Old 11-17-2012, 10:22 AM   #1576
Originally Posted by bucketboy View Post
adjust your ackerman so the outside wheel turns more, reduce castor, reduce front camber, remove anti roll bar,soften front shocks, stand them up more that should get your car to roll over..........why you would want to is another quetion!
Bb
interesting...it hit me in the head right there. I'd go for that, then tune out traction gradually...instead of starting with no traction and fighting to get some
cheapskate.brok is offline   Reply With Quote
Old 11-17-2012, 10:24 AM   #1577
racer x 1's Avatar
Trader Rating: 27 (100%+)
Bb
More often than not thats when the car is quickest when its on edge. Its fairly easily to "back off" set up wise when the car is fast and teaction rolling.
Matt Bell
Mugen MRX5 Ae R5.2 X6^3 M11x All powered by Speedtech Rc
racer x 1 is offline   Reply With Quote
Old 11-17-2012, 11:06 AM   #1578
jlfx car audio's Avatar
Trader Rating: 35 (100%+)
What shims where give u more or less outside tire angle ? Coming from top its a new tuning option for me
Justin & Matt Lyons
Awesomatix USA, EA motorsports, Sanwa, Protoform, Avid, Gravity Rc , TSR!
a800s sanwa m12s
jlfx car audio is offline   Reply With Quote
Old 11-17-2012, 12:05 PM   #1579
Meradin's Avatar
Trader Rating: 19 (100%+)
Bb
The above posts answer this for me. Yeah, I like it start a too much traction and then detune it from there. I find it easier that way rather than start and blindly shoot as I normally do for more traction.
Adding more shims to the rack should net me more initial. Just looking to get rid of the push and get on edge.
Better than Randy, Adam said so!
Second thought...I don't trust Adams, they make up everything!
"Leave it to Steever", custom paint masks, decals, and paint.
Meradin is offline   Reply With Quote
Old 11-17-2012, 01:09 PM   #1580
Traction rolling doesn't mean your car is on the edge or that its quick, all it means is your car is rolling over before your tryes loose traction, bad set up. put you castor blocks on the wrong way around and you will not be fast but you will be on your roof more than on your wheels.
Its easy to get it to roll, its a lot harder to get it to go around the corner fast.
bucketboy is offline   Reply With Quote
Old 11-17-2012, 02:31 PM   #1581
Skiddins's Avatar
Another night of indoor testing with 13.5 open.
This time ran 2000cSt in the diff and 2.7 rear springs in hole 2.
Apart from that kit setup;
+ YouTube Video
Forgot to say, blue car with yellow and Orange, Q8th
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 11-17-2012, 02:46 PM   #1582
+ YouTube Video
And what did you think ?? better / worse. How was the 2000 cst in the rear
XRAY T4 Hobbywing V3 Sanwa
FLAT OUT is offline   Reply With Quote
Old 11-17-2012, 04:35 PM   #1583
Skiddins's Avatar
Originally Posted by Mera'din View Post
Still looking for a bit more turn in (initial steering?) as the car pushed a bit. Funny thing is I cannot get this car to traction roll
Try some settings to get a bit more initial steering and help increase your corner speed etc.
Trying to make your car grip roll is total lunacy, I bet you won't get any top drivers trying to achieve that!
Skiddins
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 11-17-2012, 04:37 PM   #1584
Skiddins's Avatar
The 2.7 springs did help make the car a bit more aggressive, but it was twitchy until the grip started to come or we had warmed the tyres properly (we are allowed 60-90 secs of warm up laps.
I think the thicker diff oil just makes the car a bit easier to drive.
Will be at a bigger carpet meet tomorrow using Sorex 32JB's.
Will hopefully film some of that as well.
Skiddins
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 11-17-2012, 04:58 PM   #1585
Adam B's Avatar
Default HELP!
I seen people post complaining about pinion issues. I have the epic/trinity pinions. In order for it to fit, I put the pinion on backwards which makes getting to the grub screw even harder. Did I do something wrong, is it the pinions, or what?
Adam B is offline   Reply With Quote
Old 11-17-2012, 05:31 PM   #1586
Meradin's Avatar
Skiddins
I agree and it maybe my misunderstanding of what traction rolling is. What settings would give more initial steering.
Old 11-17-2012, 06:08 PM   #1587
Jerz616's Avatar
Trader Rating: 49 (100%+)
No. It is just the design of the car. The hole in the bottom is designed for the xray pinion. I have mine turned around also and just get at it from the top with the tool almost parallel with the top deck. Its actually not all that hard really
Ryan Gracey
XRAY T4'14/ORCA VXX/ORCA TX 5.0
XRAY XB8'14
Jerz616 is offline   Reply With Quote
Old 11-17-2012, 06:26 PM   #1588
waOscar's Avatar
I'm running my pinion backwards also, I've been loosening off the motor screws, tighten down pinion and then tighten motor and adjust mesh. I'm lining up the end of the pinion with the end of the motor shaft and getting about 2/3rds of the pinion running on the spur. working ok for me
Xray T3 2011 - my asphalt chassis
Xray T3 2011 - my carpet chassis
waOscar is offline   Reply With Quote
Old 11-17-2012, 08:06 PM   #1589
Adam B's Avatar
Thanks guys!
Old 11-17-2012, 08:30 PM   #1590
Dane's Avatar
Trader Rating: 24 (100%+)
Send a message via AIM to Dane Send a message via Skype™ to Dane
Skiddins
From what I can see the faster cars are beating you in the 2nd half of the infield. From the start to the short straight all the way thru the infield they are smooth. You throw it in the corner and the car stops kinda rather than maintaining consistent motion.
"the big secret is to keep practicing and never get discouraged when taking a good beating on the track" - Paul L
Dane is offline   Reply With Quote
Xray T3 2012 rasta_man Electric On-Road 4220 11-09-2016 01:45 PM
RC10B4/T4 Forum DerekL Electric Off-Road 14331 01-01-2016 02:18 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 08:55 AM
Tags
xray t4
