Old 11-24-2012, 06:07 PM   #1636
haywood's Avatar
Trader Rating: 48 (100%+)
Default Pinion gear
Roche Rapida P12 2015/2016/2017 / Hobbywing / Team Scream / Progressive Rc / Ko Propo / MotivRc / Dri-Fit Mafia /
haywood is offline   Reply With Quote
Old 11-24-2012, 08:38 PM   #1637
RCknight's Avatar
Any word when we will see some option parts?
RCknight is offline   Reply With Quote
Old 11-24-2012, 10:30 PM   #1638
Do people use threadlocker on any of the screws going into aluminum when building the car?
jjjheimer is offline   Reply With Quote
Old 11-24-2012, 10:42 PM   #1639
Mini8 Menace's Avatar
Default What size spur gear
What size pinion gear is what I meant to say
I currently run on carpet and I'm unsure of what pinion size I should get the track is small to medium and usually technical Just not sure what to start out with just finished my build and I will buy a bunch of sizes
TD DEX408, DEST210R, TA B44.1/upgraded to .2, XRAY T4 (in build), mini8, bashers
Airtronics LRP Tekin Revtec Orion Hi-Tec Futaba Savox Trinity CRGraphics
Mini8 Menace is offline   Reply With Quote
Old 11-24-2012, 11:39 PM   #1640
b_recliner's Avatar
Trader Rating: 22 (100%+)
I use a smidge of threadlocker on all screws that are going into metal.
Tracks: Richfield Raceway, LCRC, DRP
Current Cars: Xray t4 '14, Schumacher Cougar KF, Schumacher Mi5, Losi 22 2.0, Losi 8ight E 3.0
b_recliner is offline   Reply With Quote
Old 11-24-2012, 11:48 PM   #1641
Nope, you should never do that. You will end up with stripped screws etc. just check screws every race at first until they are all seated.
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 11-25-2012, 01:13 AM   #1642
trigger's Avatar
We will need a bit more info like what motor you plan on running and what size spur gear whether it be 48 or 64 pitch to get you somewhere in the ball park.
Minh Nguyen
[Maclan Racing][Xpert]
trigger is offline   Reply With Quote
Old 11-25-2012, 05:41 AM   #1643
Regional Moderator
CarbonJoe's Avatar
Yes, but see below.
I only use it on screws that I seldom remove, like the screws holding the bulkheads from the bottom side of the chassis. Stuff that gets removed often (like everything on the top side of the car), no.
*** The Gate - Celebrating 7 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 11-25-2012, 10:43 AM   #1644
Default More specs
I'll be running a 17.5 I will be running a 48 pitch and for right now the stock spur gear which is a 78t and will go from there just need a few sizes to get just need to know how it feels
Old 11-25-2012, 12:16 PM   #1645
Originally Posted by CarbonJoe View Post
Yes, but see below.
Still not the best idea, if the chassis gets a tweak in it you will need to slacken these off slightly.
Mb3195 is offline   Reply With Quote
Old 11-25-2012, 12:48 PM   #1646
Default What size Pinion gear
Originally Posted by Skiddins View Post
No, the T4 rear posts are 10mm closer together so it's best to put them on the back;
Hey you seem to be the best person to ask on here right now I just got done building my T4 and I am wondering what sizes of pinion would be good to start out with I am running a 17.5 stock spur 78t and 48p I run on carpet it is small to medium and technical if you could help thanks
Old 11-25-2012, 01:29 PM   #1647
mac853's Avatar
Questions??
Hello everyone!
In fact i wonder to buy 7075 drive axle and alu spool outdrive from R1wurks.com
Could somebody tell me if this site is reliable or not?
In fact i can't even his company address
Best regards
mac853 is offline   Reply With Quote
Old 11-25-2012, 02:07 PM   #1648
erchn's Avatar
Note, the stock spur is a 84t spur, not 78, but assuming you have a 78.
Assuming non-boost mode:
TC: FDR for 17.5 non-boost
http://www.rctech.net/forum/electric...l#post11344227
So, you might want to get to a 4.0 FDR, according to a previous Skiddins' posting, we was only able to get to 4.56 (84/35*1.9). Using a 78t spur, which I think will allow you to get to around a 37 pinion (78/37*1.9) you can get to 4.0. If you need lower than 4.0, you'll need a smaller aftermarket spur.
If I were you I would start around 4.4 (33 or 34 pinion) on your 78 spur, then work your way up to a 37 checking temperatures.
erchn is offline   Reply With Quote
Old 11-25-2012, 02:23 PM   #1649
Default Thanks You're right it is a 84 pitch
Thanks man for getting me in the right direction you are right it is an 84 that I'm running stock so what would be a good size for that to start out with
Old 11-25-2012, 02:29 PM   #1650
Skiddins's Avatar
Yet more racing at Newbury (13.5 open), same layout and track as Friday but this time filmed on a headcam, fastest lap improved by 0.23s, probably due to the extra grip;
Cars 1,3,4 & 6 Are Xray T4's
Car 2 is Awesomatix
Car 5 is a Yokomo BD7
Cars 7 & 8 are Schumacher Mi4's (not sure which variants)
The Mi4's had similar setups though I believe the pole sitter had returned to kit rear springs.
+ YouTube Video
Xray T4'16, T4'14 (Wet Car)
Xray X12 2016
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Xray T3 2012 rasta_man Electric On-Road 4220 11-09-2016 02:45 PM
RC10B4/T4 Forum DerekL Electric Off-Road 14331 01-01-2016 03:18 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 09:55 AM
Tags
xray t4
