Old 01-08-2013, 01:47 PM   #2326
jlfx car audio's Avatar
Trader Rating: 36 (100%+)
The diff when spinning around is like a jyroscope. (Stabilizes the role center the higher it is ) closer to center allows the car to lean more quickly while going fast . Think this shows up more the faster u go . This is my thinking anyways .
Justin & Matt Lyons
Awesomatix USA, EA motorsports, Sanwa, Protoform, Avid, Gravity Rc , TSR!
a800s sanwa m12s
jlfx car audio is offline   Reply With Quote
Old 01-08-2013, 01:54 PM   #2327
alloyslash's Avatar
Trader Rating: 19 (100%+)
So longer links = more rotation, shorter = less? When is the next time that you'll be at Thunder? I looked at Paul's latest setup sheet, think it would work for VTA being that I'm much slower speeds and 1550g heavy?
Pemberton SJ27 / Tekin RS / Cooper D4SS 17.5 / EAM 5000 / Futaba 9551 / 17.5lm
Pemberton SJ27 / Tekin RS / Bullet 13.5 / EAM 5000 / Savox 1251 / 13.5 Pro EDM
TLR22 / Tekin RS / D4SS 6.5 / Futaba 9551 / ORCA 6000 /SCMOD,
F14 carpet Oval Chassis too!
alloyslash is offline   Reply With Quote
Old 01-08-2013, 02:06 PM   #2328
Adam B's Avatar
Yes, longer links will make the car roll more. Here is a link to the directions for the new style upper clamps. I can't remember if the instruction manual was so detailed or not. I keep this in my pit bag and refer to it a lot.
http://www.teamxray.com/teamxray/pro...with Adj. Roll
If you use longer links you may need to play with your droop. Running low droop (high # on gauge) will counter act the benefit of the chassis rolling, IMO.
Franchise Racing Products * Fantom Racing * Pro One R/C Tires * RC America/Xray * Discount R/C Store * F1 R/C Lab * NORCAR @ The Gate
Adam B is offline   Reply With Quote
Old 01-08-2013, 02:23 PM   #2329
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
Where your roll centers are in the rear has a difference in diff height too. If your roll center on the arm mounts is high like most setups lower the diff is going to cause some roll-bind because of the angle the drive shafts will be at. I dont like the low diff/high roll center as much.
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | APEX Raceway and Hobbies | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 01-08-2013, 02:52 PM   #2330
Adam B's Avatar
EA
Son of a B!#@*, that is probably why my car felt so funky. I had no way to explain how it felt, I just knew it was not right.
Old 01-08-2013, 03:24 PM   #2331
Bigz84's Avatar
Trader Rating: 20 (100%+)
Adam, lower your rear roll centers to the middle and try again, low rear diff, you will like it. Sorry bro, i didn't know/probably forgot, you were running the high centers..... i thought it locked in the rear of my car at the Gate. probably too much that it caused the rear wheel nut to come loose... loose nut syndrome....
Airtronics/Sawna : EA Motorsports : Orca : Reflex Racing/RSD : Wild Turbo Fans : RCAmerica : Hudy : Xray : Diggity Designs : Team Scream Racing
Bigz84 is offline   Reply With Quote
Old 01-08-2013, 03:43 PM   #2332
alloyslash's Avatar
EA
Are you refering to the +.75 mounts in the kit? I've always run the 0s. Sunday I could pull trigger at pit lane and not let off til the sweeper turn because everytime I would turn a different direction in the chicane the car would slow itself down like i was letting off, but I wasn't. I did find some evidence of the chassis scrubbing the track on the right side only, but thats the side that dips at the end of the str8 and i was hitting it at full speed.
I have 1 more raceday before ThunderJam and I'd like to have some ideas about what to do to free it up in the turns without loosing traction/steering. I need to get the car right so I have a chance at the D Main
Thanks for the link, thats what I need for the whole car That explained everything simply ans understandable.
Old 01-08-2013, 06:18 PM   #2333
What body are you using?
Lycan is offline   Reply With Quote
Old 01-08-2013, 06:27 PM   #2334
I'll be at thunder Sunday hopefully I can get Eric to drive my car and see what he thinks (assuming traction is around what it was in the Hudy race
Justin & Matt Lyons
a800s sanwa m12s
Old 01-08-2013, 06:28 PM   #2335
Chaz955i's Avatar
Good stuff Adam. Printed and in my pit bag.
At The Gate Bizzos
Chaz955i is offline   Reply With Quote
Old 01-08-2013, 06:47 PM   #2336
Alloy I would think u scrubbing speed in chacine is either cause ur over steering the car or car is diffing out cause of the fast change in direction
Justin & Matt Lyons
a800s sanwa m12s
Old 01-09-2013, 03:06 AM   #2337
alloyslash's Avatar
The body is an HPI '68 Camaro with no spoiler, runs in the USVTA class
I will be there also. If you have a spare minute sunday, would you drive my car and give me some input as to what it needs. You may be right, I may be diff'n out because the car appears to "slingshot" once its strait. I bought 4 sets of different springs for it, so I have enough to experiment with.
Question about weight placement. Is it ok to put weight in the front bumper? I've heard that it'll actually make the car plow from some people, and I've also heard that it'll improve steering. I have to add around 100g to the car to be legal
Old 01-09-2013, 05:01 AM   #2338
Sure would love to . Adding weight to front of car will make it a slug thru the turns . It will slow reaction time from left to right and make it less responsive domineering imput, basically taking away steering in entry and mid corner .
U need to have the lead loaded before u start tuning cause 100g will affect set up no matter where u put it , mainally cause it's going to raise cg. Try to stack it around the center I was able to get 42g in my TC and I'm sure I could add 40 more between belt
Justin & Matt Lyons
a800s sanwa m12s
Old 01-09-2013, 06:16 AM   #2339
Adam B's Avatar
I think the diff position changes the center of gravity basically. With running the higher roll centers lowers all the weight in the rear (bulkhead, motor, diff, etc) and not just the diff. That is probably why my car felt good before and has always been planted. The only changes I have made to my initial setup was when grip is low, I put medium rear uprights on. EA made an awesome point about axle angle and binding. If the rear was more like an ECS, there wouldn't be as much issue. I feel so dumb not thinking about that though... Working on cars and trucks (more so trucks) we are always looking at driveline angle as possible vibration issues. Another reason I enjoy touring car, it is the closest thing to a real car we can race as far as geometry and so forth.
Old 01-09-2013, 06:21 AM   #2340
Adam B's Avatar
The T4 in VTA has to be so annoying. My car is is right at the weight for touring car. I would hate to have to add that much weight to this kit. I had a 10 with an Exotek chassis, I stuffed weight all over the place on that thing and the only way to make it legal was running the stupid driver figure. I think I had a whole strip of lead under the belt, weight on the servo, battery, and I had long wires just to be legal. I feel for those running a legal T4 in VTA.
RC10B4/T4 Forum DerekL Electric Off-Road 14338 11-18-2017 04:19 PM
Xray T3 2012 rasta_man Electric On-Road 4227 11-14-2017 05:49 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 09:55 AM
Tags
xray t4
