Old 12-03-2012, 07:22 AM   #1756
Fuzzi0n's Avatar
Originally Posted by Sean B. View Post
I just ordered some 1,000,000 from here:
http://www.tqrcracing.com/shop/produ....asp?p_id=3097
At least I hope it's 1,000,000. It has the proper part #, but I think it's a typo on TQ's page when they call it 1,000K
The only place I've found in the states so far that caries anything that heavy.
P.S. It's €XP€N$1V€ $H1T
1000K would be 1000000 in that 1K would be 1000. The part number is the same as the Spec R site for the right one anyway.
Spec-R S1, Schumacher CAT SX3 S1
Fuzzi0n is offline   Reply With Quote
Old 12-03-2012, 07:40 AM   #1757
Yeah, just thought of that. 1000 x 1000
Sean B. is offline   Reply With Quote
Old 12-03-2012, 07:58 AM   #1758
bozzplayer's Avatar
Trader Rating: 16 (100%+)
Originally Posted by Mera'din View Post
I think they took care of that right here...(from the t4 ad)
your right they did mention the new bearing holder, but they should have mentioned if you want to use ball diff option(#305003) that it will not work with the T4 bearing holders, They have it in the manual that option(#305003) can be used, but little to my surprise i didn't know i could not use it without having to order another part to complete the change, and even then I'm guessing as to if i order the t3'12 eccentric Hubs that it will work or fit in the T4 bulkheads
bozzplayer is offline   Reply With Quote
Old 12-03-2012, 12:00 PM   #1759
one thing i forgot to mention is I dont like how the shocks connect at the bottom of the shocks , kinda confused me why and how to get the shock threaded onto the screw that is already in the arm .... or did i miss something or is there a better what?
rescue119 is offline   Reply With Quote
Old 12-03-2012, 12:12 PM   #1760
samnelso's Avatar
The steel ball in the shock eyelet has a hex to accommodate your wrench.
Team Associated | Reedy | Airtronics
RC Excitement: Fitchburg, MA | RC Madness: Enfield, CT | Horsham RC
samnelso is offline   Reply With Quote
Old 12-03-2012, 12:15 PM   #1761
erchn's Avatar
Use a 3mm Allen wrench to screw the pivot ballonto the set screw in the arm.
erchn is offline   Reply With Quote
Old 12-03-2012, 12:15 PM   #1762
Meradin's Avatar
Trader Rating: 19 (100%+)
Yeah, I guess I am not following you. The T4 uses completely different eccentrics, the T3's will not work as the bulkheads are narrower. Wont the T4 eccentrics work on the T3 ball diff? Maybe that is where I am confused.
Better than Randy, Adam said so!
Second thought...I don't trust Adams, they make up everything!
"Leave it to Steever", custom paint masks, decals, and paint.
Meradin is offline   Reply With Quote
Old 12-03-2012, 12:21 PM   #1763
R Dodge's Avatar
You're right. The T4 eccentrics will work with the ball diff. The bearings are the same diameter and the ball diff is the same width as the gear diff. There's no reason why an Xray ball diff shouldn't fit in the T4.
★RCAmerica •Xray •Hudy •Motiv •PROTOform •Gravity •Avid •TQ Wire •Sanwa •BSR •ProLevelRC •2mmDesigns •Timmy★
R Dodge is offline   Reply With Quote
Old 12-03-2012, 12:26 PM   #1764
oh ok thanks guys
Old 12-03-2012, 04:21 PM   #1765
bozzplayer's Avatar
I will take some pics tonight to show you guys, i thought the same as you, they should fit and work fine, but thats not the case with mine.
Old 12-03-2012, 04:49 PM   #1766
bozzplayer's Avatar
so here are some pics, this is my Xray ball diff(#305003) that was used in my t3'12 car
Old 12-03-2012, 05:13 PM   #1767
Skiddins's Avatar
Well, they say a picture tells a thousand words, but you only need two... Your Screwed
You're right, from the pictures it's the actual shape of the diff housing etc that will prevent it from mounting in the T4.
I would suggest going with the gear diff and trying different oils.
A gear diff will be faster anyway.
Skiddins
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 12-03-2012, 05:18 PM   #1768
R Dodge's Avatar
Well then, learn something new every day!
So what feel are you looking for out of your diff? What surface & grip level is your track?
Old 12-03-2012, 05:18 PM   #1769
bozzplayer's Avatar
Skiddins
lol, sorry for all the huge pics(wanted to get a few different shots to show, maybe i was missing something trying to get the diff to fit), it just really sucks as now i feel like i have a paper weight lying in my pit bag.
Old 12-03-2012, 05:20 PM   #1770
rcnickv's Avatar
would it fit if you removed the cover on the side of the diff?
reginafastraxx.com|WCICS
Nick
rcnickv is offline   Reply With Quote
Xray T3 2012 rasta_man Electric On-Road 4220 11-09-2016 01:45 PM
RC10B4/T4 Forum DerekL Electric Off-Road 14331 01-01-2016 02:18 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 08:55 AM
Tags
xray t4
