Old 11-11-2012, 12:50 AM   #1486
Originally Posted by bucketboy View Post
helps stops screws rusting
Oh, thanks.. do they have any practical use after the bags are cut open?
jjjheimer is offline   Reply With Quote
Old 11-11-2012, 04:16 AM   #1487
How much rubbing do you guys allow? None?
built as per kit
5mm ride height front
5.5-6 rear
5mm downstops/droop all around
and i am rubbing slightly on the motor side, it is a fast sweeper at the end of the straight causing it i guess.
the car is fast & giving great lap times
Shortbusallstar is offline   Reply With Quote
Old 11-11-2012, 06:25 AM   #1488
Regional Moderator
CarbonJoe's Avatar
Originally Posted by jjjheimer View Post
Building my first XRay.. what are those little brown square papers in each parts pack? Looks like sandpaper..?
A luxury, optimized version of a desiccant. They absorb moisture.
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 11-11-2012, 06:57 AM   #1489
built as per kit
5.5-6 rear
As long as it's fast I wouldn't mind. Especially when it's only one corner.
I only do something against it when I notice that it slows me down (in the last minutes of the run).
But normally I allow the car to rub enough for a slight build up of rubber on the edges of the chassis.
niemand is offline   Reply With Quote
Old 11-11-2012, 07:13 AM   #1490
Jon Williams's Avatar
Okay, that was funny.
Jon Williams is offline   Reply With Quote
Old 11-11-2012, 05:30 PM   #1491
XSLR8's Avatar
It's a little paper towel to wipe the sweat of your forehead at each stage of the build,xray really do think of everything....
VBC Racing Australia.....FUTABA AUSTRALIA.....Volante tires.....WTF Fans.....R.A.B Hobbies....President www.serccc.com.au
XSLR8 is offline   Reply With Quote
Old 11-11-2012, 05:59 PM   #1492
Potoczak's Avatar
Trader Rating: 111 (100%+)
Hahaha that was good!!
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 11-11-2012, 08:58 PM   #1493
jlfx car audio's Avatar
Trader Rating: 36 (100%+)
Ran mine today . I'm happy to say, the only issue I had was the loose nut behind the wheel . Tho I did run better than ever before . Have me a new airtronics MT-4 coming ,was having a glitch with a full grid in the main...
@ thunder Rc in Nashville (med-high traction)
Changes made from kit :
Went to high role center in rear
-2.25 rear camber
-1.75 front camber
0 toe in front
1500cst in rear diff
300,000wt in front diff
Justin & Matt Lyons
Awesomatix USA, EA motorsports, Sanwa, Protoform, Avid, Gravity Rc , TSR!
a800s sanwa m12s
jlfx car audio is offline   Reply With Quote
Old 11-11-2012, 10:57 PM   #1494
Dan
Dan's Avatar
Trader Rating: 45 (100%+)
Just need to paint the body! Don't make fun of my battery, it works well.
I have the Yeah Racing Tornado fan too. Its a good fan, but I had to mount it on some spare lexan and used the motor guard holes to secure the lexan piece. Temporary until I find something more secure.
First time building a new Xray, went together very well. Slight weepage on the diff but I think I may have dislodged that super thin O-ring when putting together the diff. Swapped in the thicker bumper, T2 bumper hardware. Running the asphalt setup but front seems very soft still...
Dan is offline   Reply With Quote
Old 11-12-2012, 12:59 AM   #1495
Originally Posted by Dan View Post
[IMG]
Screw an Xray servo post into the spare hole in the laysaft mount, fix the fan to that, it won't budge
bucketboy is offline   Reply With Quote
Old 11-12-2012, 02:45 AM   #1496
or shoegoo the fan directly onto the chassis. Always works well and easy to remove if needs be!
Smartypants is offline   Reply With Quote
Old 11-12-2012, 03:05 AM   #1497
servo post is definitely the best option - cant move unless you want it to!
Mb3195 is offline   Reply With Quote
Old 11-12-2012, 05:33 PM   #1498
RMKinWI's Avatar
Trader Rating: 15 (100%+)
Anyone have a picture of this?
Matthew Lust
www.WisconsinSurplus.com
RMKinWI is offline   Reply With Quote
Old 11-12-2012, 05:52 PM   #1499
Josh-n-ya's Avatar
Trader Rating: 73 (100%+)
Cant wait to see it up close! You racing next week! the 18th
Josh-n-ya is offline   Reply With Quote
Old 11-12-2012, 05:57 PM   #1500
Josh-n-ya's Avatar
Question, I have an 2011 version and am looking to get more rear side bite. What are some tips? thanks
Xray T3 2012 rasta_man Electric On-Road 4220 11-09-2016 01:45 PM
RC10B4/T4 Forum DerekL Electric Off-Road 14331 01-01-2016 02:18 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 08:55 AM
Tags
xray t4
