Old 12-15-2012, 12:07 AM   #1861
pcar951's Avatar
Trader Rating: 19 (100%+)
Hmmm, one of our local racers brought out his new T4 tonight for club racing. He stripped 2 spur gears over the course of the night.
I was ready to retire one of my 12's for a T4...not so sure now. I hope there's a fix in the works.
Jim Chapman
PM Hobbycraft | RCAmerica | Xray | Hudy | Reds Racing
pcar951 is offline   Reply With Quote
Old 12-15-2012, 02:13 AM   #1862
locked's Avatar
motor mount not tightened enough or evenly?
maybe screws that hold the spur loosened?
motor moved in a crash?
too tight or loose of a mesh to begin with?
My T4 has seen a few thousand laps so far using the same 64pitch spur that I put in when I built the car. I am only running a T4 in 17.5 blinky right now, but if there was an inherent design flaw causing spur gears to strip, I figure I would have noticed it. She's taken a few good hits including one that sheared off a ball stud.
Dave Locke
Team PerformanceHobbies.ca | ORCA RC | Bodies by Brandon | Team Meeting
XRAY T4'15 x2 | XRAY XB4 | XRAY XB8E | XRAY XB8
locked is offline   Reply With Quote
Old 12-15-2012, 02:53 AM   #1863
Skiddins's Avatar
There is;
(1) Build the car properly according to the instructions.
Too many people have put the motor mount in slightly loose (as instructed) but then not tightened it up later in the build. This means that even though the motor is tight the mount can move slightly, particularly in crashes.
(2) Tighten the motor correctly
As mentioned in the last few posts, check the mesh once you've tightened the screws. As the motor mount is quite thick (5mm) you might need to be carefull on which screws mount into the motor. It is possible (depending on the motor) for the screws to actually bottom out in the motor itself before fully tightening onto the motor mount.
I've raced mine almost every week since it came out and haven't #touch wood# broken or bent a single piece of the car.
Skiddins
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 12-15-2012, 07:01 AM   #1864
Jerz616's Avatar
Trader Rating: 49 (100%+)
I have the same spur on my car from when it was built. I have had some really hard hits, and have broken a few c hubs and steering blocks, but have not once stripped a spur. I have washers between the screw and the mount that are quite a bit larger then the crew head and the motor never slips during a crash.
Ryan Gracey
XRAY T4'14/ORCA VXX/ORCA TX 5.0
XRAY XB8'14
Jerz616 is offline   Reply With Quote
Old 12-15-2012, 07:03 AM   #1865
Skiddins you'll find the front motor mount is a tuning aid for flex as stated by xray them selves. I last night stripped a spur, the car in front crashed and I hit him it happened so fast I could of done nothing. I have made some big mistakes and got away with it. I have run 64dp since I started many moons ago and never stripped a spur, so would happily say I know how to mesh it. If it is meshed properly and u don't have any big mistakes I honestly can't see how u could strip a spur. I will say xray spurs are not perfectly round so always check ur motor mesh at different points of the spur.p.s I'm not teaching how to suck eggs when I say this. J
Jampot is offline   Reply With Quote
Old 12-15-2012, 07:22 AM   #1866
ByteStream's Avatar
I've yet to strip a spur .. using 64P, steel washers with steel motor screws.
RCAmerica | Xray | Hudy | KO Propo | Hobbywing HWNA | R1Wurks | BSR Tires
5280 Raceway - www.5280raceway.com
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
ByteStream is offline   Reply With Quote
Old 12-15-2012, 08:00 AM   #1867
jlfx car audio's Avatar
Trader Rating: 36 (100%+)
Ditto ran my car 8 race days and still haven't had to fix one part ...
Justin & Matt Lyons
Awesomatix USA, EA motorsports, Sanwa, Protoform, Avid, Gravity Rc , TSR!
a800s sanwa m12s
jlfx car audio is offline   Reply With Quote
Old 12-15-2012, 09:54 AM   #1868
pcar951's Avatar
Thanks for the re-assurance guys! My T3/12's are really, really good but, I'm gonna try the T4 just cause you all said said so!
Jim Chapman
Old 12-15-2012, 11:03 AM   #1869
Chaz955i's Avatar
Yep, not so sure what is so confusing about this. Hit anything hard enough and a motor can move. This isn't something isolated to the T4.
At The Gate Bizzos
Chaz955i is offline   Reply With Quote
Old 12-15-2012, 12:03 PM   #1870
Johnny Wishbone's Avatar
Originally Posted by samnelso View Post
First, don't ream your arms.
Guess Xray will have to fix page 14 of the instruction manual then
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 12-15-2012, 04:33 PM   #1871
samnelso's Avatar
agreed. Their molds seem consistent. If the arm needs reamed something else is wrong.
Team Associated | Reedy | Airtronics
RC Excitement: Fitchburg, MA | RC Madness: Enfield, CT | Horsham RC
samnelso is offline   Reply With Quote
Old 12-15-2012, 04:35 PM   #1872
Skiddins's Avatar
The nut at the front of the mount may well be a tuning aid, but we all still need to make sure it's done up tight, I'm not saying I will never strip a spur either.
But so far as I can see there is nothing weaker or 'incorrect' about the current design, certainly no more than any of the other mounts we've all used.
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 12-15-2012, 04:41 PM   #1873
I had a cfex photon for about yr and it used the same motor mount design and tho it would bend (his car didn't use a top deck)I neverstripped a gear . And he had a single cf plate holding spur in place... its not the design that's destroying spurs on cars...
Justin & Matt Lyons
a800s sanwa m12s
Old 12-15-2012, 04:41 PM   #1874
Skiddins's Avatar
Put the pivot pin in the wishbone and hold them both in the air by the pivot pin, now try to flick the wishbone, it should should swing backwards and forwards quite a few times.
If it appears to stick at all, the wishbone needs reaming.
If the it does swing free but binds when assemble onto the car, you know it isn't the pin sticking inside the wishbone... look elsewhere.
Skiddins
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 12-15-2012, 06:27 PM   #1875
Davin's Avatar
Trader Rating: 43 (98%+)
The motor mount on this car is a MAJOR design flaw PERIOD!! 3 more spur gears today. Don't tell me I didn't build the car properly either it has been torn down and checked over and reassemble to kit spec 3 times now. I am not the only person with this problem. But yet whenever someone posts on here about it they get told they built the car wrong. Martin Hudy himself said he has had issues with the car eating spurs. My only hope is that they "optimize" the motor mount in the 14. Until then I'm going back to my 2012. Inbox if interested in a T4 all it needs is a spur gear
Davin
Davin is offline   Reply With Quote
Xray T3 2012 rasta_man Electric On-Road 4220 11-09-2016 01:45 PM
RC10B4/T4 Forum DerekL Electric Off-Road 14331 01-01-2016 02:18 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 08:55 AM
Tags
xray t4
