Old 11-18-2012, 01:57 AM   #1591
Originally Posted by racer x 1 View Post
More often than not thats when the car is quickest when its on edge. Its fairly easily to "back off" set up wise when the car is fast and teaction rolling.
Traction rolling never makes the car faster and never puts the car on edge in the right way, having to back off if your car is about to roll will slow you down much more than having a car that doesn't roll in the first place.
Traction roll is easy to achieve - give yourself a 10mm ride height for a start - will that be quicker than a 5mm ride height?......NO!
Gaining more steering is quite easy, but normally it is not what you do with the front end, it is what you do with your back end that increases this. Examples being higher your real roll centre, stand your rear shocks up, stiffen rear roll bar - making the rear end more loose will always give more front end steering.
It also depends on where you want the steering with what setup change to make, if it is more initial steering you may stiffen the front springs, if it is coming out of the corner you may soften the front springs - it is always a compromise on setup. Another example would be gear diff oil - lighter makes the car rotate quicker, heavier gives more on power steering.
If you are running the kit setup and want more steering, the first thing I would do would be change the oil all round to 400cst and change the rear springs to match your front springs, run with more bump steer (up to 3.5mm) and also run more camber on the front than the rear.
You will then have plenty of steering!
Mb3195 is offline   Reply With Quote
Old 11-18-2012, 07:23 AM   #1592
How are you drifters liking it?
Breitling is offline   Reply With Quote
Old 11-18-2012, 10:08 AM   #1593
Dan
Dan's Avatar
Trader Rating: 47 (100%+)
I don't think anyone really buys a T4 to go drifting.... and if they had enough money, there are better options. Besides, the steering is limited to 25 degrees, hah.
Dan is offline   Reply With Quote
Old 11-18-2012, 12:16 PM   #1594
locked's Avatar
Just use a stack of spacers with a smaller outer diameter on the center ballstud and you could achieve more than 25 degrees, but you don't need that for racing. It's a race car. Best one I've owned so far.
Dave Locke
Team PerformanceHobbies.ca | ORCA RC | Bodies by Brandon | Team Meeting
XRAY T4'15 x2 | XRAY XB4 | XRAY XB8E | XRAY XB8
locked is offline   Reply With Quote
Old 11-18-2012, 12:35 PM   #1595
Skiddins's Avatar
Originally Posted by Dane View Post
From what I can see the faster cars are beating you in the 2nd half of the infield. From the start to the short straight all the way thru the infield they are smooth. You throw it in the corner and the car stops kinda rather than maintaining consistent motion.
Sounds about right.
When I try to drive far more smoothly, my lap times just aren't as good
Some of it is very slight setup tweaks (which I haven't yet found) to give grip in certain places on the track etc.
Skiddins
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 11-18-2012, 02:03 PM   #1596
Originally Posted by Skiddins View Post
Sounds about right.
Skiddins
Come on Skiddins, pull your finger out mate, Chris should be easy to beat, he is not known as a carpet specialist
bucketboy is offline   Reply With Quote
Old 11-18-2012, 02:24 PM   #1597
Skiddins's Avatar
It's not the lack of carpet speciality that causes concern.
It's the '5 times in succession British Modified Touring Car Champion' bit that suggests his repeated kicking of my arse on carpet is more than simply luck
Skiddins
P.S. Beat him the last two weeks, (we'll ignore the fact that car failure and poor driving from others more than helped)
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 11-18-2012, 02:43 PM   #1598
bozzplayer's Avatar
Trader Rating: 16 (100%+)
drove the cars today in both 17.5 blinky and 17.5 boosted, they where both very easy cars to drive, only problem i was having today was that i stripped 2 gears in total between both cars, no big crashes or hits that should cause my gears to strip, but they did. Is anybody else having this issue?
bozzplayer is offline   Reply With Quote
Old 11-18-2012, 03:07 PM   #1599
Skiddins's Avatar
I haven't, but check that the motor screws are not bottoming out in the motor before they tighten properly on the motor mount.
Skiddins
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 11-18-2012, 03:19 PM   #1600
A win is a win
Old 11-18-2012, 03:56 PM   #1601
Haven't experienced any spur gear issues here. Early on I installed washers behind the motor screws to secure the motor with more surface area so the screws don't gouge up the aluminum on the mount. I like the idea I can really torque the screws down and not have to worry about ruining the aluminum and worst, not tightening the motor down fully.
Minh Nguyen
[Maclan Racing] [Xpert Servos]
trigger is offline   Reply With Quote
Old 11-18-2012, 04:24 PM   #1602
Well after some not so great driving last weekend I bent my motor mount.. Didn't notice until I went racing yesterday and was wondering why the pinion wasn't straight.. It took a 0.5mm shimm to bring the motor out enough to make it anywhere near straight.
Will the t3 motor guard fit the t4? And is there a better designed motor mout available that wont bend like rubber?
Carpet: Tamiya M05V2 R
Asphalt : Tamiya M07 , Xray T4'17
d.k.vmatt is offline   Reply With Quote
Old 11-18-2012, 04:29 PM   #1603
Skiddins's Avatar
Yes, and don't know
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 11-18-2012, 04:33 PM   #1604
Skiddins's Avatar
Well, my final in 13.5open from EWS today (Sorex 32JB's).
+ YouTube Video
Again, carpet setup, except;
2mm bump steer.
2000cSt rear diff
2.7 rear springs in hole 2
2.3-2.6 rear springs were just OK early on but as grip improved they started to make the car a little tail happy through chicanes.
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 11-18-2012, 05:26 PM   #1605
Josh-n-ya's Avatar
Trader Rating: 75 (100%+)
You guys should give yourselfs more credit driving with stick controls. I couldnt do it at those speeds.
Josh-n-ya is offline   Reply With Quote
RC10B4/T4 Forum DerekL Electric Off-Road 14338 Yesterday 04:19 PM
Xray T3 2012 rasta_man Electric On-Road 4227 11-14-2017 05:49 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 09:55 AM
Tags
xray t4
