Old 12-01-2012, 08:22 AM   #1726
jlfx car audio's Avatar
Trader Rating: 35 (100%+)
Soon as more spring rates come out we will be good with new shocks
Justin & Matt Lyons
Awesomatix USA, EA motorsports, Sanwa, Protoform, Avid, Gravity Rc , TSR!
a800s sanwa m12s
jlfx car audio is offline   Reply With Quote
Old 12-01-2012, 09:18 AM   #1727
Jon Williams's Avatar
Originally Posted by syndr0me View Post
Show me on the doll where the blue car touched you.
Wins thread. Can we now close this thread?
Jon Williams is offline   Reply With Quote
Old 12-01-2012, 09:29 AM   #1728
Team EAM
EAMotorsports's Avatar
Trader Rating: 75 (100%+)
Send a message via AIM to EAMotorsports
I have the 30 gram Xray wedge shaped weight in the center of my car and my battery does not get rubbed by the pinion. On the old car if you ran the weight the battery went in much farther than than with just nuts and the battery moved. With this car the weight acts as the "stop" and the battery fits in more snug and doesnt move around much.
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | ProSpec America | Killer Concepts | AVID.
EAMotorsports is offline   Reply With Quote
Old 12-01-2012, 09:31 AM   #1729
Originally Posted by EAMotorsports View Post
I have the 30 gram Xray wedge shaped weight in the center of my car and my battery does get rubbed by the pinion. On the old car if you ran the weight the battery went in much farther than than with just nuts and the battery moved. With this car the weight acts as the "stop" and the battery fits in more snug and doesnt move around much.
I've had the same experience.
Old 12-01-2012, 07:05 PM   #1730
Davin's Avatar
Trader Rating: 43 (98%+)
Having built and raced every Xray chassis ever made. After 4 weeks of running the T4 I have lost all hope in this car. It has done nothing but strip spur gears / loop itself in corners for no reason and several other things 4 SPUR GEARS IN 1 DAY!!!???? This car has taken me from being one of the top 3 in the A every week for to not being able to finish a race. Whether it be do to a spur gear stripping or just pure disgust in the way the car is working. Sorry I just had to vent
Davin is offline   Reply With Quote
Old 12-01-2012, 07:26 PM   #1731
I'll trade a 4yr supply of parts and extras with a top photon (will even throw in some extra spurs ) for ur T4 u despise.... lol
Hell I even have a box kit 2012 I'll trade
Justin & Matt Lyons
a800s sanwa m12s
Old 12-01-2012, 07:53 PM   #1732
Chaz955i's Avatar
I have a T4 as well as a couple other guys I know. No issues with handling or stripping gears. I also didn't hear any reports from the US Indoor Champs about anybody stripping a gear, much less four in one day. Too bad you aren't having good luck with it. So far the best car I've had and that is with a box stock set up. I haven't even started messing with settings yet.
At The Gate Bizzos
Chaz955i is offline   Reply With Quote
Old 12-01-2012, 08:02 PM   #1733
Your experience is definitely different from mine, and some friends.
I'm coming back to TC after 5 years, and its been fantastic out of the box
Sean B. is offline   Reply With Quote
Old 12-01-2012, 08:05 PM   #1734
locked's Avatar
+1
There's at least a half dozen of us around here who are loving the car.
Motor mount a bit too loose or unevenly tightened, maybe? Bent rotor?
Dave Locke
Team PerformanceHobbies.ca | ORCA RC | Bodies by Brandon | Team Meeting
XRAY T4'15 x2 | XRAY XB4 | XRAY XB8E | XRAY XB8
locked is offline   Reply With Quote
Old 12-01-2012, 08:42 PM   #1735
bozzplayer's Avatar
Trader Rating: 16 (100%+)
I had made a earlier post about stripping 3 gears in one day in 2 different t4, but the car is super easy to drive and handled great, i bought some motor guard upgrades from xray,i will give them a try at tomorrows club race, I'm hoping this will solve my stripped gear issue.
bozzplayer is offline   Reply With Quote
Old 12-01-2012, 08:53 PM   #1736
I don't get it ? How does ur spur strip . I've thrown my car off the track entering the sweeper at full tilt against a block wall (3times) and have never stripped a spur ( but I'm sure I will tomorrow now I've said that...)
Justin & Matt Lyons
a800s sanwa m12s
Old 12-01-2012, 08:56 PM   #1737
whiteflagwar's Avatar
I too had the issue with the spur gears. I tried it with thin washers on the motor screws, with thick washers and with no washers. Nothing seemed to work. Eventually, I ditched the washer idea and got a new can for the motor, as the holes in my old can were starting to strip out. With the new can I was able to tighten the screws tight enough to keep the motor from sliding forward and stripping gears.
Cole Liggett
whiteflagwar is offline   Reply With Quote
Old 12-01-2012, 09:22 PM   #1738
RCFREAK's Avatar
Trader Rating: 17 (100%+)
Another racer i know of was going through stripping spurs in one day i think up to 4 spurs. He drove his car like this for 3 races. Looking over his motor finding some excess movement of the motor while comparing it to another car, they found out his motor mount was not tightened down! The instruction manual tells you to NOT tighten the motor plate till later, keep it loose, but he forgot to tighten it back down when the chassis was done. Since then he never stripped a spur again!
Hope this helps!
Arv.
RC AMERICA// EA MOTORSPORTS// KO PROPO// ORCA
RCFREAK is offline   Reply With Quote
Old 12-02-2012, 04:32 AM   #1739
trigger's Avatar
Still on my first spur gear since the build and no issues to report here. I switch back and forth between various 17.5 and 13.5 with a few crashes every race/practice but have yet to chew up any spurs. Sorry to hear about those who are having spur issues. I have spare spurs but luckily haven't had to use them.
Minh Nguyen
[Maclan Racing][Xpert]
trigger is offline   Reply With Quote
Old 12-02-2012, 07:12 AM   #1740
Chaz955i's Avatar
Hope this helps!
Easy enough to forget in the excitement of building a new car.
At The Gate Bizzos
Xray T3 2012 rasta_man Electric On-Road 4220 11-09-2016 02:45 PM
RC10B4/T4 Forum DerekL Electric Off-Road 14331 01-01-2016 03:18 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 09:55 AM
Tags
xray t4
