Old 12-03-2012, 05:21 PM   #1771
Andy w's Avatar
I need help being talked into or out of buying a T4. Right now I use a T2 09 in 17.5 w/ a exotek chassis and a stock T2 09 for VTA. I would like to upgrade the chassis for 17.5 but don't know if I should go with a used T3 12 or go new with the T4. Both of my T2's treat me well and among the top 2 every week. What am I going to get out of the latest and greatest. Please help as I have money burning a whole in my pocket.
Andy w is offline   Reply With Quote
Old 12-03-2012, 05:22 PM   #1772
bozzplayer's Avatar
Trader Rating: 16 (100%+)
Originally Posted by R Dodge View Post
Well then, learn something new every day!
So what feel are you looking for out of your diff? What surface & grip level is your track?
i tried 1000 weight associated diff oil then i tried 1500 as well, the car feels unstable on my track with the gear diff, i had this same issue with my t3'12 and the ball diff really made a huge difference on my track, we run on carpet thats low to med grip
bozzplayer is offline   Reply With Quote
Old 12-03-2012, 05:25 PM   #1773
bozzplayer's Avatar
Originally Posted by rcnickv View Post
would it fit if you removed the cover on the side of the diff?
no it won't, it almost seems to be sitting a few mm off centre no matter what you try to do.
Old 12-03-2012, 09:48 PM   #1774
CristianTabush's Avatar
RSD066 RSD XRAY/ SPEC R R1 HARD ANODIZED 7075 T6 ALUMINUM SPOOL CUP (1 PC)
These Hard Anodized 7075 T6 Aluminum Spool Cups were designed to be used with Plastic Blades on your XRAY or Spec R Touring Car front Spool. Due to the material these spool cups are nearly as light as plastic spool cups, but are more durable and much stronger.
These spool cups are ideal for stock racing and they also provide increased life of your front blades due to its larger diameter construction.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 12-03-2012, 09:56 PM   #1775
^ Looks like the ones hanulec makes, but without the dimples on the cups.
jjjheimer is offline   Reply With Quote
Old 12-04-2012, 01:26 AM   #1776
I noticed the same thing on the 12 but try running the rear belt looser and front belt tighter, it makes it feel more like a ball diff.
Bb
bucketboy is offline   Reply With Quote
Old 12-04-2012, 01:38 AM   #1777
aussierevo's Avatar
Trader Rating: 14 (100%+)
i'm in the process of the build and having trouble setting the rear stabliser. When I'm lifting the rear arms on one side all works well ie. the other arm rises, but when I go to the opposite side, it fails to rise. I've check and recheck the downstops, check for binding and I'm basically at a loss as to why I can't get each side to rise as intented.
What am I missing, what can re-check to ensure I have right, as I'm at that stage where I'm at a lost.
appreciate any suggestions.
Speed Passion F1.
Hobbywing ESC and Motor, SMC Batteries
Meakin Park Club Member
Team ARGO RC - Like us on Facebook
aussierevo is offline   Reply With Quote
Old 12-04-2012, 01:48 AM   #1778
Skiddins's Avatar
Bb
I received the same advice while racing on Sunday (to do with handling, ball diff's weren't mentioned) and my car was a bit easier to drive once I had tightened the front belt and loosened the rear.
I was told that due to the extra length of the front belt, it takes longer to tighten up on power so you initially get rear drive fractionally sooner.
Skiddins
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 12-04-2012, 01:55 AM   #1779
Skiddins's Avatar
Is the problem with the left side not rising?
You might find that the front pivot block mount on the rear is very slightly twisted as you screw it down. Hold it in position with some pliers or a 5mm spanner (it needs to point slightly inwards at the front).
Skiddins
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 12-04-2012, 02:00 AM   #1780
Skiddins's Avatar
Where can I order some from to go to the UK?
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 12-04-2012, 04:27 AM   #1781
aussierevo's Avatar
Skiddins
thanks for the information. appreciated.
i've given that a go, pulled apart and redone...no luck. it appears as it should with it slighty inwards.
I'll need to take a breather and take a look with fresh eyes as somethings is amiss and it's driving me nuts.
Speed Passion F1.
Old 12-04-2012, 04:47 AM   #1782
I'm having the same issue.
Sean B. is offline   Reply With Quote
Old 12-04-2012, 05:30 AM   #1783
if its not broke dont try and fix it sounds like you are doing ok
rescue119 is offline   Reply With Quote
Old 12-04-2012, 06:04 AM   #1784
Skiddins's Avatar
It always happens on the left as the 'twist' is in the direction of rotation of the screw as you tighten it.
The right side also does the same, but because you actually want that small amount of twist to allow for toe-in, it doesn't matter.
Have you also checked that the pivot pin is not sticking at all inside the wishbone?
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 12-04-2012, 07:13 AM   #1785
Looking to get back into onroad.Its been 5+ years.lol
I'm looking to maybe get a T4.
It seems from what everyone has been posting,the car in kit form is real easy to drive?
What body is everyone using?what should I get?
John Piper is offline   Reply With Quote
Xray T3 2012 rasta_man Electric On-Road 4220 11-09-2016 01:45 PM
RC10B4/T4 Forum DerekL Electric Off-Road 14331 01-01-2016 02:18 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 08:55 AM
Tags
xray t4
