Old 12-10-2012, 02:33 PM   #1846
Skiddins's Avatar
Originally Posted by rafyel View Post
+CSO aluminum "downgrades" (I went back to Composite parts, I didn't like the handling at all)
Looks like a lot of added unsprung weight.
Only ever bought a couple of CSO parts..... total arse gravy!
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 12-10-2012, 03:15 PM   #1847
Lol!!
Jampot is offline   Reply With Quote
Old 12-10-2012, 06:02 PM   #1848
Meradin's Avatar
Trader Rating: 19 (100%+)
Really, I was thinking of getting the 2mm chassis they have for my 11.
Better than Randy, Adam said so!
Second thought...I don't trust Adams, they make up everything!
"Leave it to Steever", custom paint masks, decals, and paint.
Meradin is offline   Reply With Quote
Old 12-10-2012, 06:25 PM   #1849
Yeah, I never intended to drive this car - it was intended to be my trophy with all flashy upgrades to sit in a glass box. I couldn't find a second car in stock and was to impatient to wait eager to experience the feel of the T4. Now I have parts I'll never use again.
As far as aluminum - I installed the black Zeppin Racing upgrades on my T3'12 and it made a very positive difference in corning control in low traction conditions.
Xray T4 2015 /Team Orion R10.1/Scorpion RS-3420 4.5T/RSxone10/Sanwa M12:rx-471
Xray T4 2014 /LRP Flow Worksteam/LRP X20 4.5T/RSxone10/Sanwa M12:rx-472
Xray XB4 /LRP Flow/LRP X20 6.5T/Savox 1251MG/Sanwa M12:rx-471
Durango DEX410v4 /Tekin RSX/Tekin RL 6.5/Savox 1251MG /Sanwa M12:rx-471
rafyel is offline   Reply With Quote
Old 12-11-2012, 02:47 AM   #1850
RC MARKET's Avatar
A+ New Option Parts for T4
RC MARKET is offline   Reply With Quote
Old 12-11-2012, 08:29 AM   #1851
CSO Aluminum Floatable servo mount
Old 12-11-2012, 09:38 AM   #1852
badKarma's Avatar
Send a message via AIM to badKarma Send a message via Yahoo to badKarma
I am not getting free movement on my rear suspension arm on the pivot pin once I fully tighten up the Optional Fine Roll-Center Adjusment (302049-O) to the Lower suspension holder (30244)...would it be ok to place a a 3x1mm composite shim between both to free up the movement or do I have to ream out the arms...i say this because i have total free movment when not tightened...thanks
badKarma is offline   Reply With Quote
Old 12-11-2012, 10:34 AM   #1853
erchn's Avatar
Try starting here.
It's probably the same issue, the rear-forward left side block can twist a little on tightening.
erchn is offline   Reply With Quote
Old 12-11-2012, 11:02 AM   #1854
samnelso's Avatar
First, don't ream your arms.
Start with both suspension holders loose. Tighten one of them as you firmly press the arm against it with your finger (e.g. for the right rear of the car, I usually tighten the back screw first as I squeeze my left thumb on the bulkhead and my left index finger on the arm just in front of the droop screw). Then, tighten the other suspension holder in a similar fashion as you firmly press the arm against it with your finger. The arm will be free. Repeat for the other arm(s).
Team Associated | Reedy | Airtronics
RC Excitement: Fitchburg, MA | RC Madness: Enfield, CT | Horsham RC
samnelso is offline   Reply With Quote
Old 12-11-2012, 11:07 AM   #1855
badKarma's Avatar
Originally Posted by erchn View Post
Try starting here.
Erchn,
thanks man...worked like a charm...
Old 12-11-2012, 03:10 PM   #1856
Good point point it add unsprung weight, and it is good to know
that the composite lower suspension arms are more heavy than other brands.
eded1 is offline   Reply With Quote
Old 12-14-2012, 07:39 AM   #1857
What oil and pistons(how many holes+ diameter) is everyone running in medium to high traction conditions?
And how much chassis scrub/rubber build up on the edges do you have?
I'm asking because I seem to be running way harder oil than anyone else (judging from the setupsheets I saw).
I'm normally running 450 to 500 Much More Oil to get rid of chassis scrub(with 4x1.1mm pistons).
Regards
niemand is offline   Reply With Quote
Old 12-14-2012, 11:49 AM   #1858
Dane's Avatar
Trader Rating: 24 (100%+)
Send a message via AIM to Dane Send a message via Skype™ to Dane
Regards
I read in the Paul L thread that his Cleveland setup gets rid of scrub according to one testimony.
"the big secret is to keep practicing and never get discouraged when taking a good beating on the track" - Paul L
www.toycarracingblog.com
Dane is offline   Reply With Quote
Old 12-14-2012, 11:11 PM   #1859
I've noticed an issue with the new motor mount that may answer why some people have been stripping spurs.
When I first ran the car I stripped a spur within 2 batteries, put it down to perhaps not tightening the motor enough. I replaced the spur and ran the rest of the day without issue (or so I thought).
While going over the car after the days racing I noticed the motor had moved and the pinion was just engaging, luckily it didn't cost me another spur. As I was adjusting the motor after putting the car back together I noticed that there is enough play between the motor screws and the mount that should a screw loosen slightly, there is enough play that will allow the mesh to tighten or loosen significantly. I put this down to the mount being at the bottom of the motor. If this occurred on the original mount it would not have been as much of an issue due to the motor mounting along the motor centreline.
This is mainly to make people aware to be careful when adjusting the motor and to be wary of how the mesh changes as you rotate the motor CW or CCW when adjusting and tightening the screws. I'm thinking of getting some lock washers to ensure the screws don't come loose.
I will also take a bit more notice to see which way the motor wants to rotate so I can hold it that way when I tighten it to remove the tendency for it to rotate and change the mesh should a screw loosen.
He who dies with the most toys wins, if it's a tie, then it's he with the best.
sjh28 is offline   Reply With Quote
Old 12-14-2012, 11:47 PM   #1860
jlfx car audio's Avatar
Trader Rating: 36 (100%+)
I have always (with the T4) pushed my motor towards the chassis making sure the 2 screws were resting on the bottom of mount. I do wish the motor mount slots were just wide enough for screws . Or had special screws to fill gap...
Justin & Matt Lyons
Awesomatix USA, EA motorsports, Sanwa, Protoform, Avid, Gravity Rc , TSR!
a800s sanwa m12s
jlfx car audio is offline   Reply With Quote
RC10B4/T4 Forum DerekL Electric Off-Road 14338 Yesterday 04:19 PM
Xray T3 2012 rasta_man Electric On-Road 4227 11-14-2017 05:49 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 09:55 AM
Tags
xray t4
