Old 01-07-2013, 06:57 PM   #2296
Originally Posted by Davin View Post
Thanks for the heads up. Do you know of any us distributors for them? Im willing to try anything at this point
http://www.rudebits.co.uk/product_in...5953af06697067
I hope this link works
Jampot is offline   Reply With Quote
Old 01-07-2013, 07:00 PM   #2297
Regional Moderator
CarbonJoe's Avatar
Stainless steel screws are the second worst choice next to aluminum for RC applications. They are way too soft. Stick with black oxide steel screws, preferably grade 10.9, like those that Tony's Screws sells. Second choice would be something like the Lunsford Fat Boy titanium motor screws.
*** The Gate - Celebrating 7 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 01-07-2013, 07:06 PM   #2298
Originally Posted by alloyslash View Post
The trick to using washers is to either ruff one side up with a dremel/stone, or like I did yesterday, put it on the tip of your finger and drag it across some sandpaper. You have to ruff up the side that goes against the motor mount so it will grip the mount. After I did that I had a few crashes that were 5x as hard/worse than the one that killed it. Once I got knocked clean off the track in turn 1 at the start of the A main, motor didn't move at all. I feel that you are able to get more torque on the screw itself because its not digging into the aluminum mount, the ruff side of the washer is.
I don't want to spoil my orange! If u look at the link posted above this is what I mean. I'm not 100% it will fit but it has a nice load spread capability and button head to really torque it down!
The issue with a washer unless for instance a 1mm, any thinner it will bent and attempt to go into the slot for the screw to move in, the product above ill not collapse because of the design of the sides.
This is a lee Martin product obviously off road legend, if the buggys can be thrown or go mid air to a complete stop of nose diving the triple! And the motor stays put surely this can only work for the ones having issues?
J
Old 01-07-2013, 07:06 PM   #2299
porsche928gs's Avatar
Originally Posted by Jampot View Post
Wow! $7 dollars for two screws
porsche928gs is offline   Reply With Quote
Old 01-07-2013, 07:06 PM   #2300
Trader Rating: 57 (100%+)
Does the LRP radical cooling set fit this car?
http://www.amainhobbies.com/product_...al-Cooling-Set
PROMODVETTE is offline   Reply With Quote
Old 01-07-2013, 07:09 PM   #2301
No u need to chop heat sink in half or run sp mmm motors with wires on the back. There are better options out there.
Old 01-07-2013, 07:12 PM   #2302
If they work its cheaper than 1 spur gear! Replace from wear not motor moving!
I am happy to purchase before advising u guys in the states to ship over as its just adding cost for something that might not work!
But if they don't at least u can sell to ur offroads buddys
Old 01-07-2013, 07:13 PM   #2303
Wow! $7 dollars for two screws I'm 90%sure it will have clearance issues.
Old 01-07-2013, 07:16 PM   #2304
Adam B's Avatar
Default Awesome fan....
Great fan for the price, only special mount required is servo tape
http://shop.franchiseracingproducts....m?categoryId=3
Franchise Racing Products * Fantom Racing * Pro One R/C Tires * RC America/Xray * Discount R/C Store * F1 R/C Lab * NORCAR @ The Gate
Adam B is offline   Reply With Quote
Old 01-07-2013, 07:20 PM   #2305
Essnowyt's Avatar
Send a message via AIM to Essnowyt
These are the screws that are in all my cars.
http://www.teamassociated.com/parts/details/6515/
$1.99 for four items.
Snowy.
Team XRay, RCAmerica, Motiv, Gravity RC, Schacht Design Works.
Drive it, Dont slide it!
Essnowyt is offline   Reply With Quote
Old 01-07-2013, 07:26 PM   #2306
alloyslash's Avatar
Trader Rating: 19 (100%+)
J
The only way the washer is going to try to pull into the slot is if you are using a screw that has a head thats too small. I have .5mm washers under my stock screws, torqued to the moon, been thru 20+ minutes of running and they are still the same as when I installed them. They aren't "digging" into the aluminum, just gripping onto it. I just backed one of them off and there is no marks what so ever in the mount.
I am just throwing an idea his way that worked for me. I had a pro XRay sponsored driver check my car and he said to have washers under the screws.
Pemberton SJ27 / Tekin RS / Cooper D4SS 17.5 / EAM 5000 / Futaba 9551 / 17.5lm
Pemberton SJ27 / Tekin RS / Bullet 13.5 / EAM 5000 / Savox 1251 / 13.5 Pro EDM
TLR22 / Tekin RS / D4SS 6.5 / Futaba 9551 / ORCA 6000 /SCMOD,
F14 carpet Oval Chassis too!
alloyslash is offline   Reply With Quote
Old 01-07-2013, 07:28 PM   #2307
Snowy.
That's a lot more reasonable price to experiment with. So You don't have any clearance problems ?
Old 01-07-2013, 07:28 PM   #2308
Snowy.
Yeah I'm sure it's more the washer really than the screw, the bigger the surface area the better with weight loading.
It was an alternative to try, if he has done so many spurs if this product fits and works it will save him money.
J
Old 01-07-2013, 07:34 PM   #2309
Sorry incorrect if the screw is soft (steel can be soft different grades etc) then the head can bend just as easily, I assume ur .5 washer is not steel. Then on the flip side of this, u can have a real tough screw a soft mount... A do the screw up enough the screw will either a pull the thread on the motor or B sink in the mount! If it sinks it won't move!!
J
Old 01-07-2013, 07:51 PM   #2310
alloyslash's Avatar
Believe it or not, its a 3x5x0.5 aluminum shim. As I said its the factory kit screws. I have all the proof I need sitting here on the table and in the performance on the track yesterday, and there is nothing incorrect that I'm seeing.
Xray T3 2012 rasta_man Electric On-Road 4220 11-09-2016 02:45 PM
RC10B4/T4 Forum DerekL Electric Off-Road 14331 01-01-2016 03:18 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 09:55 AM
Tags
xray t4
SEO by vBSEO 3.5.0
