Old 12-24-2012, 08:00 PM   #2026
nashrcracer's Avatar
R/C Tech Charter Subscriber
Originally Posted by jlfx car audio View Post
Dirla ur fast lap in the main was only .007 faster . Lol that's OK tho I still had another tooth or 2 to spare. Also I noticed in the main at some point I blew out a tire . Think that might have been why my car was edgie near the end of the race .
doesn't matter if it's a inch or a mile......
RC50 As you come into this world, something else is also born. You begin your life, and it begins a journey towards you. It moves slowly, but it never stops. Wherever you go, whatever path you take, it will follow never faster, never slower, always coming. You will run, it will walk. You will rest, it will not. One day, you will linger in the same place too long you will sit too still, or sleep too deep. And when, too late, you rise to go, you will notice a second shadow next to yours. Your life will then be over.
nashrcracer is offline   Reply With Quote
Old 12-24-2012, 08:41 PM   #2027
jlfx car audio's Avatar
Trader Rating: 35 (100%+)
Lol true that.
Justin & Matt Lyons
Awesomatix USA, EA motorsports, Sanwa, Protoform, Avid, Gravity Rc , TSR!
a800s sanwa m12s
jlfx car audio is online now   Reply With Quote
Old 12-24-2012, 11:10 PM   #2028
Chris Adams's Avatar
Default Wow
So I normally dont get on here and hype up a car but today I will. I just finished building the kit and put it down on the carpet. First time out, the car was already as fast as my 2012. On my 3rd pack, I made one change to the setup I was using and went back out. Lap times I was putting down haven't been seen yet in such a consistent manner. I was skeptical that the lack of steering throw would be an issue on our tight carpet track but it was not the case. Very glad to have upgraded from the 12.
TEXASEOS.net, SpeedzoneUSA, RcAmerica, Xray, Hudy, Protoform, Orca, Avid, 2mm Designs
Texas EOS 2016
Chris Adams is offline   Reply With Quote
Old 12-25-2012, 12:16 AM   #2029
B00t13g's Avatar
^ we all know its because of my dialed hole reeming skills! Seriously though the t4 is a very good car and I'm confident that once I get used to it ill be just as fast if not faster than in my yoko.
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 12-25-2012, 07:14 AM   #2030
alloyslash's Avatar
Trader Rating: 19 (100%+)
I could tell something happened. You had maintained a very tight line around the sweeper, especially in heat3 and the AMain, didn't seem that you were 6" off either way. Then towards the end of the main your car started kicking out at the end of the sweeper. I was marshalling there all day, and out of all the cars the T4 was the best looking in that area. Its unbelievable that they were turning that flat at those speeds and maintaining traction lap after lap.
Pemberton SJ27 / Tekin RS / Cooper D4SS 17.5 / EAM 5000 / Futaba 9551 / 17.5lm
Pemberton SJ27 / Tekin RS / Bullet 13.5 / EAM 5000 / Savox 1251 / 13.5 Pro EDM
TLR22 / Tekin RS / D4SS 6.5 / Futaba 9551 / ORCA 6000 /SCMOD,
F14 carpet Oval Chassis too!
alloyslash is offline   Reply With Quote
Old 12-25-2012, 09:42 AM   #2031
Where can I get a set of the adjustable carbon fiber battery holders for my T4 (the "L" shaped brackets)? I have looked everywhere and the only ones that I can find are the Exotek and they require you to drill another hole in the chassis (NOT).
kmags is offline   Reply With Quote
Old 12-25-2012, 09:47 AM   #2032
B00t13g's Avatar
Team sr.
Mackenzie Meyercord
Old 12-25-2012, 09:50 AM   #2033
artwork's Avatar
Trader Rating: 54 (100%+)
Well...The issue with the metal or CF battery mounts can be found during a big side impact. The plastic hooks are designed to brake during an impact to the side. I know this is not the answer you were looking for, but honestly I would either run the plastic hooks (which is what I run) or nothing at all.
I took the adjustable CF mounts off of my Tamiya for this specific reason. Now I just have two servo mounts holding the battery in place and it works very well.
See attached picture for reference:
Xray | Hudy | Sanwa | R1 Wurks | Avid | Protoform | Proline | 2mm Designs
artwork is offline   Reply With Quote
Old 12-25-2012, 11:32 AM   #2034
Check reflex racing . I think he has one . I know he has a battery holding system that locks the battery in without tape
Justin & Matt Lyons
a800s sanwa m12s
Old 12-25-2012, 03:45 PM   #2035
Trader Rating: 38 (100%+)
http://www.teamsr.co/shop/item.asp?item=TSR260
or8ital is offline   Reply With Quote
Old 12-25-2012, 05:20 PM   #2036
They dont fit unless they made t4 versions. The steering assembly is in the way.
Texas EOS 2016
Old 12-25-2012, 07:27 PM   #2037
They fit on my T4 with a really tiny bit of light sanding.
Old 12-25-2012, 07:30 PM   #2038
Old 12-25-2012, 07:46 PM   #2039
Double post.
Old 12-26-2012, 04:35 AM   #2040
jeppesen's Avatar
Hi guys.
I have had the T4 since it came out, but have only run 5 packs with it, so i havent changed anything from the stock set-up, I have been reading 10-12 pages back, and it seems that the most common change is harder linear springs in the rear.
Any other suggestions? I will run it at this track with LRP 13.5 X12 blinky mode. http://www.dhi-cup.dk/
And as a bonus, does blinky mean that boost is not alloved, or any speedo timing? I have a sppedo without boost, but with 20 degree timing.
Thanks alot.
Large scale racing with RS5 Touring car, Sanwa, Savx, Modelsport engines and Shell V-Power
1/10th Racing with RGT R2, Hobbywing, Gens-Ace and Absima.
jeppesen is offline   Reply With Quote
Xray T3 2012 rasta_man Electric On-Road 4220 11-09-2016 02:45 PM
RC10B4/T4 Forum DerekL Electric Off-Road 14331 01-01-2016 03:18 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 09:55 AM
Tags
xray t4
SEO by vBSEO 3.5.0
