Old 11-29-2012, 08:04 PM   #1696
hanulec's Avatar
Trader Rating: 25 (100%+)
Does anyone else have a problem with how 'tight' the battery pack is to the motor/pinion?? Would anyone be interested in an altered battery retension system that would allow you to keep the existing 'width' but also move the battery our 1-2mm?
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 11-29-2012, 08:20 PM   #1697
The car is great, but it is a problem.
I had to lengthen the flat spot on the rotor shaft so I could run the pinion backwards, and I also shaved just a little length off the shaft so it wouldn't hit the battery.
I guess that's the price of having everything as close to center as possible.
Sean B. is offline   Reply With Quote
Old 11-29-2012, 08:32 PM   #1698
hanulec's Avatar
what im proposing is a _real_ replacement product to fix this issue. any interest? i know the Stash said he was interested at the local track last weekend..
Old 11-29-2012, 08:58 PM   #1699
defcone's Avatar
Trader Rating: 15 (100%+)
Just dremel the plastic retainer?
defcone is offline   Reply With Quote
Old 11-29-2012, 09:10 PM   #1700
jsr555's Avatar
Trader Rating: 17 (100%+)
Default Blue is better
Interesting....
Xray T4 - Yokomo Bd7-14 - HPI Pro5 - Powered by Hobbywing
HPI RS Pro - HPI Pro 3 - ??
jsr555 is offline   Reply With Quote
Old 11-29-2012, 10:25 PM   #1701
mac853's Avatar
Questions??
Could anybody tell me if NT1's diff's bevel gear are steel or not?
Best regards
mac853 is offline   Reply With Quote
Old 11-29-2012, 10:27 PM   #1702
syndr0me's Avatar
Trader Rating: 32 (100%+)
Originally Posted by eds24 View Post
Blue is better
This makes me want the car. And not because I'm biased toward blue brands, but just that the orange is truly terrible.
syndr0me is offline   Reply With Quote
Old 11-29-2012, 10:57 PM   #1703
ByteStream's Avatar
Hopefully you'll get to see in person at our track soon.
RCAmerica | Xray | Hudy | KO Propo | Hobbywing HWNA | R1Wurks | BSR Tires
5280 Raceway - www.5280raceway.com
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
ByteStream is offline   Reply With Quote
Old 11-30-2012, 01:19 AM   #1704
Skiddins's Avatar
What we need is something that fits where those plastic nuts go in the center of the chassis that just move the lipo out slightly while still fitting under the belts.
Skiddins
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 11-30-2012, 01:37 AM   #1705
Skiddins
Get a bigger dia nut.
Bb
bucketboy is offline   Reply With Quote
Old 11-30-2012, 02:12 AM   #1706
rc-goods's Avatar
Default Zero Force XRay T4 Bearing Kit Set
Zero Force XRay T4 Bearing Kit Set (12pcs) (ZF-E13005)
www.rcgoods.com
rc-goods is offline   Reply With Quote
Old 11-30-2012, 03:12 AM   #1707
rosko's Avatar
I didnt think the orange was that bad until i saw the blue, looks a lot better
rosko is offline   Reply With Quote
Old 11-30-2012, 03:31 AM   #1708
Chrissy C's Avatar
Eds, are those home made lipo holders, if not where are they from?
Skiddins, the 417 uses a small palstic servo post to hold the lipo in place, i think it could work really well for this application - only issue may be the height of the part, its 7~8mm, maybe ok for the rear hole, not sure about the front...
I got mine as part of the Part A set for the TB03.
HTH,
Chris
Chrissy C is offline   Reply With Quote
Old 11-30-2012, 04:27 AM   #1709
Really?
To me, blue is more than played out.
Old 11-30-2012, 05:41 AM   #1710
Remove the nut push a bit of fuel tube over, cut it and glue it. But obviously lipo's are different sizes so u may need to dermal the plastic l's so lipo is not to tight. U only need fractions to clear.
J
Jampot is offline   Reply With Quote
Xray T3 2012 rasta_man Electric On-Road 4220 11-09-2016 01:45 PM
RC10B4/T4 Forum DerekL Electric Off-Road 14331 01-01-2016 02:18 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 08:55 AM
Tags
xray t4
