Xray T4 '13
#1832
#1834
#1835
for out of the box carpet set up, what shock oils are you guys running front and back? thanks
#1836
Very common with many manufactures. I run muchmore o rings, tamiya's are very good too.
Easiest way to tell if the o rings are any good, before building a new kit keep 1 in clear container for a week and another in shock oil filled container then compare after the 5 to 7 days.
I change them regardless but if u have a new set do it and see actually how bad it is.
I have two set of shocks built and then have not leaked or have air in after 3 months of running, after christmas I shall rebuild both and replace the diafram and o rings dependent of use depends on rebuilt I race a few times a week so 4 months is really good.
#1837
#1838
There are many opinions on this. Some people do every race day, some people do only before a big event, some people (like me) rebuild them on an as needed basis. I use the Losi shock matching tool, and check the shocks from time to time. If there is no leaks, can't hear air inside them, they are still equal from side to side, no reason to fix what isn't broke. What if your car is handling perfect for your driving style, then you rebuild good shocks and your car's handling goes to hell? Even though you may rebuild the shocks exactly the same way every time, they are not always going to feel exactly the same. If it's not broke, don't fix it.
#1839
when i feel d car is not right, i will change the oil...but sometimes its "does" make thing worse...
#1840
I don't recall ever seeing my oil turn black, I run a Losi oil though. Just because oil changes a color, doesn't mean it is bad in my opinion. I am a mechanic on 1:1 scale cars, and if we sold oil changes because the color of a fluid changed I would be so rich! As long as the car feels good still, and there is no leaks or air in the shocks, run it. Granted this is my opinion and people are gonna say rebuild every run. Until an affordable way to check the viscosity of shock oil is developed and people can prove to me that changing shock oil on an extremely regular basis will benefit me, I am sticking to my method.
#1842
Yep, I've seen offroad cars and road cars driven in parking lots that manage to pull a lot of dirt past the shock seals. None of the cars that I drive on carpet ever have oil that looks contaminated when I change it. Typically my shock oil changes happen because I'm changing viscosity, not due to loss of damping from oil degredation.
#1843
I've never re-built a set after every meet. I will rebuild before nationals but not because they need it just so when u put the car down u know the shocks are matched. If u change oil during the day u know they are matched together and u feel the difference. From freshly built to freshly built if that makes sense
Club meets are just put down and drive too much hassell u can loose more time behind a back marker
Black oil: grease, dirt cr@p oil cr@p o rings.
I ONLY use associated I still think its the most consistent and very high quality.
I never have had black oil but only ever run associated as I said but every 4 months I change the o rings.
