2383
It's on www.teamxray.com - has pictures from in the pits of various team drivers and their cars. All the cars however have bodyshells on, which to me is a sure sign they are trying some new parts which are obviously different. Usually when they have pictures from pit tables it's of the cars with shells off, why would they not want to show their product off!
Old 01-14-2013, 02:12 PM   #2384
exactly my thoughts!
And to add to that before this gets out of hand. Im not here to bash xray, cause its still the best car out there in my opinion! but i just wonder how its possible to mount my motor without having it scrubbing against the battery. (see post #2380) .
Old 01-14-2013, 02:16 PM   #2385
erchn's Avatar
My motor (Team Powers) hits the battery. I just dremeled off about 1.5mm from the end of the shaft.
erchn is offline   Reply With Quote
Xray T3 2012 rasta_man Electric On-Road 4227 11-14-2017 05:49 PM
RC10B4/T4 Forum DerekL Electric Off-Road 14337 11-10-2017 08:19 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 09:55 AM
Tags
xray t4
