Like Tree2Likes
Old 08-28-2013, 10:12 PM   #436
Erik, the Awesomatix shaft is extremely flexible: easily flexed with your fingers in the middle.... I am almost finished building the Car, and I can tell you that the tc4 aluminum shaft is way stiffer... I hope you're working on an A700 CF shaft too..... I did warn Oleg that the shaft needed to be hollow titanium or something so it wouldn't be so flexy, but carbon fiber is definitely stiffer....
Also, the A700 shaft is extremely close to the steering rack: 0.6mm or less.... That's why a 4mm CF shaft is necessary... Keep up the good work....
bertrandsv87 is online now   Reply With Quote
Old 08-29-2013, 06:12 AM   #437
Trader Rating: 113 (100%+)
I just shipped the complete TC4 shafts so hopefully you like them.
I have a donor Awesomatix shaft coming in for retrofit - test condition. Alex and I came up with a possible solution to the issue. One of the aluminim tips will be very short, just enough to fit into the carbon tube. The front tip will be extended to keep the 4mm OD appox 25mm. Hopefully this will correct the high levels of flex, eliminate the need for the shaft support (reduce drag) and still keep the clearance to the steering rack. I should have teh donor part over the weekend and get the updated part back to Alex for testing. He agreed to post pics of the part installed and provide some feedback once he has a chance to test.
Erik
http://store01.prostores.com/servlet/whipracing_bluescrews/StoreFront
ewippler is offline   Reply With Quote
Old 08-29-2013, 08:28 PM   #438
Default Tekno shafts
Originally Posted by Bignose94015 View Post
Could you make a center drive shaft for the Tekno SCT410?
+1 on this and the EB48. I can donate stock steel shafts for both. The front driveline is dogbone, very straight with ~4mm of float. Stock measurements are Length: 187mm Diameter: 4.8mm.
Boss Ross is offline   Reply With Quote
Old 08-29-2013, 08:57 PM   #439
Thanks Erik.....
Old 08-30-2013, 09:17 AM   #440
I just received the four CF shafts, and they are extremely light and slightly thinner than the original Ae shafts, which is good for the steering turnbuckle clearance.... I also run no foam cushions inside the input cups, and let the shaft float.... Nice Work Erik !
Old 08-30-2013, 06:34 PM   #441
I can try to make one for this car. Standard $28/shaft conversion price, plus the donor parts. Just PM or email if interst for additional details.
Erik
Old 08-30-2013, 10:29 PM   #442
oldrcr's Avatar
Trader Rating: 43 (100%+)
Alxd - Seattle RC Racers - AWESOMATIX - Having Fun :-)
oldrcr is offline   Reply With Quote
Old 08-30-2013, 10:30 PM   #443
oldrcr's Avatar
Erik
I will be converting my car over to carpet settings as I await the CF shaft. Our outdoor season has about come to a close, sometimes there will be one or two last runs if enough show up and the weather is dry, but I am not sure if I will get out to any of those. The indoor carpet season begins on the 21st of September, so I hope to have an update for all then. I will be running mod, so it will get a good test.
-Alex
Old 09-03-2013, 06:05 AM   #444
I received the Awesomatix donor shaft over the weekend and started the conversion. The shaft looks really small and flexes a lot. I would be surprised if it rotates without flex even with a 21.5 motor. Anyway, The conversion is about 1/2 complete and I should have some pics tonight comparing the converted CF part to a stock part. Stay tuned.
Erik
Also, I still have 1 or 2 of the TC3 and TC4 drive shafts available if anyone is interested.
Old 09-03-2013, 08:06 PM   #445
Pics of the Awesomatrix Completed Carbon Fiber Drive shaft, ver1.0. Weighed in at 5.4g versus the stock part at 7.1g. Also is much, much stiffer. Hope to have the part back to Alex shortly for test fitting.
Carbon Fiber Shafts for Touring cars-awesomematrix-3.jpg   Carbon Fiber Shafts for Touring cars-awesomematrix-2.jpg   Carbon Fiber Shafts for Touring cars-awesomematrix-1.jpg
Old 09-03-2013, 08:31 PM   #446
hanulec's Avatar
Trader Rating: 27 (100%+)
dupe.
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 09-03-2013, 08:31 PM   #447
hanulec's Avatar
very cool...
might be interested in a bunch of these...
Old 09-05-2013, 05:38 PM   #448
i am interested in one of those for TC4. how i can do??? thanks
pepito10.5 is offline   Reply With Quote
Old 09-06-2013, 04:34 AM   #449
PM sent.
Old 09-10-2013, 09:23 AM   #450
edonsohc's Avatar
Got the cf shaft for my tc4 the other day. Perfect fit, fast turn around, great communication. Thanks! Will recommend to everyone I know running a shaft drive car.
Tekno sct410.3, tekin gen2 rx8, hobbywing 4700kv motor, savox 1258.
Tekno EB48.3sl, 4000kv hobbywing on 3s.
Losi scb, mmp, bhr 10.5 motor.
Ofna H4E, vta, usgt, & 17.5 tc
Spratt's Hobby Center, Hillsdale Michigan.
edonsohc is offline   Reply With Quote
1/5th Fg Modellsport Touring Car Carbon Fiber Adj Rear Wing nytaurean R/C Items: For Sale/Trade 0 01-01-2008 07:38 PM
Racing MINI at the NA Finals? (tires and carbon shafts for sale) gibbous R/C Items: For Sale/Trade 5 08-20-2007 08:31 PM
carbon fiber shafts for tc4 speedybill Electric On-Road 2 07-13-2006 03:27 PM
Your take on 3 carbon fibre touring cars the dirt Electric On-Road 18 09-10-2005 12:23 PM
Carbon Fiber Drive Shafts Coming Soon Warren Weaver Electric On-Road 0 04-20-2005 08:25 AM
