Old 11-16-2012, 10:22 AM   #1546
Originally Posted by artwork View Post
There is nothing to stare at...it is a piss poor design. The word on the street is that I guess that design works well with Xray pinions, but that is silly. Who can afford to buy even one Xray pinion let alone a whole set.
The work around to to remove the motor and tighten up and or replace the pinion with that method. Luckily, you can get the motor out with the motor mount being so low, but seems pretty silly to not consider that other people could possibly use other types of pinions.
The only thing thats "faulty" designwise is the hole in the chassis for tightening the grub screw of the pinion.
The motormount as well as installing pinions (non Hudy ones here as well) works just fine for me.
Just out of curiosity: how are your pinions shaped for not working with the motormount?
niemand is offline   Reply With Quote
Old 11-16-2012, 10:31 AM   #1547
you guys never run a tt01...now thats a bitch
rescue119 is offline   Reply With Quote
Old 11-16-2012, 10:34 AM   #1548
Meradin's Avatar
Trader Rating: 19 (100%+)
I will take some pics when I get home. I am running Robinson pinions and the xray off set spurs. There is no way to get to the grub screw from the bottom and no direct way from the top. I could see getting the job done from the top with a ball tip possibly but I don't have one that small.
Better than Randy, Adam said so!
Second thought...I don't trust Adams, they make up everything!
"Leave it to Steever", custom paint masks, decals, and paint.
Meradin is offline   Reply With Quote
Old 11-16-2012, 10:38 AM   #1549
Suspended
The T4 looks like a nice peice of machinery.
Team__Evil is offline   Reply With Quote
Old 11-16-2012, 11:01 AM   #1550
artwork's Avatar
Trader Rating: 56 (100%+)
+1
I am using epic pinions. I know they are very very rare and forged in the mountains of Tibet by monks with specially designed Lhasa Apso's bones as tools, but I figured they might work on this car since they work on every other f*in car on the planet. According to the report from Martin they tried hundreds of motors, thousands of different types of servos, millions of different types of body clips, but I guess pinions did not make the list. Good news is that my current body clips are in fact working perfectly. No clearance issues there!
Seriously, The issue is that the set screw ends up too close to the motor which blocks the access from above and below. It is something I will figure out how to deal with, but this is one item they did not coptimize very well. Maybe a rubber Hudy hex wrench made from nano technology might be in order to solve this mystery of the ages.
Xray | Hudy | Sanwa | R1 Wurks | Avid | Protoform | Proline | 2mm Designs
artwork is offline   Reply With Quote
Old 11-16-2012, 11:41 AM   #1551
syndr0me's Avatar
Trader Rating: 32 (100%+)
You should go ahead and invest in some XRay pinions. They generate more grip.
syndr0me is offline   Reply With Quote
Old 11-16-2012, 12:07 PM   #1552
jlfx car audio's Avatar
Trader Rating: 35 (100%+)
I have had no problem with pinions . I go thru top deck with long Hudy 1.5 mm and works fine .
Justin & Matt Lyons
Awesomatix USA, EA motorsports, Sanwa, Protoform, Avid, Gravity Rc , TSR!
a800s sanwa m12s
jlfx car audio is offline   Reply With Quote
Old 11-16-2012, 12:35 PM   #1553
artwork's Avatar
are you using this one?
Old 11-16-2012, 12:47 PM   #1554
Jon Williams's Avatar
Jon Williams is offline   Reply With Quote
Old 11-16-2012, 01:32 PM   #1555
bucknuts's Avatar
I also get to it through the top deck. In thinking about grinding a groove in my nice Hudy wrench to help fully seat it.
bucknuts is offline   Reply With Quote
Old 11-16-2012, 02:01 PM   #1556
jsr555's Avatar
Trader Rating: 17 (100%+)
I apologise if already listed or asked, but is there somewhere I can find out what T3 parts wont work on the T4.
thanks
Xray T4 - Yokomo Bd7-14 - HPI Pro5 - Powered by Hobbywing
HPI RS Pro - HPI Pro 3 - ??
jsr555 is offline   Reply With Quote
Old 11-16-2012, 03:13 PM   #1557
jsr555's Avatar
thanks
Stop looking I found it...
Sway bars.. Are they different between T3 and T4
Old 11-16-2012, 03:21 PM   #1558
Crap, I think I messed up gluing the chassis.
I got a bit overzealous and glued some other screw holes, but the CA dried lumpy. How do I clean the bevel of the countersunk screw holes?
Preferably without doing more damage?
jjjheimer is offline   Reply With Quote
Old 11-16-2012, 03:36 PM   #1559
locked's Avatar
I haven't tried this, but it might work. I just thought of what I might try if it happened to me.
poke a small hole in a piece of sand paper. Put a countersunk screw through the hole from the back. use hex driver to hold the screw in the hole and then wiggle the sandpaper back and forth, maybe while also turning the screw in sync.
Just an idea...good luck
Dave Locke
Team PerformanceHobbies.ca | ORCA RC | Bodies by Brandon | Team Meeting
XRAY T4'15 x2 | XRAY XB4 | XRAY XB8E | XRAY XB8
locked is offline   Reply With Quote
Old 11-16-2012, 03:51 PM   #1560
I think that will work or even CA a piece of sand paper to a screw and use a wrench or drill to spin it . Btw I glued all my chassis holes with a qtip and thin CA worked great
Justin & Matt Lyons
a800s sanwa m12s
Xray T3 2012 rasta_man Electric On-Road 4220 11-09-2016 01:45 PM
RC10B4/T4 Forum DerekL Electric Off-Road 14331 01-01-2016 02:18 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 08:55 AM
Tags
xray t4
